Who is getting the Gen 5 integrated dashcam?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Gokhan, Apr 6, 2023.
  1. thnok
    thnok Member
    122
    44
    2023 Prius
    Correct me if I'm wrong but as much as I agree with your comment. I also felt Toyota put the "integrated" word just to show it blends in visually and in terms of wiring as well. I agree it's not the best thing in the world but seems like thats the case. I'm also debating getting the integrated or a 3rd party dash cam, only thing I dislike about a third party is the wires sticking out.
  2. Gokhan
    Gokhan Senior Member
    6,717
    2,672
    Paramount CA
    It is integrated into the electrical system—it detects the ignition, so you don't need to remember to turn it on. It also has an impact sensor.
  3. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    If I am not mistaken, every dashcam with wire harness does exactly that as well.
  4. Gokhan
    6,717
    2,672
    Paramount CA
    If it comes with a wire harness with both the ignition and nonignition power connections like for a radio, it can do that.
    However, the wires will show and the camera will look like an added gadget instead of an OEM camera that looks like a part of the vehicle.
    So, it is a compromise between video quality and looks/ease of installation. In that sense, it is no different than replacing the OEM multimedia head unit with a fancy Pioneer head unit or the OEM speakers with fancy Pioneer speakers.
  5. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    IMHO, it does look fairly clean.
    The only pain is to move trim around the window to lead the cable. It can be done with hanging wires into a "lighter", but considering a lot of people are buying dashcam to watch a parked vehicle as well, it is worth the effort to use a hardwire kit.
    Edit: It seems I am not able to upload image :-D I am certainly doing something wrong.
    URL it is then.
    https://kamery-viofo.cz/wp-content/uploads/2023/03/Viofo_A-139-PRO-008.webp
  6. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    This is a fair point. It is easy to install (just pay for it), looks nice and no wires.
    10 years ago, this would likely be what everyone thought of when they hear “integrated”.
    Now though, Toyota needs to manage expectations. Some cars come with a ‘dash cam’ that uses multiple cameras (4). They automatically record if someone comes near the car.
    Videos are available live through an app, or can be viewed in the car. I believe, using the app, the owner can actually speak and be heard.
    This is what “integrated” means to me, as well as a growing number of other people.
    Toyota needs to be careful to not oversell.
    #26 Zythryn, Apr 9, 2023
    thnok and JoeBlack like this.
  7. thnok
    thnok Member
    122
    44
    2023 Prius
    Exactly! In my experience, Tesla does it well since the user can easily access all the cameras around the car easily. I don't understand why we even Toyota needs this extra dash cam when the car is already surrounded by cameras, they just need to enable access to the users.
  8. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    It’s too bad the digital rear view mirror isn’t an option for all the trim levels, too.
  9. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I'd probably go for one if it doesn't involve wiring. Otherwise I would go aftermarket.
  10. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
    I found this website selling power adapters to make third-party dashcam looks integrated but I'm not sure if this will work for the new Prius.
    https://dongar.tech/
    thnok likes this.
  11. PriusPeep
    PriusPeep Member
    127
    79
    New Jersey
  12. David Mk.2
    David Mk.2 Member
    61
    61
    Connecticut
    2023 Prius
    I think your phone and your computer already spy on you way more than anything in your car does :)
    If you're going to be naked though you'll probably not want to do that while inside a car with an interior dash cam. Does the Toyota integrated dash cam film the interior too, or does it only capture events in front of the car?
  13. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    Toyota dashcam is only front facing, but there should be inside camera for alarm and jam assist functionality that could save images, sound or maybe video.
    thnok likes this.
  14. thnok
    thnok Member
    122
    44
    2023 Prius
    I noticed the Prime 5th gen seem to have an internal camera/something in those lines for the traffic jam assist feature.
  15. qdllc
    qdllc Senior Member
    1,377
    400
    As much as I’d like an integrated unit, quality matters. I would first consider installing the following.
    https://www.innovv.com/innovv-k5-dashcam
    It’s designed for powersports, but if you can find a way to install it, you get front and rear cameras with the DVR unit capable of being installed where it’s more sheltered from heat/the elements.
    I have the old K2 version, and the only down sides it had was (1) the integrated microphone is fairly poor while the bike is running…later models had an external microphone, and (2) it had issues making smooth front-facing video when the image was cluttered with too many changes (i.e., driving through a grove of trees). The second was solved by a firmware upgrade made by an enthusiast on the INNOVV message boards.
    Most dashcams I’ve seen have sketchy reviews…most all for the same reason…they can’t handle being in direct sun. If they don’t make the unit easy to install and remove, many don’t last long.
  16. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    TBH, that probably is the issue of reading bad reviews, like those on Amazon recommending Dashcams with often fake specs - like 4K on Dashcams that do not even use 4K sensors etc.
    Something like Viofo A139 will have better image, optional external mic as well, remote button to start the recording, and it is even considerably cheaper.
    There are ton of fake review because people do not know what to buy, what to look for - a lot of them see the sticker 4K, pick the cheapest rebranded one, and are done with it.
    There are actually a lot of videos and articles mentioning this issue.
  17. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    I added it to my XSE just in time pre-build. I was considering the Ring Car Cam with 2 way camera and parking mode, but mediocre reviews.
  18. thnok
    thnok Member
    122
    44
    2023 Prius
    I got the VIOFO dash cam 139Pro. But I’m considering returning it to switch to the integrated dash cam. It was fairly easy to hookup to the wiring which was close to the Toyota sense/radar system and with the Dongar adapter.
    annoying part is to fix the camera that’s why I’m considering the integrated camera.
  19. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    I have to agree. Not so much the quality but the features for the price. I UNinstalled mine and installed a Viofo239 Duo in its place.
    Anyone want to buy a little used dashcam from a 2023 Prius?!?!!
  20. Hammersmith
    Hammersmith Senior Member
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Welp, I only had partial success with my installation. I decided on the Lexus version of the dashcam so I had a big black button instead of a big red one. I was very careful with the placement of the template on the windshield, but either I misunderstood something or the Lexus version is slightly different than the Toyota version. There's an extendable section that covers the wiring and hooks into the headliner, but mine is way too short to reach. I plan to fix it at some point when I can get a replacement adhesive patch, but I ran out of daylight.
    The other minor negative is that I have to use the Lexus dashcam app instead of the Toyota(I was hoping the Toyota app would recognize it). But that's not a huge deal since the apps are identical except for color and it's not like the regular Toyota app can run the dashcam anyway. I will need two apps to run the car regardless(Toyota car + Toyota dashcam or Toyota car + Lexus dashcam).
    A pic of the trouble spot: (Maybe @HoustonEvolution can tell me if their cover was longer or if my installation is wrong.)
