while i have the HV battery out of my gen1
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Aug 14, 2013.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    Yes, I have them charging in paralell. They were at 7.46v and after 2hrs they went up to 7.92v. Could I be doing something wrong.
  2. bwilson4web
    16,202
    He is doing it right and there is no problem. I would only go up to 8V and then do a discharge to 7.8-7.9V. Then do the same for the three replacement modules. Now comes the hard problem, finding the weakest modules.
    The approach is to put a known load, say a tail light bulb, on each individual module for a fixed period, say 60-100 seconds using an accurate watch, and see which modules drop the greatest voltage. The two weakest are dropped from the reassembled pack. You also use this survey to pair the strongest and weakest module pairs with the strongest pairs in the middle and weakest on the ends.
    Now pairing the modules, two strategies come to mind but it isn't clear to me which makes most sense:
    • closely paired modules with strongest pairs in the middle and weaker on the end
    • strong and weak modules paired and using the average to stack stronger in middle and weaker on ends
    Of the two approaches, I'm leaning towards the first but can't give a strong reason why. If a weaker pair fail, having the two together might simplify a future repair . . . planning for the end game of the NHW11 modules. However, the second strategy, especially if the stronger is always on one side so they isolate the weaker ones, might minimize weak module heating concentrating. I'm certainly open to other suggestions.
    Before assembly, be sure and clean the terminals with distilled water and throughly dry. Also, make sure the buss bars are clean and free of corrosion. Be careful with the sense wires as any corrosion makes them fragile and subject to breaking. Easy to repair but . . .
    It sounds like you have a high probability of being on the road early next week! Just work carefully because you really don't want to do this again.
  3. scotman27
    735
    82
    PA
    2001 Prius
    I most certainly don't want to do this again if I can help it. All I want to do is get this to last me to spring (be great if it went much longer) so I will have funds available so I won't need a loan. I am going to have my replacements tomorrow.
    I got three to be safe. I will definitely do the tailight bulb thing to see how they drop. Then pair accordingly. I think ill put the strongest in the middle and weakest outside. Ill be doing this tomorrow. So ill be posting the results before and after.
    Any more advice and help it's much appreciated.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,431
    3,304
    Madison, Wisconsin
    John,
    You are correct. I was wrong. (That's what I get for skimming to fast and multitasking!)
    Since they are in parallel, it is safe (.05 amp per module). And yes, it still will take a long time.
  5. scotman27
    735
    82
    PA
    2001 Prius
    Ok. i disconnected the wire i had on both sides so i could take the pack out of parallel. all voltages last night at 11:30pm were 7.82v (they were 7.84v when I left) after sitting for 9-10 hrs while is was at work. hopefully thats not a bad drop.
    after taking the pack out of parallel so the modules would be disconnected from each other. this morning after sitting for 10 hrs the voltages are as follows at rest.
    1)7.81
    2)7.79
    3)7.79
    4)7.79
    5)7.78
    6)7.78
    7)7.78
    8)7.77
    9)7.78
    10)7.79
    11)7.79
    12)BAD MODULE (DELETED FOR NOW)
    13)7.79
    14)7.79
    15)7.78
    16)7.78
    17)7.78
    18)7.78
    19)7.77
    20)7.78
    21)7.80
    22)7.78
    23)7.78
    24)7.78
    25)7.78
    26)7.77
    27)7.78
    28)7.77
    29)7.78
    30)7.79
    31)7.78
    32)7.78
    33)7.79
    34)7.78
    35)7.79
    36)7.79
    37)7.80
    38)7.76
    it does not seem too bad. is this normal voltage drops over a 10 hr span? should I be concerned about module 36?
    After i do the light bulb drain thing to them, ill post results. then i may recharge to 8.0v. What other maintenance can I do to this pack.
    I know my super brain is 2 chargers in one meaning it can charge 2 batteries at once up to 5 amps a piece. i may connect my charger at separate ends of the pack and charge using both chargers at 3.50. that would double my charge right?
  6. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    An easy mistake and something we are all guilty of from time to time "I know I am". The important thing is you were using caution and trying to keep things safe obviously important with the voltage and current capabilities of 38 modules in whatever configuration.
    John (Britprius)
  7. bwilson4web
    16,202
    Don't worry too much about the least significant digit of a VOM.
    From the data you've posted, I see two candidates for replacement. It makes sense to test the two apparently weakest modules with the three replacement ones in a parallel charge to equalize and then discharge test. Keep the top three and put the bottom two aside as weak.
    Now if the three replacements do not arrive today, I would take the time to use the discharge through light test for a fixed interval, 100 seconds. Unlike self-discharge, the fixed load will put a significant load for a finite time on the modules and should more reliably identify the weaker modules.
    One last balance charge, parallel, for all modules and then reassemble and put in the car. Work careful on the reassembly. I would put the longer buss bar assembly on first. If I remember correctly that also includes the sense wires. It is easier to test the sense wires to the plug now than later in the car.
    Because the split buss bar has a jumper that won't be in, your voltage risk is 'less bad'. Carefully reassemble . . . "one hand rule." Button up and back in the car.
  8. scotman27
    735
    82
    PA
    2001 Prius
    ok i did the taillight test 60 second intervals
    the little light was pulling 2.28amps according to my meter.
    here are the results
    At rest v...........test results v
    1)7.81 .................7.64
    2)7.79 ................7.63
    3)7.79 ................7.63
    4)7.79 ................7.62
    5)7.78 ................7.60
    6)7.78 ................7.60
    7)7.78................7.62
    8)7.77................ 7.60
    9)7.78 ................7.61
    10)7.79 ................7.63
    11)7.79 ................7.62​
    13)7.79................7.63
    14)7.79 ................7.62
    15)7.78 ................ 7.60
    16)7.78................7.60
    17)7.78................7.61
    18)7.78 ................7.60
    19)7.77 ................7.60
    20)7.78................7.62
    21)7.80................ 7.64
    22)7.78................ 7.61
    23)7.78................ 7.60
    24)7.78................7.60
    25)7.78 ................7.61
    26)7.77 ................7.61
    27)7.78................7.61
    28)7.77................7.60
    29)7.78................7.61
    30)7.79................7.62
    31)7.78................7.60
    32)7.78................7.62
    33)7.79................7.63
    34)7.78................7.62
    35)7.79................7.62
    36)7.79................7.63
    37)7.80................7.65
    38)7.76................7.60
    I dont think that looks too bad(than again i am a new at this). what do you think?​
    should i charge to 7.8v and do this with a headlight bulb or was the taillight bulb i used fine?​
  9. bwilson4web
    16,202
    Hummm, you might find a quick refresher on the tags to make a table. For now, assume that "*" is the same as "[".
    *table]
    *tr]*th]header_1*th]header_2*th]...*th]header_last
    *tr]*td2]data_1*td2]data_2*td2]...*td2]data_last
    */table]
    So with the "[" you get:
    Column 1
    0 [tr][th]header_1[th]header_2[th]...[th]header_last
    1 [tr][td2]data_1[td2]data_2[td2]...[td2]data_last
  10. scotman27
    735
    82
    PA
    2001 Prius
    i edited my results hopefully thats better
  11. scotman27
    735
    82
    PA
    2001 Prius
    What do you think? do I have any bad modules or doe it look ok. if so should I put the pack in parallel and discharge it down to 6.0v with a couple of bulbs then recharge it then recharge to 8.0v? or just recharge and put it back in the car if my modules arrive?
  12. scotman27
    735
    82
    PA
    2001 Prius
    Well, the mail just came and went. and no modules. what a let down, usps is getting bad. i sent something to boston and its there in 3 days. usps cant get me my modules in 3 days from 2 1/2 hrs away? i dont understand. ok enough ranting. well i guess i wont be getting the car back on the road until tuesday or wednesday, if they show up.
  13. bwilson4web
    16,202
    These are the one I'd probably look at:
    Column 1
    0 [tr][td2]38[td2]7.76[td2]7.60
    1 [tr][td2]8[td2]7.77[td2]7.60
    2 [tr][td2]19[td2]7.77[td2]7.60
    3 [tr][td2]28[td2]7.77[td2]7.60
    The next set may also be weak as the least significant digit is the only real change. Module #38 looks the worst only because of the self-discharge. The others are just suspect.
    Let's go over some of the engineering. Your 2.28A lamp for 60 seconds was 2.28*(1/60) Ahr load, 0.038 Ahr discharge. Small steps are always best but they also give a clue as to what sort of values make sense (and are safe.)
    Take the above candidates and parallel balance them back to 8.0V. Then using the lamp for 10 minutes, 0.38 Ahr, report the starting and stopping, unloaded voltage. The 10 minutes puts a fair load on the modules and the voltage difference gives us a rate of dV/dC (C amp hour.) This will give a solid ranking of the strength, the amp-hour capacity, of these modules . . . a definitive assessment.
    There is another approach, put the load on and measure how long it takes to reach a common, target voltage, say 7.2-7.4V. Just use the measured time and dV to calculate the dV/dC. . . . Often there is more than one way to 'skin a cat.' It might be easier than trying to hit 10 minutes. <grins>
    Use the same approach with the replacement modules to figure out the best set. Then parallel charge the selected 38 modules to 8.0-8.1V and you're ready to go.
  14. scotman27
    735
    82
    PA
    2001 Prius
    Ok so parallel charge those four to 8.0v then discharge each one of those for ten minutes with the bulb and post the results? Just want to make sure I'm getting this correct
  15. bwilson4web
    16,202
    Correct.
    Your earlier tests suggests the charge should be fairly quick, less than an hour, and four, 10 minute discharges, another hour. This will give a better idea of the health of those four modules. The idea is to be able to rate their capacity and compare to the three coming in. Eventually the top three, one for the failed module, and the next two for the strongest set.
    My back of the envelope suggests two hours should handle it. Remember, this is just to get the pick of the litter.
  16. scotman27
    735
    82
    PA
    2001 Prius
    Ok, just got home and will be messing with the pack here in a minute or two
  17. scotman27
    735
    82
    PA
    2001 Prius
    ok,
    weak cell test 10 mins at 2.28amp discharge
    voltage at charge ..........voltage at 10 mins load connected.......... volts load off 2min recovery
    cell:38: 8.02.............................................7.35........................................................ 7.43
    cell:28: 8.02.............................................7.27.........................................................7.36
    cell:19: 8.02.............................................7.25.........................................................7.34
    cell:8 : 8.02.............................................7.23.........................................................7.32
    given i used four bulbs to speed the process, one bulb for each module. all at the same amperage.
    i tried to disconnect them as close to the ten minute mark as much as possible, so these could be off a hair.
  18. bwilson4web
    16,202
    Looks like you've got your order and #38 looks the strongest of the lot . . . a keeper. The others are so close, not hardly one worse than the others although #8 might be a flea's hair weaker. But we have enough information to estimate the Ahr capacity.
    ~0.65V/(2.28*(10/60)) = 0.65/0.38 = 1.7V/Ahr
    8-6 ~ 2V normal range (conservative)
    2/1.7 ~= 1.17 Ahr . . . fairly weak, an estimate
    What is important is you now have a credible test, with stronger, more trustable results than the single digit earlier tests, to evaluate the modules.
  19. scotman27
    735
    82
    PA
    2001 Prius
    would you recommend that i just replace the bad module that caused me the trouble, top off the charge and leave the others go and keep the other ones i ordered as spares?
    afte leaving them sit for a good hour. they just measured at
    8: 7.37v
    19: 7.39v
    28: 7.40v
    38: 7.47v
  20. bwilson4web
    16,202
    Even if you keep them as spare, you still want to know how good/bad they are.
