Whistling sound after replacing condenser
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WxW, Jul 28, 2023.
  1. WxW
    WxW Junior Member
    Netherlands
    Business Edition
    I replaced the condenser of the a/c today. The a/c hadn't been working for a while and the condenser definitely needed replacing. It probably leaked cause there was no presssure left in the system.
    After replacement I took the car to a shop and had them test for leaks, vacuum the system and refill the refrigerant and add a little bit of oil. Took it for a test drive. It blows very cold air again. So far so good. After parking the car however, I noticed a high pitched whistling noise coming from the car. It's hard to locate the exact source but it appears to be coming from around the condenser. It stops after a few minutes. A/c still blows cold air.
    I have attached two recordings of the noise.
    Any idea what this could be? I called the shop but they don't know ... they said just continue to use it and see what happens.
    #1 WxW, Jul 28, 2023
  2. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    I'd give it some time... If the AC keep blowing cold than it's not a leak. If it is a leak go back to shop and ask them how come they charged you to check for leaks and they didn't do what you paid them to do.
  3. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    And then after you get out of the car and walk away or begin to how long will that whistling continue till you get tired of standing there or does it stop almost immediately?
  4. WxW
    WxW Junior Member
    Netherlands
    Business Edition
    It goes on for a couple of minutes.
  5. Tombukt2
    13,875
    2,521
    Durham NC
    If I'm not mistaken on the side of the factory type condenser for the air conditioner in front of the radiator there's an accumulator or a tank on one side and it may be just the gas accumulating and settling down after running. It may not be as quiet as the original unit for whatever reason some of these newer things have smaller ways and passages and the things and what have you which can be a problem sometimes it's not. If it's a factory direct replacement I might want to make damn certain that my gas charge and everything is seriously correct I realize it was done at a shop for money so there's that You can take a long coat hanger or something like that a mechanic stethoscope was a long piece of metal on its pickup and listen to I think it would be the right side of the condenser that's where that little accumulator looking tank is if I'm not mistaken it is on my '05 anyway and listen and see if that's where the noise is emanating from You can probe around with the mechanics stethoscope and see if you can isolate the noise to a certain spot on the condenser in the hose in the compressor obviously this is off so everything should be fairly safe.
  6. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    A true whistling sound results from gas moving through a small hole. That shouldn't be happening anywhere in the AC system. If your car does that reliably give the AC shop a call, tell them you're coming in, and have them listen to it when you get there.
  7. WxW
    WxW Junior Member
    Netherlands
    Business Edition
    Well I called the shop where I had it refilled and checked, but they weren't very helpful. Said they don't know what causes it and weren't even interested in listening to the recording I sent them.
    #7 WxW, Jul 28, 2023
  8. PriusCamper
    13,475
    5,441
    Catch is the shop was paid to find those leaks and they said they didn't find any... Hard to imagine something came loose on the drive home, but until the AC stops running cold, it's probably best to update the shop about the symptoms and wait for things to change.
  9. pasadena_commut
    3,071
    956
    Southern California
    "Shop doesn't want to hear about it" isn't a sign that the shop is very trustworthy. I'm trying to think of a situation where a whistling sound isn't indicative of a problem in a car, and the only thing I can come up with is whistling from the windows due to a cross wind. In this case we know it's the AC because the OP only hears it when the AC has run, and it sounds like it is coming from near the condenser that was just replaced. I would take it to a different AC shop for a second opinion, and arrange the appointment so that they have time to listen to the noise immediately on arrival.
  10. PriusCamper
    13,475
    5,441
    Because the shop is in the Netherlands and subject to far more strict EU consumer regulations compared to the US, I'd be willing to bet the shop is basically saying get in touch if the AC stops working, but how it sounds doesn't concern us as long as its working. And its pretty common for shops to have very little patience for people concerned about strange noises if the car is working fine without any issue but the noise. I tend to be the same way.
  11. pasadena_commut
    3,071
    956
    Southern California
    Is it possible that one of the valves is leaking? The shop wouldn't have seen that since they would have had their equipment attached to them.
    PriusCamper likes this.
  12. PriusCamper
    13,475
    5,441
    Time will tell... If OP doesn't return to update it's likely that everything is fine and weird noises in old cars is nothing to get on about.
