Whining noise from driver's side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ron69424, Aug 31, 2008.
  1. gac53
    gac53 Junior Member
    Minnetonka, MN
    2002 Prius
    Thanks. Would that mean the check engine light would be on?
    Greg
  2. gac53
    gac53 Junior Member
    Minnetonka, MN
    2002 Prius
    Added quote.
  3. Patrick Wong
    18,210
    6,510
    Hi Greg,
    No. Assuming that the problem is with the transaxle or inverter, when a DTC is finally logged the master warning light (red triangle) should come on and the hybrid vehicle icon should appear in the MFD.
    The check engine light would come on if a DTC was logged by the engine ECU.
  4. ron69424
    ron69424 New Member
    75
    Just to give you guys an update of my 04's continuing problem here's what's happening.
    The electric motor seems to be straining to get the car moving. The ICE has to kick in way sooner than normal to accelerate. The car acts like it has those big mud bogging tires with the big lugs. You can feel the lugs (or gear teeth) lugging. Don't know how else to describe it. The traction battery is staying highly charged (in the green). The gas mileage is much lower than normal.
    There are still no codes or lights. I keep the scan gauge on all the time.
    Any ideas. Thanks, Ron
  5. Patrick Wong
    18,210
    6,510
    Hi Ron,
    Just for fun, how about disconnecting the Scan Gauge, and also disconnecting the negative terminal of the 12V battery for 10 minutes (to allow all ECUs to reset).
    Then reconnect the battery (leaving the SG disconnected) and see if there are any driveability differences.
  6. ron69424
    ron69424 New Member
    75
    Hi again Patrick:
    I couldn't stand not knowing the problem so I took it to Toyota today. Three mechanics drove the car with their scan tool. Then they ran the car on the rack with the ICE disabled. They pin pointed the noise to the transaxle and said it is not long in this world.
    When they ran it after disabling the ICE many lights and codes appeared that did not register on my scan gauge. Their opinion is that the differential carrier bearing or the pinion bearing are failing.
    This is the first example of transaxle failure this Toyota service dept. has seen. It is truely a rare occurance. Like winning the lottery.
    I already have a salvage transaxle from an '05 with 40k miles on the way. I have all the Toyota maint manuals and a shop garage. I will attempt to change it out myself. If you have any pointers let me know. Thanks, Ron
  7. Patrick Wong
    18,210
    6,510
    Hi Ron,
    It is great that you have a diagnosis and are going to tackle the job yourself. Good luck with the transaxle swap. Please take lots of photos and post!
    After you get the salvage part in, if you have time to disassemble the failed transaxle and photograph what it looks like, that would be very interesting to see. I am particularly interested to know what the stator windings look like (any burnt wire?) and what the bearings look like (any obvious wear?)
    Please answer my repair poll in the main forum, so that we can log your car's activity.
  8. Patrick Wong
    18,210
    6,510
    Hi Ron,
    Since your car has 92K miles, it may make sense to replace the front axle bearings while you are working on the car, and also inspect the axleshafts to make sure they are in good condition.
    I am also wondering whether it makes sense to replace the engine at this time, since you have to remove the engine and transaxle from the vehicle. Note for example, that you can buy an engine with 3,900 miles for $500 from this source:
    04 and newer Prius Parts Cars
  9. ron69424
    ron69424 New Member
    75
    Hi Patrick:
    Thanks for the suggestions. I started tearing down the car today. I should have the transaxle out tomorrow. The salvage unit should arrive in 4 or 5 days. I may end up replacing one or both drive shafts. The wheel bearings show no signs of wear (play or noise). I'm not removing the engine and it seems to run well with no oil consumption between changes @ 7000 miles.
    The Toyota dealer quoted a price of over $6,000 to replace with a new unit. They would not consider installing a used one. All said and done I should have it done for under $1000. I will keep you posted, Ron
  10. Patrick Wong
    18,210
    6,510
    Hi Ron,
    OK, if you can remove the transaxle without removing the engine, that would be great. I'd like to see how you do that if you can take some photos.
  11. ron69424
    ron69424 New Member
    75
    Patrick:
    I will try to get some photos posted with my teenage sons help as time permits. I am not very computer savy.
    Didn't get the transaxle removed yet but this will be the next step Monday morning.
    Ron
  12. patsparks
    10,664
    567
    Adelaide South Australia
    If you can feel a cogging sensation and reduced power I would have thought MG2 may be fried and one of the 3 phases is burnt out. This can occur if the car is in a accident and there is a problem with the transmission coolant circulation after the car is repaired caused by a kinked hose or pipe or air in the system. I read this somewhere but not sure where.
    It may be important to double check coolant lines and carefully bleed the system to prevent future failures. Then again I could be full of crap.
  13. ron69424
    ron69424 New Member
    75
    The transaxle is out!
    Now the hard part (taking out is always easier than putting back). After the replacement arrives and my car is running, I will tear the old unit down to see what failed. I will try to take pickures and keep you informed.
  14. gac53
    gac53 Junior Member
    Minnetonka, MN
    2002 Prius
    Patrick and others,
    The red triangle and other lights came on today. Strange driving experience (real slow) until it stopped and I turned it off and restarted. Then it ran almost normal with the warning and check engine light still on and normal display showing. Could actually see that battery was low - but eventually charged back part of the way before I got home to park it. I plan to get a salvage transaxle for $700 and have it installed at an "all purpose" shop close by.
    Any warnings for them?
    Good to have you experts out there to give us newbies tips.
  15. ron69424
    ron69424 New Member
    75
    I finished the installation of the 05 transaxle into my 2004 today along with a low milage drive shaft on the driver's side.
    The car drives well with no unusual noise :D. I found the toyota manual to be very helpful. I did do things a little out of order to make things easier.
    The most difficult part was disconnecting some of the plugs that were very hard to get to. Also the drive shaft on the driver's side refused to come out no matter how hard I tried. It took much patience and three different jacks and hoists to align and install the new transaxle into the engine.
    I got the transaxle and drive shaft from Hybrid Autoparts in Rancho Cordova, CA. They were very helpful and reasonable.
    I leave on a 4 day trip tonight but when I have some time I hope to tear down the bad transaxle and determine what went wrong and why. I might even have pictures.
    Thanks everyone for your input.
    Ron
  16. Patrick Wong
    18,210
    6,510
    Hi Greg,
    I recommend that you have the DTC (diagnostic trouble codes) retrieved by your local Toyota dealer, to confirm your belief that the transaxle is bad. If the problem is intermittent, I would think it more likely that another component has a problem, such as the inverter or hybrid vehicle ECU.
    Hi Ron,
    Congratulations on the successful completion of your repair. Is this the reason why Toyota recommends that the engine and transaxle should be removed as a single unit from the vehicle?
  17. ron69424
    ron69424 New Member
    75
    Hi Patrick:
    The three vol. Toyota manual I referenced did not suggest removing both the engine and trasaxle as a unit. But it probably would have been easier in the long run to have done so.
    If I ever do this again :mad:,(and I hope I don't), I will probably do both at the same time. Dispite all the pain and agony I appreciate the experience for what I have learned:rolleyes:.
    Ron
  18. Patrick Wong
    18,210
    6,510
    Hi Ron,
    You are right - I checked my 2G repair manual and confirmed your statement. Perhaps the Classic repair manual suggested removal of engine/transaxle together; and the procedure was subsequently changed for 2G.
    How much time did you spend on the repair job?
  19. ron69424
    ron69424 New Member
    75
    Hi Patrick:
    I didn't punch a time clock but I estimate approx. 20 hours work. Thankfully I was on vacation.
  20. gac53
    gac53 Junior Member
    Minnetonka, MN
    2002 Prius
    Thanks, Patrick, will do.
    Greg
