Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    Yeah.. Same as on my last recall dealer said, "NO CODE, NO CHECK" They don't get paid by Toyota and No Free lunch
  2. priusrat
    priusrat Junior Member
    CT
    I think the same thing has happened with mine. No problem for over 100K miles, seven years. Had the software update done (while I had it in to change all the fluids at the 105-110 K checkup), and a few weeks later, when I turned on the car at lunchtime, it went into limp mode. Turned it off, then a few hours later turned it on, (no limp mode), drove to nearby AutoZone, where they checked the 12 V battery. They said it was fine, but that the car wasn't charging it. I read up, and I bet it's the inverter. Local dealer looked it up, says that they need to check to see if it threw a particular error code, and that if it did, Toyota will replace the inverter for free.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What kind of warranty did the dealer say it was covered under?
