Whistling sound comes from engine
Discussion in 'Gen 3 Prius Technical Discussion' started by Princedunet, Jan 27, 2018.
  1. Princedunet
    Princedunet Junior Member
    46
    morocco
    2012 Aqua
    Hey bro, if you see the video I attached, the sound is same as the last sound of the inverter in the video, and it started I accelerate at speed more then 50km/h, maybe someone else can’t notice this sound but for me I can hear it, is not so loud but it exist, hope it a normal sound and not an issue
  2. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Watched it. It's the same as mine, this whine has been posted many times. It's normal. Same for el converters
  3. Princedunet
    46
    morocco
    2012 Aqua
    so it’s normal. Thank you all
  4. Princedunet
    46
    morocco
    2012 Aqua
    Hey guys, I’ve record a video that shoes clearly the sound.
  5. Princedunet
    46
    morocco
    2012 Aqua
    Hey guys, Im here again and this sound still anoying me too bad, I could make a video, If you can hear the sound , it starts from sec 22, listeen carefully and tell me what do you think
    https://youtu.be/p3Nr_ULN00c
  6. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Sounds like the interver, louder than usual. I was thinking a quieter whistle but that's way louder than mine and most gen 3 I've test driven
    Raytheeagle likes this.
  7. Princedunet
    46
    morocco
    2012 Aqua
    So it should be replaced or repaired and how long the inverter resist. And what do you the probleme comes from? Is the inverter coolant because I never change the coolant water . My prius is 152000km
    #27 Princedunet, May 12, 2018
  8. Erman Atalay
    Erman Atalay New Member
    San Diego
    my car is almost 190k miles I have the same problem . Please keep the post updated.
  9. Erman Atalay
    San Diego
    I have 2013 Prius with 220k and I 've been hearing the same loud whistling from the engine. it started around 180k and it wasn't that loud when it first started. I thought it might be the pump and today I decided to change it myself. I was able to replace the pump without removing the inverter. I just lifted the inverter put a piece of wood underneath just like someone else from another post. After that, everything was normal the sound was gone. I drove the car for about half a mile for a quick tour nope no noise or nothing. then I park the car opened the hood and I opened the inverter coolant lid just to see if there is any movement in the coolant. there was no movement. (by the way, I've never seen the coolant moving ever, not with the old pump neither with the new one) Then something strange happened. I heard a puffing noise sounded like a pressured air leaked instantly from somewhere it shook the engine a little bit too. it was the same time me opening the lid and the sound came right then. I don't know what it was. And then the noise was back the car started whistling again just like before. Tomorrow I m going to check the fuse box to see if anything wrong there. I will try to figure out why the pump is not moving the coolant. I will keep posting.
  10. Brocklyn
    Brocklyn New Member
    CA
    did you ever find a remedy for your whistling problem? My Prius has just started doing the same thing. Thanks!
  11. Genc
    Genc Junior Member
    Oslo
    Did you figure out what the issue was since my car started doing it aswell? just 96.000km Gen 3
