Whirring buzzing noise when car is off, in garage hours after shutdown
Discussion in 'Gen 3 Prius Main Forum' started by gerrypez, Jan 2, 2011.
  1. gerrypez
    gerrypez Junior Member
    Davis, CA
    This is strange. Twice in the past week I have gone in my garage at night, and my Prius'10 is make a buzzing whirring noise. Without touching it ... it's just sitting there making a buzzing noise. This is hours after using the car.
    Any ideas?
  2. gerrypez
    Davis, CA
    I found the answer in another thread (I had searched but somehow missed it).
    "Approximately five hours after the hybrid system is turned off, you may hear
    sound coming from under the vehicle for several minutes. This is the sound
    of a fuel evaporation leakage check and, it does not indicate a malfunction."
    That must be it. So never mind!
  3. Mendel Leisk
    38,644
    First time I heard that: I'd jacked up the rear end of our near-new 2010, and the noise started up. As you said: it had been hours since it had run. My first thought was: 'oh man, I've done it now...'. ;)
  4. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    Thanks for this thread. Just heard it in the garage tonight (about five hours after I last shut my new '11 Prius down). The location seemed to be in the back, and nothing like the coolant recovery pump from the 04.
    Sighs of relief that my battery won't be dead tomorrow morning. :)
    Bob.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This information is covered in the owner's manual for both the Gen II and Gen III.
    Tom
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    To paraphrase from the owners manual:
    "Any noise you hear, whether the car is running or not, is normal."
  7. SamelCamel
    SamelCamel New Member
    60
    Kansas
    Don't forget also that if you approach the car with the keys in your pocket, the car may make noise based off of the proximity.
    Just another thought.
    -Sam
    princessprius likes this.
  8. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    How far should the fobs be stored from the vehicle? I'd really like to be able to keep the spare fob in the car, but I guess that can't be done and still lock the doors.
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Walk up to your car at night and notice when the interior lights illuminate. That should be the distance that the SKS detects the key fob. Storing the key further should not be a problem. I think you could lock the fob in the car but you would have to use the actual key and lock to do it.
    Aloha,
    ED
  10. David Beale
    5,963
    1,981
    Edmonton Alberta
    Find a metal box the FOB will fit in. Then you can store it in the car. Car thieves will love you for it.
  11. jamesa53
    jamesa53 New Member
    74
    Indiana
    That is just too hilarious!!! Love It!!!!!:D:D:D
  12. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I was about to make a new post and found this on a search. I heard the whirrling/buzzing noise about 5 1/2 hours after I turned it off. the FOB is about 15 feet from the car. even though it is in a garage I hit the lock button and the sound went away.
  13. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    If it's gen III you CAN leave the spare key in the car and lock it with your other FOB. However the car will continue to be "aware" there is a key in the car and will periodically communicate. This will use power from your 12v battery.
  14. Jpk5
    Jpk5 New Member
    dall
    Ok, I have this noise on my 2010 Prius and the noise hasn't stopped for a couple of hours, car now won't start and there is a sulphur type odor. Any ideas? Any ideas on hou to get the power killed to the car
  15. WE0H
    WE0H Senior Member
    3,247
    527
    Yikes, sounds like something wrong with your 12v battery. It is located in the passenger side rear corner of the hatch area. Unhook it until you figure out what the issue is.
    Mike
  16. Ynot1951
    Ynot1951 New Member
    Wisconsin
    I have experienced this several times with my 2010 and also with my wife's 2007 Prius. I have found that if I grab the key, start the car for a second or two then shut it off the noise stops. Do not buy the suggestions offered. Would prefer that Toyota be more transparent about what is causing this.
  17. schorert
    schorert Member
    127
    51
    mass
    from another thread:
    From the owner's manual:
    Noise from under vehicle after turning off the hybrid system:
    Approximately five hours after the hybrid system is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction.
    WE0H likes this.
  18. qbee42
    18,058
    3,074
    Northern Michigan
    Toyota *is* transparent about this noise. It is the evaporative system leak test, as discussed in a previous post. Whether you buy it or not, this is the cause of the noise. It is clearly described in the owners manual.
    As for the person with the sulfur smell, that's a different issue. That generally means that something has gone horribly wrong with the 12v battery.
    Tom
  19. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Also came here via a search b/c I heard the noise today for the first time (1 month Prius owner here). Sorta freaked me out, I thought the car was becoming self-aware or something.
    BTW, I had not driven the car for 7 hours. I hope it wasn't running for 2 hours or something.
  20. David Beale
    5,963
    1,981
    Edmonton Alberta
    What do you mean "becoming" self aware? It already knows you, how you drive, what it's supposed to do in many situations. Pearl S is WAY smarter than I am. ;)
