Whiteline Lower Control Arm Bushings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Nov 3, 2014.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    My Gen III is currently at 95k miles, and the large rear bushing on the lower control arms have had small tears for some time.
    I have also been experiencing a rubber "crunch-like" noise from the right control arm. I have been able to silence the noise temporarily by spraying silicone lube on the bushing, but the noise returns after a month or so.
    While it is a bit subjective, the handling has noticeably degraded compared to when new.
    The Toyota-approved repair is to buy new lower control arms as the bushings are not sold separately. The cost is approx $175 per side.
    A friend of mine that services Nissan/Infiniti vehicles advised me to check with Whiteline Bushings, as he installs many of these with great success. And from a handling and durability standpoint, he finds them to be a signifiant improvement over the OE bushings.
    Sure enough, Whiteline sells both the inner front and inner rear bushings for our lower control arms. The part numbers are W53301 and W53302. I paid $35 for the W53301 and $105 for the W53302.
    I just ordered the parts and will be installing them later this week or early next. I will keep this thread updated with my results and with pictures of the old bushings.
  2. Spooled
    Spooled Member
    142
    26
    Concord, CA
    if i get some free time id like to come check this out you doing this in your driveway?
  3. The Critic
    3,193
    2,333
    CA
    I will be doing them at a friend's garage. I have already received the bushings and am just looking for a way to press the old bushings out. I have access to a hydraulic press, but I need to find the right adapters. If it becomes too much trouble, I will take the arms out and take them to a shop to have the new bushings pressed back in.
  4. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    You can also buy the bushes on eBay the rear is about £20 the front you can pick up for£7.54 If you search the part number 29SB602
    Just a question was it the right or left side ? Did you have to drop subframe or find another way round it?
    I would get the sway bar bushes changed if you still have issues
  5. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    In a pinch, and if you aren't concerned with the environmental ramifications, you can always burn out the old bushings (did this once in my younger days).
  6. ilovegirls
    ilovegirls Member
    178
    42
    San Diego
    Did you ever install this? Any changes in performance?
  7. The Critic
    3,193
    2,333
    CA
    No, the bushings were the wrong size. I purchased new control arms (with bushings pre-installed) from the Toyota dealer.
    Raytheeagle likes this.
  8. ilovegirls
    ilovegirls Member
    178
    42
    San Diego
    Thanks for the reply.
  9. Mendel Leisk
    42,343
    Is this a front suspension component, the highlighted one:
    And the circled bushing is the problem?
  10. The Critic
    3,193
    2,333
    CA
    No, the other one.
  11. Mendel Leisk
    42,343
    Ah, this?
    Moot point if you buy replacment arm. But something to check.
  12. The Critic
    3,193
    2,333
    CA
    Yep. Aftermarket suspension parts are pretty much garbage these days. If you want anything to last more than a few years, you have to buy it from the dealer.
    m.wynn, Raytheeagle and Mendel Leisk like this.
  13. ilovegirls
    ilovegirls Member
    178
    42
    San Diego
    I thought whiteline was a performance company that offered stiffer bushings.
  14. The Critic
    3,193
    2,333
    CA
    The Whiteline stuff works great. My comment was directed towards the Mevotech and Moog r-line products on the market today.
  15. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
    I remember seeing Harbor Freight had a bushing kit for under $50.
    You could search e bay also for a kit.
  16. Athos
    Athos Junior Member
    Ontario, Canada
    I put the whiteline bushings in my 2005 a few weeks ago. The car is very tight now. I'm very pleased.
    It wasn't hard but took time. The glue holding the old bushings had dissolved so I just knocked out the rubber. Then I cut a slot in the old bushing ring which allowed that ring to collapse into itself, shrinking its diameter. Then it was easily knocked out with a couple of hammer raps. The new ones had to be pressed in with my press but I had the right size in a monster socket and it pushed in easily.
    I probably saved $50 but I was more interested in getting quality bushings and reducing the carbon content of the repair. I figured, two hours extra work on the one side of the ledger and three nice benefits on the other- reduced carbon (shipping and manufacture), better bushings and a savings of $50.
    There was one other intangible. As a Canadian I am pissed that the Chinese are holding two Canadians hostage over the Huawei fiasco. They are also waging a trade war over this cutting their Canadian imports of Canola. Why should I support that? I think the Whiteline bushings are Australian. I'm pleased to do business with them.
    By the way, see my post #22 in the following thread.
    Changing Control Arms = Headache, Am Stuck! Need help | Page 2 | PriusChat
