while i have the HV battery out of my gen1
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Aug 14, 2013.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    oh yeah, duh(boy dont i feel like a moron), i forgot to mention that i have it in the car and running(y) , actually, i got the thing in there around 3;30 pm today and took it for a drive. ill have to post a video of how it behaves on my scangauge. ill try to do that before i go to work tomorrow. all i can say is the high voltage block numbers bounce around and so do the low block numbers bounce around instead of resting on one block like last time.
    but i do want to post a video of how it acts so you can tell me if everything is ok and looks good or if there may be something questionable.
  2. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    bob, what is the lowest amp hour capacity you would deem "good to use" for a re-build?
  3. bwilson4web
    16,202
    I don't have a good number. It is more important that the modules be charge balanced and have similar Ahr capacity than anything else.
    A strong module will have a flatter 'charge-discharge' curve than a weaker one. So if we had individual modules monitored, not the 19 pairs, the strong ones would stay closer to the nominal operating voltage and the weaker ones would go higher voltage on charge and lower voltage on discharge. By pairing the weak and strong modules, we're 'fooling' the battery management software into seeing the pairs work as if they are same Ahr capacity.
    What happens is as the modules become weaker, they tend to run hotter with a slight increase in internal resistance. The electrolyte is 'drying out' by loss of H{2} and O{2}. This means a smaller and smaller area of the plastic separator carries more and more of the current flow. Eventually this smaller area gets hot enough to melt the plastic mesh separator and that shorts the cell . . . fails the module.
    What we've done is 'battery emergency repair'. Consider it the same as using a can of 'quick fix' for a flat. You can now go far enough down the road to get the tire properly repaired but you are living on borrowed time. But you can 'baby' the traction battery to maximize the remaining life:
    • Heat is the Enemy
      • Do not go up a hill so fast the traction battery is providing charge to drive the wheels. Back off the speed in a hill climb until just the engine is providing the climb power (i.e., look for a semi to follow up the hill.)
      • Drive with cruise control as this minimizes the human 'fretting' that can cause micro-charge and discharge cycles. Smooth is you friend.
    Shop for a good traction battery rebuilder. In the East, I have used ReInVolt but there may be others closer of equal skill. Regardless of who, see if you can coordinate having the battery swap done over one of the three day weekends:
    • Price and payment expected (add 10% safety factor)
    • Check if they have a battery ready the week before (offer a deposit to hold it.)
    • Understand their hours (call frequently including ' I just wanted to let you know I'm on the road . . .')
    • Get a reasonable room; eat a nice dinner, and; let them know how to reach you if a problem shows up.
    Each shop is going to be different so negotiate. I would have no problem if ReInVolt offers to change the transaxle oil and coolant fluids. Especially if they can also do the inverter coolant pump. Negotiate because you want to leave with your car in the best possible operating condition. Living with a marginal car is no fun.
  4. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    bob, would you say my calculations here are correct?
    here are 3 cycles worth of mili-amp hour readings i took on a 2005 module with my supermate dc6:
    D1 2922
    C1 4705
    D2 4552
    C2 4828
    D3 4638
    C3 7249
    is it correct to say that the amp hour capacity for this module is 4.552 Ahr and that this would be a good working module? i know 6.500 is the ideal capacity for a perfect module.
    Read more: http://priuschat.com/threads/while-i-have-the-hv-battery-out-of-my-gen1.130701/page-6#ixzz2e3t8UVwX
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  5. scotman27
    735
    82
    PA
    2001 Prius
    seems i cannot upload a video on here. hmm well ill have to tackle that later. now onto the charger bit. which charger would you recommend, the dc6 or the superbrain 989 for bringing back my other 2 weak modules
  6. bwilson4web
    16,202
    It looks like you've got the "dc6" working correctly.
    slimfrancis likes this.
  7. bwilson4web
    16,202
    Put it in Utube and you can make a reference.
    I only have experience with the MRC 989 and it works perfectly fine. I have no experience with the DC6.
    GOOD LUCK!
  8. scotman27
    735
    82
    PA
    2001 Prius
    how would i upload a video onto here?
  9. scotman27
    735
    82
    PA
    2001 Prius
    bob how far voltage wise should i charge the weak modules up with my brain 977. im off today and could keep an eye on them. i stopped the one at 8.15v the other i didnt do yet,
    thank you
  10. bwilson4web
    16,202
    Read the manual: http://www.modelrectifier.com/resources/BatteryChargers/RB977_manual.pdf
    We do not know the current capacity so assume:
    • 3000 mAhr (3.5 Ahr)
    • 300 ma - 1/10 C safe charge
    • get two boards and clamps to secure modules so they won't swell
    You will use "A" channel because it also allows a discharge:
    • voltage -> 0V set so it will use delta peak
    • current -> 300 ma
    • cells -> 6
    • mV -> 5 mV (the manual suggests 30=6*5 mV)
    • mAh -> 3500
    • Min -> default
    Let it run until it stops. If you the a thermometer, monitor the temperature. If it goes over 90F, watch it. If it reaches 100F, stop. It has reached peak charge some time earlier. Whatever charge it shows, assume that is an initial approximation.
    Configure for a discharge to 6V limit. Whatever discharge is measured is the capacity. Put it aside and do the other one. Use the first module value + 20% as the estimated Ahr capacity on the charge and current.
  11. scotman27
    735
    82
    PA
    2001 Prius
    what if it drops the voltage below 6.ov should i shut it off?
  12. bwilson4web
    16,202
    Just pull one side to the module. You want the discharge Ahr as that is the metric of interest. According to the manual, it will report an error yet keep the values. But double check how to program the discharge to stop at a given voltage level.
  13. scotman27
    735
    82
    PA
    2001 Prius
    what about charging, should i let it run up until it shuts off?
  14. scotman27
    735
    82
    PA
    2001 Prius
    Well before I go any further, I'm going to invest in another charger that stores the capacities and does automatic cycling. It discharged the battery and then shut off automatically but I missed getting to it in time so I missed getting the values for time and capacity and voltage. So I recharged it and the last I checked at about 12am it was charging for 480 minutes and was at 8.4v and had put 2680mah into it, I fell asleep and woke up 2 hours later to Check on it and it has stopped charging and I couldn't get the values for it.
    I'm a little disappointed over that
  15. bwilson4web
    16,202
    Certainly look around but I am going to suggest an alternate.
    Do you have a video system that can run in 'time lapse' mode? It may be possible to setup a 'time lapse' video mode that might monitor the output. With say a 15 or 30 second delay between shots, you might be able to make a video recording and play it back later with the time-stamps . . . just a thought.
    The other alternative is to use higher currents. Double the current, half the time with some loss of accuracy. Still the 2,680 mAhr sounds about right.
    Now if you are handy with microprocessors and single board computers, you might 'crack the case' and see if there might be a debug-interface. In theory, you might be able to get a debug-interface to the microprocessor for your computer and see if it responds. Then comes the fun part, trying to find a way to read out the Ahr.
  16. scotman27
    735
    82
    PA
    2001 Prius
    That's an idea, but I don't think I got anything to record that long.
    I fly remote planes anyways so it wouldn't be a bad move for me to pick a charger that can cycle my receiver and transmitter packs. I'm going to look around locally for a charger. I'm looking at either the dc6 or the super brain 989 or an early triton
    bwilson4web likes this.
  17. scotman27
    735
    82
    PA
    2001 Prius
    here are the chargers i am looking at.
    the superbrain 989
    supermate dc6
    these ones my local hobbytown has in stock:
    http://hitecrcd.com/files/X1MF_US_Manual.pdf (link for the manual to the hitech x1mf)
    http://www.ecxrc.com/ProdInfo/Files/DYN4105_Manual.pdf (link to the passport ultraforce)
    http://www.batteryspace.com/prod-specs/6343.pdf (link for the manual to the Imax B6 quattro from Skyrc)
    im thinking of the getting the quattro because it can do 4 batteries at once and i think it will store the values when its done cycling the batteries but im not sure if it can handle four prius modules at once.
    let me know what you guys think.
  18. bwilson4web
    16,202
    I use the MRC 989. Although it claims up to 24-28(?) NiMH cells at once, my one attempt to do multiple Prius modules did not work out. It failed the MRC 989 but it was within the one year warranty. It took a month but they fixed it and since then, I only do one, six-cell module at a time.
    It keeps the last eight charge and discharge values and puts the battery on whatever tickle charge you want.
    The man-machine interface is 'modal' which means margin notes help. Also, the indicated charge limit of my unit continues for an additional 12% (very bad!) So now I take my desired charge limit * 88% and that is what I program in the unit. I hate that it does not indicate why the charge ended: dV/dt, charge limit, temp.
    It supports multiple battery profiles so you can have one for Prius modules and another for other systems.
    All-in-all, it seems a little pricey for an awkward man-machine interface. I would much rather have one with a serial interface that could be programmed from a laptop and record the data back into the laptop. I have to manually transcribe the numbers from the display.
    Also attempts to use it as a dumb power supply . . . well it still decides to shutdown after some finite time that I can not control. Still, it meets my primary requirements . . .
  19. scotman27
    735
    82
    PA
    2001 Prius
    the passport is $80
    the quattro is $125
    the hitech is $80
    I have a hobbytown 25 gift card i got from my girlfriend i can use to get the prices down
    im thinking of cycling my whole pack because if i was down to 1000 mah on the first weak cell that im working on and got that weak cell i took out to replace with yours up to lets say 3000mah, i should do the whole pack and should be good for a while. but i cant do one module at a time( due to it taking too long). that quattro can do 4 at a time but im not sure if it would handle 4 prius modules at once, it says 50w per channel power wise. what im trying to find out is if it will store the values from mall the charge/ discharge cycles.
    i could on my days off the night before take the cover off and start cycling the modules until they are all done and i get the final values from each module. but im still going to need to do more than one module at a time. what do you think about that quattro?
  20. hozer
    hozer New Member
    2001 Prius
    I have a hack-tastical prius-aware scanner based on some ELM327 clone that is currently giving me this kind of output:
    Code:
    send: 01af
    data read: 01af
    48 6B 16 41 AF 7F 7F 7F 19 0F 02 <DATA ERROR
    48 6B D5 41 AF 06 51 01 D0
    It's based on djs/obdii from github, but I can't for the life of me figure out how to talk *just* to the battery ECU.
    I also saw some other comment about how heat is the natural enemy of a Gen1 prius battery, and I can definitely confirm that. My donor battery pack was perfectly happy last night when it was cool, but is rather unhappy in the heat today. (I'm hoping I can manually balance recharge the two cells right in the middle that have a lower voltage than all the others)
