Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I've found my car sits at 7/8 bars much more often than it ever did previously. It also barely uses the regen to the same extent.
    I'm guessing they've reduced regen and get the car to top off the battery during driving. Perhaps it's more gen2 now in the way it works?
    Economy seems slightly up, but then the weather is getting warmer so hard to tell.
    WE0H likes this.
  2. Alan Claver
    Alan Claver Junior Member
    79
    Central Pennsylvania
    Got mine done today. Scheduled it with my 6 month service and also some squeaks in the console that needed to be tracked down. Don't know how long they took as I left the car the whole day.
    Noticed no change in the operation. My dealer did say that they've had a number of 2013 Prius with a similar squeak - from the center console. Turns out two plastic parts touch under the gear shift lever - a little friction tape stops that.
    Still trying to get them to track down an intermittent buzz from the hybrid battery cooling fan under the vent in the rear right passenger's seat.
  3. Rupert B Puppenstein
    Rupert B Puppenstein Active Member
    261
    126
    North Carolina
    I think most of us didn't notice the difference the first day. I never got a letter or even an e-mail notification that my car was under the recall. I saw it on my online account. It took about an hour for the update along with an oil change to be completed. There is a definitely loss of power, the brakes feel different, and I don't know if it is related, but my dome lights wouldn't shut off a couple days ago. So, I had to shut the switch off. I have no idea if the update is related, but it does seem a bit odd. I haven't driven the car since, so I have no idea if the problem would occur again.
    You would think any update that Toyota did would have a goal to improve things, not decrease mpg.
    WE0H likes this.
  4. Mendel Leisk
    42,354
    I'm thinking the contrary, coupled with déjà vu from the last Honda Civic Hybrid (gen II) software update.
    Any software change tailored to reduce stress on the hybrid system is very likely going to reduce the use of that system, make the car rely more on the conventional components. And that's going to reduce mpg.
  5. bubbatech
    bubbatech Member
    153
    60
    Alabama
    I have detected absolutely no difference after the update. Mileage still ranges from 56-62 depending on ambient temperature.
  6. LlF
    LlF Junior Member
    42
    Canada QC
    i find the rattle on the rear right to be the removable trunk cover.
  7. jayrider
    jayrider Member
    163
    17
    southwest illinois
    Had the computer monkey shocked. oil changed-- 3 cups of Starbucks + carwash--- hour and 15 minutes -- $51 out the door with coupon.
  8. canta
    canta Member
    101
    Raleigh
    reported 4 days after done with the recall:
    Car behavior is changing a bit on regen during braking, acceleration and gliding :D
    overall I got better 3-4 mpg during my daily commute (traffic, Highways/Interstate/Locals)
    * during regen, hybrid is not charging constantly as used to be, It use Pulse recharging and more conventional brake at low mph (could be...10-15mph, not sure). oops brake pad life would be less than used to be.
    * I always use normal mode ( once for a while using power mode. Eco Mode is just a gimmick for me :p). Acceleration has some more (electric)power and flat after that. to play with this, I have to push the gas pedal more on a certain time, release, and glide a bit, than repeat again.
    some people do not like the update, but I do not mind since getting better millage. But pain in the nice person, Need to change my driving habit again.
  9. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    It is odd that there is such a drastic difference in reported performance and mpg impact after this update. I wonder how much is truly a difference as a result of the recall update and how much is just a psychological difference in our heads since Prius drivers are typically a little psycho when it comes to our cars..
    csp1971, macman408, kbeck and 2 others like this.
  10. Nutstoyou
    Nutstoyou Junior Member
    34
    Southern California
    Amen to that!!!
  11. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    After more driving I agree with that.
    I haven't noticed any performance or overall mpg difference though.
    GrumpyCabbie likes this.
  12. pmike
    pmike Member
    237
    81
    Central Florida
    I have never seen mine a 7/8 until the update, Central Florida terrain for a reference. The bars seem to function differently but I see no I'll effect.
  13. Mendel Leisk
    42,354
    I don't mind at all being called out, it would be nice if this is win/win. Still wonder though.
    WE0H likes this.
  14. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Got my notice today. Will have to schedule an appointment. Already the car has less power and sputters and misses. :rolleyes:
    m.wynn and h00ktern like this.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    You may laugh but I've noticed the car utilises the engine more. It's hard to explain but I wonder if the electric side took up more of the slack that it had previously been given credit for. Accelerating to over take is probably almost as fast but it is much noisier than it was as the engine seems to work harder and presumable the electric motor works less.
    I guess it depends on how well you 'know' your car or indeed how bothered or how much notice you take of the little things. If I hadn't have spent 10 hours a day in mine I doubt I would have noticed.
    WE0H likes this.
  16. WE0H
    WE0H Senior Member
    3,247
    528
    So far this week 1673.9 miles 42.9 mpg 57 mph average.
    Mike
    Somewhere on my phone ;-)
  17. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I think the mileage is the same after the recall. The only reason I don't seem to be getting quite the same is the pedal seems a bit more sensitve. So, I am having to get used to being lighter on the pedal than before. I think this will happen soon.
  18. ETC(SS)
    7,565
    They got Goofy. :eek:
    Replaced it with "Sticky", a 200? white Malibu with 150K miles, VERY grubby interior and too many maladies to list, which is why it's the Hangar Queen.
    I never thought I'd ever say this.....but I want my Prius back! :(
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Eh?
    Note to ETC: Never mix forums and alcohol (y) :whistle: :D
    WE0H likes this.
  20. ETC(SS)
    7,565
    We're at GMT minus 6.
    It's a little early for all that, and I make it a practice never to drink and post. ;)
    I get into enough trouble POSTING when I post.
