saving EV till later
Discussion in 'Prime Fuel Economy & EV Range' started by priuscatprimeguy, Sep 16, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    not yet, but I've only had my Prime since November 2016 and I've filled my tank several times since then, it's supposed to show up after 1 year of no gas fill ups
  2. priuscatprimeguy
    2,730
    2,640
    ok, here's some solid info. drove off in HV mode with 32.5 miles EV. While driving around 70 MPH my EV would fluctuate from as low as 28.4 miles to a high of 31.2 miles. when I arrived in Ann Arbor I travelled 58 miles got 50.0 MPG and my EV was at 29.5 miles.
    Tideland Prius likes this.
    52,781
    i'd comment, but i don't own a prime.:oops:
  4. priuscatprimeguy
    2,730
    2,640
    awww, go ahead Bisco, give it your best shot:p
  5. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    What I would really like to see is the mpge if you ended the drive with 0 EV. Also, if you took another route and was able to lower the speed.
  6. DavidA
    2,349
    1,825
    Chicago western burbs
    Last month I drove a couple thousand miles from Chicago to an eclipse viewing spot in NW Nebraska. I charged up to 100% at home on my L2 right before I left for an estimated 33.x miles. I used regular HV mode (gas - arghhh!) for the entire trip there and back. At the end of day one, I had between 97% and 95% remaining. It fluctuates depending on temperatures outside and the temp's around the main battery. At the end of day two, and at 850 miles in HV, I was down to 92% - I still hadn't used EV mode. By day four it displayed 83% left. Still no intended EV usage. My conclusion is that there are losses both real as well as some phantom losses as the car seems to use the battery reserves in some way unknown to me.
    Before I returned home, and with about 80% charge remaining, I greedily stole some electrons from a nearby camping site's 120v outlet to get back to 100%. I did pay for the camping if you're wondering (but not for the site with electric :p ). This was the first time I used the L1 plug and cord that came with my car. That 20% took two friggin hours!
    Slow charging in Hemmingford, NE.
    The two day trip home, again completely in HV, this pattern repeated and I was down to a little below 90%. The phantom drain was still going on. The final 15 miles I happily shifted my driving style to pure EV and still had some small EV miles left on the readout when I pulled into my driveway -- where I then immediately plugged into the L2.
    #26 DavidA, Sep 19, 2017
    priuscatprimeguy likes this.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I've noticed that Hv targets current charge level or 80%, whichever is less. I drove 400 miles starting at 80% and it stayed right there.
    L1 will give you 10% every half-hour up to about 98%, then the last 2% will take another 30-40 minutes.
    breakfast and priuscatprimeguy like this.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Charging is non-linear, so the final % is much slower. Using a remote outside outlet like that will slow it down even more.
    breakfast likes this.
  9. john1701a
    12,840
    5,312
    58
    Correct, water penetration into the system is prevented.
    I certainly haven't ever encountered any trouble, going months between fill ups.
    SM-G920V ?
  10. bwilson4web
    16,513
    Just before filling up the third tank. The only reason for filling up was to deliver a Gen-1 battery pack to Knoxville.
    drysider likes this.
  11. drysider
    823
    336
    Liberty Lake WA
    Can you supply some details on your driving habits? I am assuming mpg's like this are due to a lot of EV and shorter trips. What kind of mileage did you get on the Knoxville trip? Have you tried any high speed/long trip techniques to increase mileage?
  12. bwilson4web
    16,513
    I live in Huntsville AL and everything I want is within 10-15 miles. We are also well populated with free L2 chargers.
    I’ll have to check my records on the Knoxville trip but I am sure between 55-60 MPG. I use dynamic cruise control to follow a pacing truck or car:
    Prius Prime Plus in my hands | Page 24 | PriusChat
    Trip summary for July 9:
    • 467.5 miles
    • 58.8 MPG
    #32 bwilson4web, Oct 12, 2017
  13. priuscatprimeguy
    2,730
    2,640
    joachimz and john1701a like this.
  14. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    It's not possible to save EV charge as loads continuously vary. However, if you want the best mpg, use all of your Ev, let the car switch over by itself and then observe the results. Shockingly rewarding. Note: I am speaking of reasonable driving. like Bob Wilson.
  15. Lee Jay
    5,850
    4,036
    And yet, I've done it several times over thousands of miles.
  16. Andyprius1
    2,327
    859
    Cool CA
    I think it's fiction, OR: 35 MPHr......everywhere. no possible Senor.
  17. Lee Jay
    5,850
    4,036
    My first tank was 1509 miles.
    My fifth tank was 1151 miles.
    My sixth tank was 2045 miles.
    My current tank is over 1800 miles.
    john1701a likes this.
  18. Mark57
    2,945
    2,740
    OK
    Ditto, I'm' on track to duplicate your results, I just need more time behind the wheel. Absolutely doable depending on where you live and drive.
  19. priuscatprimeguy
    2,730
    2,640
  20. priuscatprimeguy
    2,730
    2,640
