Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. Mendel Leisk
    42,271
    Just like Honda, eh Harold?
    HaroldW likes this.
  2. J_w73
    J_w73 Junior Member
    67
    For those of you that are saying that your MPG went down after the recall, how are you checking your mpg? I just had the software update done so that I could register my car in California. I will say that it does seem that the "cons. MPG" that shows on the HUD is reading a little lower than it used to, but I think it is just more accurate. My HUD MPG would always show 45-46 MPG, but when I measured it against the miles driven and the amount of gas I used, it would always come out to about 42 to 43 MPG. Now after the software update my cons. MPG on the HUD is showing around 42 to 43 and is matching what I get when I fill up.
    I do notice that the fan to cool the hybrid battery seems to run a lot more often now. Before it would only come on when the outside air temp was really hot. Now it seems to come on and run at all times while driving.
  3. JC91006
    16,933
    8,643
    sounds like you are headed for a replacement battery soon. It should only turn on when the modules are overheating.....a sign of failure
  4. Mendel Leisk
    42,271
    Fan will run with normal battery. There's 6 speeds I think. Monitoring ours with ScanGauge I've seen speeds 1 thru 4. But I've yet to hear it, so I'd think if you're hearing it's running at speed 5 or 6. Or your hearing's more sensitive, lol.
    If it's running fast enough to hear, maybe not a good sign.
    To determine mpg I'd just calculate, tank by tank.
  5. Tideland Prius
    16,672
    There’s a new pending recall for this recall. Affects both 2010-2014 Prius and 2012-2014 Prius v.
    Mendel Leisk and Bay Stater like this.
  6. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I recently got this recall notice too.(n)
    Guess we'll have to wait for Toyota to design and implement their remedy. :whistle:
  7. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    I also received that notice from Toyota. Had my service done today and asked about it, but the advisors' screen showed no outstanding recalls. Must be due to the lack of a remedy as yet.
  8. Tideland Prius
    16,672
    Yeah that notice is to let us know that Toyota is working on a fix. There’s no remedy yet.
    Bay Stater, Merkey and Mendel Leisk like this.
  9. crabbyman
    crabbyman Member
    79
    30
    Makes you feel all warm and cozy, doesn't it?
    RMB and Mendel Leisk like this.
  10. ChapmanF
    18,960
    Remedy announced December 20th. More info here for liftback and here for the Prius v.
  11. crabbyman
    crabbyman Member
    79
    30
    So I was going to do a new Torque measurement before I go to get my new J0V recall done.
    I booted up torque and I cannot find most of the meters I used before. Any idea why?
  12. ArtAtlanta
    ArtAtlanta New Member
    Atlanta GA
    Recently had the software recall done on my 2012 Prius V. Never had any problems with this car before. Driving 5 weeks after the software install, the Inverter Fails.
    Getting quoted very high prices on repairs.
    Anyone else had failure after the software install?
    Grit likes this.
  13. Prieth
    Prieth Junior Member
    17
    NM, USA
    Didn't they extend the warranty on the inverter to 15 years?
  14. Mendel Leisk
    42,271
    How many miles on it?
  15. 88skisupreme
    88skisupreme Junior Member
    Austin, Texas
    I'm just now looking into the recall, was there ever a second recall?
  16. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    I did my recall 2mo ago.. Software updated make the ICE stay longer on every time turn off and turn on the Engine. Even engine has 20 min drive and Engine Coolant has 170 degree F. Each time shut off engine for pickup stuff less than 3min and Turn on engine again will take 2-3 min can be switch to EV mode.
  17. 04priusnow
    04priusnow Active Member
    345
    201
    im behind in recalls since i still need this software update and i need the air bag brackets fixed
    Pixel 3a XL ?
  18. 88skisupreme
    Austin, Texas
    the Prius is my wife's car, it had a few bouts of phantom acceleration and she said it nearly stalled once at a light. Hopefully this update clears it up. I plan on having the inverter checked out at the dealer before the warranty is up on the Hybrid system.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No code no check - dealers. Don’t be surprised. The bad ones will check it quickly with an eye and bill you an hour for it.
