whistling noise on freeway
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by oil_burner, Mar 22, 2017.
  1. oil_burner
    oil_burner Active Member
    249
    126
    I am noticing a very annoying whistle above 35mph on the drivers side. I have checked some threads here that suggest taping over the screws under the mirror, and have done so with some clear tape but the noise persists. Any other suggestions on the cause? I have also treated all the door seals with some rubber conditioner/cleaner that hasn't helped either.
  2. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Try to move the windows a slightest bit to see if that effects the noise? Or if you lean on the door? Or something else? Try to figure out where it comes.
