White smoke diagnosis help requested !
Discussion in 'Gen 2 Prius Main Forum' started by Ds001001, Nov 11, 2023.
  1. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    For my 2007 with182,000 miles I’m experiencing a weird white smoke event after long mountain descents. I live in Tahoe and frequently drive between north lake (6200’) and Reno (4500’) over mount rose highway (8900’).
    About a month ago at bottom of mount rose highway when getting onto 395, the first acceleration (after 15 minutes of coasting down the 4000’ drop) there was a significant amount of white smoke out the back. I dismissed it at the time as I was in a big group of cars and didn’t see it again until at the same spot yesterday when another large cloud of smoke came on the first acceleration. I tried to replicate it on flat ground and was not able to.
    Today when going back to north lake at the bottom of descent I turned onto an uphill side street and gunned it and got the smoke. After 3-4 quick starts the smoke doesn’t happen again.
    oil dipstick looks fine, no milky substance. Last oil change late summer didn’t notice anything. No milky substance on oil cap. I wasn’t plugged into odb2 so wasn’t watching temps.
    Coolant levels are full, the last time I added coolant was 2 years ago. Since 110,000 miles I’ve been burning about 1 quart per 3000 miles. I’ve ran 2 cans of BG EPR through it about six months apart and my last oil change only burned 1/2 quart.
    Is it possible that the long descent cooling exhaust that it’s water condensation ? Any ideas on what it could be?
    I have a buddy at his place in socal for a couple weeks where I can swap the head gasket, but have the time limit of when he’s there so semi rushed decision.
  2. Tombukt2
    Tombukt2 Senior Member
    13,579
    2,449
    Durham NC
    A one NZ with a head gasket leak at 180K yeah it's possible likely probably not last for some reason it's been overheated unbeknownst to whoever which I kind of doubt because you'd smell it more than likely and then it would be quickly downhill from there.
  3. PriusCamper
    PriusCamper Senior Member
    13,192
    5,340
    Pacific Northwest, USA
    You're either losing coolant (downhill) or losing oil (uphill) or both with those symptoms. Yet you say your oil and coolant levels haven't changed? And cars usually don't smoke when you're going down a mountain with little use of accelerator unless your brakes are failing... There's zero reason to blame it on a bad head gasket in a 2007 because they rarely have that problem. It's not water condensation either.
    How's the gas mileage?
    At this point only thing you can do is a thorough inspection of the underside of the car and engine compartment for anything that looks wrong, but other than something you think you're seeing in your rearview mirror you don't have anything wrong with your car.
    Is it possible you or someone else did some really extreme off roading and this is just large amounts of light, near white colored dirt and debris that was packed into the underside of the car?
  4. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Thanks for the input PriusCamper,
    The gas mileage is normal.
    The smoke has only occurred on the first couple accelerations after the long downhill and not during the coasting. Last occurrence I accelerated from stop with no one around and went 1/2 block, watched the smoke go up out and up via the mirror , stopped got out and watched it float away.
    check of oil and coolant again, all look fine and full. Last oil change was like 500 miles ago.
  5. PriusCamper
    13,192
    5,340
    The good news is that you are paying close attention... The bad news is without dash warning lights or other symptoms its too soon to say... When I face situations like this the best way to handle it is spend a few hours cleaning every nook and cranny of the car while making a list of every minor thing that can be fixed so when you do figure out what this problem is it's the last thing that needs attention.
  6. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    I forgot one piece of info, I drove the Reno side spot today fully warmed up, without the long descent, and no white smoke.
    Question, for checking coolant levels: if it does have a leak does it show up at the radiator cap, or can the thermos be low and top end of system can look full ?
    I think I will try on next Reno trip to have heat on max to keep ice running on the descent. My feeling is this has something to do with the cat cooling down and then asking for 2000 rpm acceleration right away. But that wouldn’t necessarily answer if there is a coolant leak as it could be a small drip that collects on the descent and ignites at once instead of one drip at a time.
  7. PriusCamper
    13,192
    5,340
    Cats only cool down on plugin hybrids and even then its not gonna create weird smoke... As for monitoring coolant level its not very easy on Gen2, but fill the reservoir up as full as possible so even just a tiny loss of coolant will be noticeable.
    The only time I've had a problem like you're describing was when I put a rebuilt engine in my Subaru and didn't replace the radiator hoses and one of them failed and leaked onto the exhaust manifold... But in a Gen2 Prius I'm not seeing how the same thing could happen.
  8. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    Always check the coolant level at the radiator itself. If you have any coolant system leak, the siphon to and from the reservoir will not work reliably. if at all.
    The fact you're mentioning the coolant thermos, does that mean you've drained the engine coolant system recently? If you had air trapped there that subsequently freed itself, then you could have a low radiator and a subsequent failure of the overflow system.
  9. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    I changed the 3 way valve 2 years ago and filled/bleed it after. I didn’t open the radiator cap since then until yesterday and it was full. I recently ran the heater and didn’t hear any gurgling in the system like I had when the water pumped failed and the shop didn’t bleed the system right under warranty late 2000s.
    dolj likes this.
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,661
    6,693
    Texas Hill Country
    Long downhills can fill up the hv battery and then engage engine braking with no fuel or ignition. Effectively a vacuum pump which can suck in oil from worn valve seals or rings. Then it burns off as a one time event.
    JohnPrius3005 and PriusCamper like this.
  11. PriusCamper
    13,192
    5,340
    Yes, I should have clarified that if checking fluid level at the radiator cap doesn't show a loss of coolant you can also try filling up the reservoir as full as possible so you can keep an eye on that as well.
  12. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Good thought, thanks for the idea, that gives a test point to do the descent in neutral so the forced ice spin in “D” above 72% SoC (iirc that’s the threshold, I don’t monitor SoC that often) doesn’t happen. In my 100,000 miles of mountain driving in this car I only use “B” when it’s snowing to help control speed, the 5000 rpm spin when battery full I burned multiple quarts in a month winter 2013 in Colorado.
    PriusCamper likes this.
  13. PriusCamper
    13,192
    5,340
    I bet you could test what Hill said by putting it in B on one day downhill and putting it in neutral on the same downhill on another day.
  14. dolj
    dolj Senior Member
    8,604
    4,366
    Probably not a good idea. Just fill to the F mark on the tank. There needs to be headroom to allow for the expansion of hot coolant.
  15. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Update, driven about 1000 miles since first posting this, before driving to Vegas for F1 I saw that oil on dipstick was 1/2 qt low (I guess when I checked it before, oil wasn’t settled?) Filled it and drove to Vegas it was 1/2 qt low again. Filled it before going to ridgecrest where my friend has car shop and oil level is still full about 500 miles later.
    So pretty sure issue is oil consumption and I’m seeing the smoke at bottom of mountain descent at first acceleration with ice.
    Now I’m Bleeding my brake lines, left rear is still dripping with new bleed screw and now brake actuator isn’t actuating and have abs vsc small exclamation point and brake dash lights on. Fun times in diy maintenance land.
  16. PriusCamper
    13,192
    5,340
    How did the experiment with using B versus using neutral at the bottom of a long downhill go?
  17. Desert
    Desert New Member
    Neveda
    Hello,
    I have this problem. Steep, Long downhill runs, hot or cold weather, not as bad cold. At bottom of hill, at take off, large plume of whitish smoke, for half a block , then purged. The HV battery has to be full. I have tried the experiment, of putting it into neutral and coasting as much as possible, to not let HV battery fully charge. This seems to work. With little no no smoke, at the bottom at stop, and then takeoff. It doesn't throw codes. No leaks underneath at all. No water/coolant in oil, no oil in coolant. It does go through some oil. Yet I'm on top of it daily. 310,000 miles, runs great otherwise. I was thinking, piston rings. However valve job should be easier. Never had overheat issue. Hardly ever top off coolant in either reservoir, check it all the time. I frequently run in Vegas desert heat highway speed 75 at 115°. Rings and valves explain oil losses. However, never smokes in city, or if HV battery is not full.
  18. rjparker
    10,661
    6,693
    Texas Hill Country
    When your battery is full the system does engine braking to save the brakes on a steep downhill. During this time the ignition and fuel is off. The engine then becomes a vacuum pump of sorts allowing oil to get past the bad rings and accumulate in the cylinder. At the bottom your engine starts (not just engine braking) and then burns off the oil in a white cloud.
    In neutral you have no engine braking but you could overheat the friction brakes.
    The engine needs to be rebuilt or replaced.
    Brian1954 likes this.
  19. Tombukt2
    13,579
    2,449
    Durham NC
    So then your smoke and your car and your tailpipe and all that around that area smells like oil after these events not glycol coolant... just saying You should readily smell the smell of the glycol or the oil burning like all the time It's like all over the back of the car not that you necessarily can see it on the rear bumper but maybe that too But the oil particulates are all underneath and around the tailpipe and hatch area etc not in the front of the car necessarily because you're going forward but you should definitely be able to smell the oil or glycol smell pretty much anytime you walk up near the back of the car It's a permanent smell that will stay until it's fixed generally something you don't forget if you've owned like old British Leyland cars like MG triumph Aston Martin etc you'll know the smell
  20. Desert
    Desert New Member
    Neveda
    Thanks RJ, I wasn't sure, my own brain thought rings only. I appreciate everyone who posts here. Now I can focus on Valves too. Just knowing there is vacuum and sucks the oil, this is why there is excessive oil loss on that downhill. With regular driving its about normal loss. Thanks for heads up.
    I was staying off engine braking because I thought it might be harsher on rings. Will now be the go to on downhills. Thanks again
  21. Desert
    Desert New Member
    Neveda
    Tombukt2
    Yes on the downhill event, when hv battery gets full, there is some excessive emissions, sometimes visible, but only after acceleration.
    If you accelerate, while downhill, hv battery full, you could see some smoke. The smell, yes, I find if you keep the windows up, the fresh air intake on climate open. You can avoid, burning oil emissions. If you accelerate during this event with battery full. Then more emissions come out. More chances of smell infiltrating vehicle. Partially because there is some Cabin vents, on both sides of the car in rear wheel wells. This helps vent the cabin pressure. However I think it allows emissions in. The HYbrid battery cooler vent, exits the cabin vent, just behind the 12 volt battery in wheel well. It doesn't take much for these vents to open and close. Especially at higher speeds. the hv battery cooler vent has about 1 1/2 inches of space between the end of it, and rear wheel cabin vent. Which could allow emissions from hv battery cooler vent into cabin, as well as tailpipe emissions, again this only happens when Hv battery is full. This could be through normal city driving. Light smells. Or during a full Hv battery downhill event, where you get a lot of smell. I tried covering the 1 1/2 in space, between cooler vent, and cabin vent in wheel well. Didn't seem to help. If you open the windows, even a Lil bit the cabin air will open, the wheel well vents, and this allows emissions in to some degree. This is why I don't open windows during full Hv battery events. I also open the fresh air vent on climate. If you leave it on recirculate cabin air. During the event. It just reticulated emissions also. It's kind of like if you left your rear cabin open while driving, or not closed tightly, those tailpipe emissions come in.
    Hope that helps
