while i have the HV battery out of my gen1
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Aug 14, 2013.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    should i put the pack i parallel and discharge to 6.0v and recharge to 8.0 or just charge to 8.0 and leave it alone.
  2. bwilson4web
    16,202
    Personally, I would just charge to 8.0 and wait for the three to arrive.
  3. scotman27
    735
    82
    PA
    2001 Prius
    Ok, will do. ill try to do that tonight when I get home. I called the postmaster this morning and they told me I have two packages so I'm hoping those are it.
    My only fear is that they were abused during shipping or turned upside down.
    how hard is it to damage one of the modules by turning it upside down or shaking it?
  4. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The battery modules will not be harmed by shaking or turning upside down. They are effectively sealed units although they do have pressure relief valves. Damage by bending, dents or cracks in the plastic cases is a different matter.
    John (Britprius)
  5. scotman27
    735
    82
    PA
    2001 Prius
    okay great that's good to hear. I was afraid you know how they can be with packages sometimes throwing them in and out of trucks. even though it says fragile handle with care lol
  6. boppo
    boppo Active Member
    799
    139
    Owego, NY
    USPS would never do that. :)
  7. scotman27
    735
    82
    PA
    2001 Prius
    <grins>
    about a month ago, they did have a habit there for a couple weeks where i would get about 2 torn letters from their machine a week with an apology letter. and then they crushed my dads Opti-Lube and it was leaking in the box. they sent it back and sent us an apology letter as to what happened(someone smashed it when they took it out of the truck).
    I'm about throw them into the back of a truck and shake them around. mail came today and no modules again:mad:.
    if they dont show up tomorrow, im going to be pretty irate with them on the phone.
  8. scotman27
    735
    82
    PA
    2001 Prius
    Ok, so I was thinking about charging my pack to 8.0v then using 6 taillight bulbs at 10 min intervals I an going to test all modules in the pack 6 at a time and report the results.
    Do you think this would be necessary or not.
  9. EV_Cor
    EV_Cor Junior Member
    28
    40
    2002 Prius
    Necessary no, but it will tell you if any modules are low capacity (worn out) so those should be replaced before you put the pack back together.
    Original modules have 6.5 Ah capacity. It has been reported that some Prii ran fine even though the capacity was severely reduced, but I would consider replacing modules that have very low capacity before putting in too much effort rebuilding the pack, so this test will tell you if any have very low capacity. I think you said that the tail light was drawing like 2.7 Amps (?) which would mean that a 10 min load test will draw almost 0.5Ah from the module.
    If the voltage drops below 7.2V during that test then the module has at least one bad cell and you might consider replacing those that do not even survive the 10 mins.
  10. Patrick Wong
    18,204
    6,505
    Although this is true, it appears that scotman27's battery did not start from a discharged state. If, after resting for a few hours, the parallel battery still measures 7.94V then I would say he should stop, since the nominal battery module voltage is 7.2V.
    I agree that 8V per module is a good target voltage to strive for. 8V x 38 modules (when connected in series) = 304V compared to nominal battery voltage of 273.6V.
    It is not necessary to fully charge the traction battery; it is sufficient to get the battery to the point where it will comfortably spin MG1 to start the gasoline engine.
  11. EV_Cor
    28
    40
    2002 Prius
    While the nominal voltage is 274V, that is also the level that the battery is "empty", the normal operational voltage on the Prius HV battery is around 300V. If you want to reach fully charged, that will be around 330V, depending on temperature (higher temp = lower voltage, that is also the reason the you might be able to charge to close to 340V when the HV battery is cold, but it will drop to 330V when you continue to charge at a low current, of course, otherwise you will gas the electrolyte out of the cells)
    So, I find that you can see a constant current charge safely taking the modules to 8.7V (while compressed, as they will build up some pressure). At 300V the modules are about half-full, so the Prius will happily start with that level and will put a bit of charge into the pack, so 8V per module is a safe medium-charge level. Hope this clarifies.
    bwilson4web likes this.
  12. bwilson4web
    16,202
    Standalone, using my MRC989, I've seen voltages above 8.0V but not much above. More importantly, they are not holding nearly as much charge per volt above 8.0V as below. With 6 cells per module, 8/6 = 1.33V.
    Let me suggest reading the Panasonic datasheet on NiMH batteries: NI-MH HaNdbook - Panasonic
    • 1.5-1.62V maximum charge - 9-9.72 V peak shown at start of dV/dt drop (DANGER!)
    • 1.4V highest discharge voltage - 8.4 V the safest, highest voltage I would EVER go.
    • 1.33V - 8 V a safe target that provides 5% volt, safety margin.
    My MRC989 detects the dV/dt drop and stops charging. But as soon as it does, the voltage decays. The extra energy pushed into the module goes away (probably heat) and not much at all. Stop at 8V per module and you are in a good, conservative state. Go higher and your starting to play with risky voltages. These NiMH batteries do not take kindly to overcharging . . . even a little bit.
  13. scotman27
    735
    82
    PA
    2001 Prius
    At least I think the taillights are pulling 2.27amps. Thats what I get when I set my fluke voltmeter to dc amps and while it's puling the load it shows 2.27 amp. Hmmm it also says that even when nothing is connected to the module. I think the bulbs are a 3157 taillight bulb.
  14. EV_Cor
    28
    40
    2002 Prius
    3157 bulbs are spec'ed as a 27W + 7W dual filament bulb.
    7W as running taillight,
    27W as brake/turn light.
    This light is also used in trailers and pickup trucks, since you
    need only a single red enclosure to provide all mandatory lighting functions.
  15. EV_Cor
    28
    40
    2002 Prius
    Oh and since 12V, 27W means that 2.25Amp is drawn in normal application, I suspect that at 8V they will draw just under 2A for the heavy filament and just under 1/2A for the light filament, so I would not be surprised that the total current is 2.3 Amp at 8V.
    BTW, is your meter switched to "hold" mode so it continues to display the last measured value even when disconnecting the load?
  16. scotman27
    735
    82
    PA
    2001 Prius
    no i did not put it on that setting.
    my meter is a fluke 23 i have both probes connected on the right hand side.
    i have the bulbs set up to have both filaments illuminate
  17. scotman27
    735
    82
    PA
    2001 Prius
    ok, i may have a problem here. i just got off the phone with mark from prius rebuilders. he has not shipped them yet!
    i asked him why and he told me he has not found any that match capacities to what i have(he is going off of mileage and it being 12 yrs old), he doesnt want to send me crap modules.
    he told me last wednesday that he was shipping 3 of them out on thurdsay of last week.
    I wish he would of called and updated me on this. im pretty irritated that he didnt. bob wilson offered me some modules and im wondering now if i should of just went with him. i would of had them by now.
    I asked him how long and he told me he is going to ship towards the end of this week that he is going through cells.
    I paid $60 shipped through paypal to get 3 of them to cover myself if another goes. so i can always open a dispute and cancel
    what do you guys think about this? should I continue to wait or should i cancel.
    heck i could possibly call off work friday and drive the 2 1/2 hours there and take my pack with me and have him run a capacity test and see if he has cells to match.
  18. Britprius
    5,194
    1,921
    Scotman I am a little concerned about the current drawn with your tail lamp bulbs. You say this is around 2.7 amps. This seams very high for a tail lamp as these are rated (at leased in the UK) at 6 watts and turn signal bulbs at 21 watts, this translates to 0.5 amps and 1.75 amps at 12 volts. At the module voltage of 7.2 volts the current drawn would be nearer half those figures. Could you confirm the wattage and rated voltage of the bulbs used, or the exact type of bulb.
    John (Britprius)
  19. EV_Cor
    28
    40
    2002 Prius
    Hi John,
    Incandescent lamps are *not* resistors. Their current is almost independent of the voltage, because the higher the voltage, the hotter they get, the higher their resistance.
    Since those bulbs are spec'ed (in the US) for 7+27W (34W total) the 2.27 Amps reported seems to match pretty well at 8V, since they are supposed to draw a nominal 34/12 or almost 3 Amps total at 12V.
  20. EV_Cor
    28
    40
    2002 Prius
    Did the other 2 packages that the USPS said were on the way arrive in the mean time?
    If you want someone else to look at your pack, that is an option. Did you ask Mark what he can do for you?
    If you prefer to do this yourself (it is not difficult - I already explained the basic procedure - just some work and time spent) then the modules from Bob sound like an alternative. I do not know how money is, sometimes you need to do things yourself because money is tighter than time, sometimes it is the other way around - you could do things but don't want to spend the time. Do you have enough vacation to take a day without affecting your pay check, or would taking a day off cost you?
