White defect on taillights?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elt31987, Nov 9, 2021.
  1. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Anyone noticed something similar on their tail lights? What's strange is its on the inside of the light. And there's no cracks or damage to the lights. The lights never get moisture in them after rain etc. This is the worse of the 2 lights. The other still has some of this white stuff in it though.
    PXL_20211104_210048740.MP.jpg PXL_20211104_210055626.MP.jpg PXL_20211104_210103087.MP.jpg
  2. Elt31987
    205
    155
    Derry, NH
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    My guess would be water spots. Looks like a crack or a seam might be the problem.
    I noticed it first here, but then saw it on the 1st picture, too. My wife is out right now with her 2017, so I can't compare.
  4. Elt31987
    205
    155
    Derry, NH
    That is a seam that runs the entire length. Id normally suspect a crack, but to happen to ALL 4 tail lights and to be as white as paint? Very strange indeed.
    jerrymildred likes this.
  5. jerrymildred
    11,517
    14,170
    Tampa, FL
    Strange indeed. I looked just now at my wife's tail lights and I see the seam. She has a slight watermark at the bottom left corner of the left upper light.
  6. Elt31987
    205
    155
    Derry, NH
    Yeah i always had a very slight something, but then one day its full blown white paint looking. After seeing used tail lights on ebay with the same issue its obviously a more widespread issue than just me. Oh well, sees got over 100K on her so the lights will stay. Before covid you could get a new light for about 50 bucks but now theyre 100 so ill live with it
  7. Joemcb
    Joemcb Junior Member
    Michigan
    Three Touring
    My 2016 is just starting to show these marks and it’s new from this winter. Any idea how to fix or is this a replace the lens? IMG_2480.jpeg IMG_2481.jpeg IMG_2480.jpeg IMG_2481.jpeg IMG_2480.jpeg IMG_2481.jpeg
  8. Elt31987
    205
    155
    Derry, NH
    Besides replacing I don't think there is anything you can do. Ive left mine
  9. jerrymildred
    11,517
    14,170
    Tampa, FL
    They are slowly getting worse.
  10. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Assuming that the problem is occurring from the inside of the lens, therefore NOT related to anything the owner could or could have done, that would potentially make it a serious safety defect and hazard. I would suggest a visit with your dealership and emphasizing that aspect regardless of warranty status. And I am not one to jump on that bandwagon in most cases.
    It appears as though the lens is degrading from the inside out, so blaming environmental factors won’t work for this one.
  11. Henrique Lucas Chevrand
    Henrique Lucas Chevrand Junior Member
    Brazil
    image.jpg 056A074E-E8B0-490A-8AB8-6AF810012800.jpeg Hello! Mine is the same way. This random white stuff got into the tail light. Recently one of the taillights, from night to day got 3x more dirty.
    Did anyone find a fix to do at home?
    Here in Brazil there are people that remove the lens to clean the inside. When I do it I’ll share it here.
    the first picture is from today, looks horrible. The picture that looks cleaner is literally from yesterday.
  12. Animal Mother
    Animal Mother New Member
    Georgia
    Yep, I have the same exact thing happen to my taillights. All four taillights have it to some extent but my passenger top taillight had it the worst. It isn’t really noticeable on the others unless you really look closely, I decided to replace the top passenger light using an OEM taillight for about $140 for the part and I did the install myself (easy). The part number on the replacement taillight was different and I believe that would indicate a redesigned the original part, hopefully to prevent this issue from reoccurring. There is no indication of cracking or damaged to the removed light. My guess would be a seam failure that allows a tiny amount of moisture in.
