Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It sounds like you engaged the hill holder.
    Next time press the pedal more gently.
    sfv41901 likes this.
  2. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    My opinion is that all the conflicting responses are the result of a full and total ecu reset, which means everyone's cars are "learning" all over again, from square one.
    jdcollins5 likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Exactly, that's why reports of achieving higher mpg immediately following the update is meaningless. The ECU has to reset and relearn air to fuel mixture settings, O2 sensor calibration, etc.
    SCH-I535
    Chuck65 likes this.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I just received my letter yesterday. I will probably try to schedule an appointment next week some time.
    In the meantime I have found the listed acceleration time of 0-60 mph in 9.8 seconds in the 2010 Prius Product Information manual. On 3 different attempts I have averaged about 9 seconds, 650V boost voltage and a range of 120-140 battery amps.
    It will be interesting to take these readings after the update.
  5. Chuck65
    Chuck65 Member
    Swanton Ohio
    I got mind updated early this month,letter today, i took test before the update.
  6. Mendel Leisk
    42,355
    You're really "taking a bullet" for the Prius community, at the expensive of your mpg, lol. I couldn't bring myself to do that.
    I had my first real opportunity to drive ours post-update, apart from driving straight home after the appointment. Impressions:
    1. Acceleration up steep hills seems a bit more of a struggle. So heavy acceleration is maybe curtailed slightly?
    2. The car seems to slip into and stay in electric-only propulsion more readily.
    3. On the whole, seems steady, solid, no real complaints.
    My wife drove it downtown to meet me and the in-dash liters/100 km was at 4.4. When we got home with me driving I'd managed to coax it down to 4.3. This is with half a tank gone since last trip meter reset.
    This is very good for us, this time of year, on the snow tires. The weather's been warming (have to get the snows off), so that is a factor.
  7. jdcollins5
    5,131
    1,346
    Wilmington, NC
    By test do you mean the 0-60 test? If so, what are your before and after results?
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yea, I do not mind wasting a little gas to gain some "before" performance data.
    I kept waiting for someone else to post their results so I would have something to compare. I was really hoping somone would do the before and after. It looks like Chuck65 may have done this.
    I am surprised that with all of the members reporting having the update completed, no one has reported any real data from SGII, Torque, Engine Link, min-VCI. Everything has been subjective.
  9. canta
    canta Member
    101
    Raleigh
    Received recall letter yesterday. I opened the letter and saw "Safety Recall" on right side of the letter.
    Reread many times, this seems Toyota will not fix the future problem that related with this safety recall, if software update is not done.
    something different with Hyundai (during owned Hyundai Cars). they did major safety recall, and skip software update that caused Engine light went off(light on) . I talked to Hyundai dealer that not eagerly to do software update since this was not mandate by Hyundai HQ.
    At the end, they fixed with the update, after engine light went off on my car without cost.
    this was a hassle, they(Hyundai) should fixed/updated first recall than dealing later on.
    well, I am living in parallel world where not sync-up once for awhile :p.
  10. PearlBlizzard
    PearlBlizzard Member
    75
    31
    So Cal
    With all the chatter in this forum, I could not find definitive before and after information on acceleration (0-60 or dyno horsepower tests) or mileage. Both of these are easy to ascertain. Simple 0-60 mph android and iphone apps that auto start on acceleration can be used before the update and after, tested on various roads with similar weather conditions. For mpg, forget the dash readout that overstates mileage. Fill the tank, zero the tripmeter and check the mpg on several subsequent tank refills. All this subjective conjecture is pointless. Anyone???
    If everyone has results that indicate slower acceleration after the recall, there is grounds for a class action lawsuit; the vehicle will have wrongly stated net hp and 0-60 times, and this materially effects our enjoyment of the car. IMHO, from a casual glance, the correct (albeit more costly) fix is to replace the failing caps with ones that can endure the driving conditions better instead of simply detuning the car to overcompensate.
    WE0H likes this.
  11. ptn
    ptn Junior Member
    24
    Orange County, CA
    Got my recall done today. When I got my car back, it felt the same but smelled funny.. o_O oh that's probably the stench left by the mechanic who sat in my car and left it on to install the update. I noticed the cap to my 12V car lighter plug was left undone and mpg drop with the battery drained when I left it to them full.
    Or they just took it around for a test drive... Well it's all said and done. 5k maintenance service with EOE recall done in under 3 hours.
  12. crabbyman
    crabbyman Member
    79
    30
    I used Torque app and got between 9.8 and 10 second 0-60mph on my three tests. I didn't test any other aspects but let me know which ones you guys want me to test and I will.
    Former Member 68813 likes this.
  13. PearlBlizzard
    75
    31
    So Cal
    Was this before the update? If so, please post after the update. If afterwards, without a before the test is of little help. Comparing to product info does not have the same conditions.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    If you can monitor HV Battery amps and Voltage after Boost while performing 0-60 tests. After the update we can perform the after tests for comparison.
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I got my letter in the mail today......3 weeks after I got the recall done
    VS980 4G ?
  16. xliderider
    8,140
    3,280
    Honolulu, HI
    My letter came yesterday. Scheduled for next Friday.
    SCH-I535
  17. WE0H
    WE0H Senior Member
    3,247
    528
    Was my rental still learning 2000 miles after the update???
    Mike
  18. xliderider
    8,140
    3,280
    Honolulu, HI
    Mike, we were referring to all the other posts referring to mpg impressions immediately following the update. ;)
    I believe the overall mpg would decrease, but there's been a multitude of posts claiming improved mpg. Probably more to do with the warmer weather.
    SCH-I535
    WE0H likes this.
  19. Former Member 68813
    3,524
    983
    US
    Why don't you do it?
  20. walter Lee
    1,126
    376
    Maryland
    I got my ECU software updated last Saturday when I did my oil/oil filter change at about 45,500 miles at the Clarksville Maryland Toyota Dealership. I had a 8am appointment. I got in line at about 7:45am. My 2010 Prius was ready at about 11 am. The Service Specialist was told that my OE Yokohoma Avid tires still have enough tread for another 5000 miles ( I was thinking of replacing them with a set of Michelin Energy Saver All Season Tires). I haven't notice any big changes in the way the car handles so far. As far as fuel efficiency - I'm getting about 53 mpg this winter which is about normal for this time of the year when it is this cold.
