While it's happily charging, questions
Discussion in 'Prime Technical Discussion' started by Deleted member 111882, Sep 18, 2017.
  1. Maybe it's in the manual and glossed over it:
    Why does L2 charging happen at 8 A (according to my ScanGauge) even when the "Charge Current" setting is set to Maximum, rather than 8 A? And why was the "Charge Current" option frayed out when I ran this test on a public L2 charger?
    How do I keep the car on accessories (e.g., listen to music, run light A/C or heat) while staying in the car while it's charging? It seems to shut itself off after 2 minutes, so how do I just keep it on for longer?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    You're out of luck on that one. Toyota did this also with the 2012-2015 PIP. I guess Toyota thinks running accessories is wasteful use of energy
  3. Prodigyplace
    12,670
    11,829
    Central Virginia
    But the preconditioning is not a waste?
    When running accessories there is usually somebody inside the vehicle, unlike preconditioning.
    priuscatprimeguy likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    It doesn't, unless the EVSE tells it to. I've seen it at 15.4A.
  5. priuscatprimeguy
    2,730
    2,640
    Well IDK maybe Toyota thinks nobody's going to sit in the car for 2 hours. I'm just shooting in the dark here. I really don't understand Toyota's logic here.:confused:
  6. Lee Jay
    5,850
    4,036
    This is a software bug. It's supposed to last 20 minutes. I've reported it.
    mercat68 likes this.
  7. priuscatprimeguy
    2,730
    2,640
    Geez, you'd think Toyota would allow the 12 volt battery to be trickle charged by the charging system powered by the EVSE.:eek:
  8. Lee Jay
    5,850
    4,036
    It does the opposite.
    heiwa and priuscatprimeguy like this.
  9. bisco
    52,373
    let's face it, toyota has thought of everything. no improvements possible.
  10. priuscatprimeguy
    2,730
    2,640
    But not running in Accessories mode while sitting in your car while charging:mad:
  11. bisco
    52,373
    i bet tesla doesn't have this hurdle to overcome.
  12. Prodigyplace
    12,670
    11,829
    Central Virginia
    Neither does a Corolla.
    blueterp and bisco like this.
  13. bisco
    52,373
    i wonder what all this 'checking/operating' stuff is all about? must use a lot of power.
  14. Lee Jay
    5,850
    4,036
    Early Tesla's at least were famous for MASSIVE vampire loads killing both the 12V battery and the traction battery while the car sat unused. And the 12V battery is very hard to access making jumping really hard if that one died.
  15. bisco
    52,373
    yeah, a real piece of carp. i wouldn't touch one with a ten foot pole.
  16. Lee Jay
    5,850
    4,036
    I'm not making this up.
  17. Uh, to Toyota directly? How/If/Will they let customers know, and how to update their cars to get the 20 minutes?
  18. Lee Jay
    5,850
    4,036
    I submitted it to Toyota and I have no idea if or when they will fix it.
  19. Heh, was wondering how Toyota would respond, instead of fixing the software in the car to make it go 20 minutes, they'll say "Oh that's a typo, it's supposed to say 2 minutes" o_O
  20. DavidA
    2,348
    1,823
    Chicago western burbs
