Whirring Noise when put in Reverse Gear
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Robert van Nostrand, Jun 8, 2024.
Tags:
  1. Robert van Nostrand
    Robert van Nostrand Junior Member
    Halifax, Nova Scotia, Canada
    2022 Prius Prime
    Technology
    It is normal for a new to me, 2022 Prius Prime to make a metal on metal whirring sound when put into reverse?
    I mainly notice it when inside a parking garage. No noise when the car is turned on. Slight whirring noise when put into Drive, much louder noise when put into Reverse gear (not moving).
    The whirring noise resembles what I would describe as a metal wheel spinning against another metal wheel.
  2. schja01
    schja01 Senior Member
    1,842
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    The pedestrian alert/warning system?
    The sound device is in front so it increases sound level when in reverse so people behind the car can hear it better.
    Trollbait likes this.
  3. Robert van Nostrand
    2022 Prius Prime
    Technology
    Thanks for your response. Hmm, I don’t know what the alert you describe sounds like. I picture a loud Beeping sound like on delivery trucks when they backup, but this is nothing like that. It’s more like a gear turning.
    52,371
    for some reason, toyota's are inordinately loud. is the volume adjustable?
  5. Robert van Nostrand
    2022 Prius Prime
    Technology
    I have a YouTube recording but can’t post it because I am too new here…
    BUT if you listen to this guys YouTube and IGNORE the beeping sound, you can hear the whirring noise in the background that gets louder in Reverse. So I guess this is normal?
    #5 Robert van Nostrand, Jun 8, 2024
  6. schja01
    1,842
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s more like the sound a bunch of Cicadas would make.
  7. Robert van Nostrand
    2022 Prius Prime
    Technology
    OK, thanks. I found another "noise" YouTube video and confirmed that the sound I am hearing is the Pedestrian Alert noise. Its not anything like a beep beep, but as you say, more like a continuous sound of Cicadas singing together.
    schja01 likes this.
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The beeping sound is only on the inside, to make you aware you are in Reverse. The outside sound has been likened to the drone of a space ship. It was not as loud in early Gen 4s, but made louder in later models, due to changes in the federal regulations.
  9. bisco
    52,371
    when we are on our daily walk, a lot of cars pass us slowly enough the the pedestrian warning is on.
    toyota seems to have the loudest, or perhaps it's the pitch, idk.
    our new hycam is much more obnoxious than our new bolt.
  10. Mr.Vanvandenburg
    1,358
    588
    2020 Prius Prime
    The 2020 I have seems pretty quiet electrically. I almost always have a window open. I don’t hear the space ship sound at all.
  11. schja01
    1,842
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    You’ll only hear it below about 20 miles an hour or so. Also fairly sure you will not hear it if you are in HV mode as in engine is running.
  12. Mr.Vanvandenburg
    1,358
    588
    2020 Prius Prime
    I go slower than 20 a lot, and 99% is in ev mode, not auto ev or hv mode. I back up often and a long way. Go slowly up parking garage grades and a steep hill at 25 every day. No audio on. No space ship sound so far, maybe I got a lemon. I’ll focus on it more to make sure.
  13. Mr.Vanvandenburg
    1,358
    588
    2020 Prius Prime
    I listened more today and the signal is there when brake is released going forward and in reverse. Very quiet and steady sound, not that noticeable with window open, quiet area. Not a louder whoop whoop electrical type sound I hear other cars making, even going down the street. .
    I find it a non issue on my car since I had to try quite hard to notice it.
  14. bisco
    52,371
    you either need hearing aids, or got lucky with a defective unit.
