Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. crabbyman
    crabbyman Member
    79
    30
    These are before updates. That is why I was offering my info and seeing what info people wanted. I have my 5000 mile service already and dont know if they will do the update also even though I may not request it yet.
    I don't know the break in period but my Fuelly is listed below so you can see my mileage results so fare.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I would like to know your source for this information.
  3. RRxing
    RRxing Senior Member
    2,562
    1,841
    NEPA
    It is explicitly written in the letter sent by Toyota.
    WE0H and xpcman like this.
  4. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Mine was done today. Took 45 minutes including the car wash.
    Not certain if my car, an early 2010 (July 09) would have a greater delta in terms of changes that the firmware updates compared to a newer Prius like a 2013+, but I'd have to repeat that for the most part the only change that I 'think' I can attest to is that the transfer from ice/electric may be more refined; less of a noticeable shift. Smoother in better words, so all is good.
    Just a piss me off event in the fact that my satellite radio/nav traffic trial seems to have ended while the car was in for the update. Purely coincidence but my first thought was that my radio had been reprogrammed with the update. I paid to subscribe with more music and traffic and my feathers are no longer ruffled. Seems that Sirius/xm should have stopped my preview before now, I really thought it was some kind of deal with a lifetime feed but no. I did not know until after the fact. :confused: Was nice while it lasted and if I work out the extended free period into my new yearly bill the cost seems fair for the amount I enjoy the services.
    They kept the power supplied to my car during the reflash. Before calling Sirius/xm to correct the situation with loss of service, I removed a battery cable myself to do a reset. I am of the opinion that many of you had this done, and that it does clear old data and I can look forward to better mileage now with warmer temps. If the sat/nav service had not been interrupted I'd likely have not cleared data by disconnecting the battery and simply rode things out.
    Hope your recall goes as well as mine did, hats off to the tech and service manger at Destination Toyota up here.
    Roland
  5. xpcman
    1,302
    295
    Thanks. I haven't seen the letter yet. I bought my car off the second boat to land in California, early June 2009. They must be sending the notice letters out totally at random.
  6. WE0H
    WE0H Senior Member
    3,247
    528
    It is in the envelope we all got for the recall. If you haven't received it yet, you will read it when you do.
    Mike :)
  7. osidecruzr
    osidecruzr Member / BB #256
    30
    So Cal
    I had mine done last week with my 15k service. Did not notice any difference. The service and recall were done in less than an hour.
  8. crabbyman
    crabbyman Member
    79
    30
    I hooked up the OBDII apdater this morning and let it load all the sensors..I did not see either of these as choices in the graph. I may be reading your request too literally. Where should I look for these meters or readings at?
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    What are you using to read and monitor the OBDII data; SGII, Torque, Engine Link ?
  10. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    If it's any consolation to us Prius owners, I just heard the Nissan Leaf has a recall now too. It's potentially more serious as it deals with the airbag not deploying.
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I obviously missed the humor in your remark the first time that I read this :)
  12. crabbyman
    crabbyman Member
    79
    30
    Torque paid version
  13. jdcollins5
    5,131
    1,346
    Wilmington, NC
  14. crabbyman
    crabbyman Member
    79
    30
    Got it..downloaded it..installed it. I got the voltage after boost as a gauge but I still don't see the HV Battery amps that someone was requesting.
    I see..
    HV battery charge control
    HV batter discharge control
    HV battery intake air temp
    HV communication open
  15. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I believe it is listed as IB.
  16. crabbyman
    crabbyman Member
    79
    30
    Not seeing that one either..
    I see "Auxiliary battery voltage"..."Batt block max voltage".."engine Kw a wheels".."SOC Max" as questionable ones
  17. Sumedha
    Sumedha Junior Member
    52
    Colombo, Sri Lanka
    I got mine done couple of days ago and I do not see a noticeable difference in the pulling power.
  18. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Try this:
    Name,ShortName, ModeAndPID, Equation, Min Value, Max Value, Units, Header
    Power Resource IB, IB, 218A, (A * 256 + B) / 100 - 327.68, -200 ,200, Amperes, 7E2
  19. crabbyman
    crabbyman Member
    79
    30
    There is one called Power Resource in my list. I will give that a try. Feel stupid now..
  20. crabbyman
    crabbyman Member
    79
    30
    First tests..
    50-60 amps
    600-650 volts
    0-60 was 10.6 seconds tonight
    WE0H likes this.
