Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    My longer commute today showed MPG at least as good as I observed on previous similar commutes, perhaps a bit better. I'm seeing the battery level behave the way it did before the recall service (not staying near full), and I'm also noting that, when in ECO mode, the instantaneous MPG level goes down linearly as the HSI status bar passes the mid-point. Yesterday, I was seeing a very sharp plunge in the instantaneous MPG as the HSI bar passed the mid-point when the vehicle should have been warmed up.
    The statement by PriusinParidise about the vehicle having to re-learn the characteristics of the traction battery makes some sense, and for those that see a MPG drop after the recall service, I'd recommend that they try a 1 hr+ drive on a freeway then re-evaluate their MPG performance.
    WE0H, The Critic and paprius4030 like this.
  2. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    Ours is scheduled for tomorrow. We get a free loaner.
    We don't care about MPG, it's plenty good.
    glen68 likes this.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Thanks for the update, it makes me feel better about getting mine done.
  4. dhowlan
    dhowlan Junior Member
    2014 Prius Plug-in
    I just discovered I had never registered with this group. I've corrected that oversight and have a question.
    How common is it to need the inverter replacing after having this update? My wife's 2010 Prius V has been at the dealer for I think a week and a half. They said flashing the software update killed the inverter. They also said this was supposed to be rare, but that they had 3 other Priuses in the same state. This seems like a lot to me. The inverter seems to be hard for them to acquire, so we have a loaner for however long this takes.
    Anybody go through this and have a guess as to how long it will take to get the inverter?
  5. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    That does seem rather excessive. Once fixed, I'd look elsewhere for another dealership.
  6. Bwrx
    Bwrx New Member
    Moved post to different forum
  7. JGI
    JGI Member
    77
    46
    I noticed the same thing on mine. It's a LOT smoother now when going from a full stop to cruising speed and I don't feel the combustion engine turning on anymore like I used to.
  8. JGI
    JGI Member
    77
    46
    Ok, I guess I spoke too soon. It's now been 1 week since the update. The battery SOC "always full" only lasted a few days and now it's actually worse. Now the battery seems to go down to 2 bars left more often than not, especially on ECO mode. My MPG is also in the crapper now. I've gone from 40mpg to now only 37mpg average. Not sure if the update has anything to do with it, but they also corrected my tire pressure down to 35/35 (from 65/45) so that may have something to do with the mpg hit.
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I just had mine done at Maita Toyota in Sacramento. With an appointment, it took about 1hr 20 min from the time of service write-up to the time of departure. My advisor was outstanding and it is clear that this dealer is a very well-ran organization.
    WE0H likes this.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes! Tire pressure that low can make a huge difference 3-5 mpg. Make sure you check side wall on tires for max psi and do not go over that number. Also run 2 pounds less psi in rear tires helps with stability.
    snead_c likes this.
  11. marjorie030758
    marjorie030758 Junior Member
    Colorado
    I had my update done this week. About 2 hours, no noticeable difference with the car. Yes, my online toyota record shows that I had the update done.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Has anyone actually gotten the hard copy letter from Toyota?
    I told myself I'd just wait until it came. Still waiting.
  13. bisco
    52,895
    i'm getting concerned about my transistors.
    m.wynn likes this.
  14. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    No letter yet. I just went to Toyota dealer and have them update the software, no need recall note or letter.
    elementnomore likes this.
  15. nedear88
    246
    142
    65PSi in the front tires? It's WAY over the tire's cold pressure limit! I have 17"wheels and tires and all tires at 33 psi, after the software upgrade and about 2 weeks of ECU re-learn, now my "constant MPG" read 49-51 on my 2nd fill-up. This is a good number and car run so much more responsive than before even at ECO mode, I usually drive at NORMAL mode. I'd say the software upgrade is a plus.
  16. The Electric Me
    9,083
    5,801
    I know you don't need the letter, just want to know if anyone has gotten one yet. I did not want to be in the first wave, so I thought I'd just wait until I actually got the letter.
    I'm guessing nobody has gotten the letter?
  17. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    No letter for me. I have been busy and haven't tried another dealership. I'll get to it soon.
  18. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    No letter and no update yet. I figure with cold temps, it's not likely to be a problem.
    A few days ago, my '12 Ridgeline coasted to a stop with CEL and another indicator lit. The truck restarted and a dealer corrected the problem. The next morning I asked my wife whether I should drive the truck that coasted to a stop or the car that has the recall for the same type of issue. She wanted me to drive her Fit, but I took the Prius.
  19. ChadInOKC
    ChadInOKC Junior Member
    46
    Moore, OK
    Did mine Friday, took about 50min and I got a free car wash. No battery disconnect.
    iPhone ?
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    They are talking about your car! :whistle:
    WE0H likes this.
