WHO TO BUY MODULES FROM?? I need 5???
Discussion in 'Gen 2 Prius Technical Discussion' started by Anthony Park, Mar 23, 2017.
  1. Anthony Park
    Anthony Park Junior Member
    37
    Arizona
    So I need 5, maybe 6 modules. i had a guy on ebay who sold great modules for like 35bux... but now he has one listed for 999.99 dollars. uhhhhh no.
    I need a great price and consistent reliability... doesnt have to be on ebay. who would you recommend?
    Thanks!!
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    What kind of "modules" exactly ?
    I suspect that you mean individual battery cells and a quick search on here should find some sources that have already been discussed.
    If you have had 5 battery cells go bad already, now long do you think it will be before more fail ??
    Hint: Odds are, not too long.
  3. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    No actually the OP is quite correct, he means modules. A Prius II battery consists of 28 modules that contain 6 cells each; for a total of 168 cells that make up the battery.
    In addition each pair of modules are grouped into blocks (14 of them) that are monitored by Techstream.
    #3 dolj, Mar 23, 2017
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    I have modules.
    But if you need 5 that seems like quite a bit more than usual.
    Feel free to contact me directly.
    Anthony Park likes this.
  5. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Don't buy modules off ebay, chance of getting bad ones again is very high........buy them from this guy ^^^^^^^
    I also agree though, if you need 5 modules then heat/usage has probably killed your pack so you many want to look into a complete rebuild or replacement.
  6. Sam Spade
    2,036
    1,024
    2017 Prius c
    Except that the car may also have OTHER things that are called modules.
    He should have specified BATTERY modules.
    Andyprius1 likes this.
  7. JC91006
    16,936
    8,647
    I think everybody that read this post knew he wanted battery modules. Even you knew without him telling you specifically its battery modules.
  8. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Changing modules, especially 5 of them, is kind of like playing whack-a-mole. It will fix the problem until the next one fails. It's best to either replace the pack with a new or reconditioned one, or to recondition it yourself. Once you do the reconditioning, you may find that you need more than 5. It's usually only 1 or 2 that fail. Whack-a-mole is OK if you enjoy pulling that battery out and admiring it on your workbench or if you absolutely don't have any other options because of limited funds.
  9. Anthony Park
    37
    Arizona
    i purchased the prolong system and installed it along with the 7 i ended up replacing. i will be reconditioning the battery every quarter or so. hopefully thaT will keep the battery off my bench for good.
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Could you expandl on this type of maintenance? Cost, time, ease of repair, etc.
  11. Anthony Park
    37
    Arizona
    i'm no expert on the prolong system, but if you are doing a battery repair/replace anyways it adds exactly 3 minutes. The harness is positive/ negative attached where the big orange from the car attach to the battery, and 2 white plastic clicks to install the fan harness.
    thats it. the rest of putting your car back is normal. Prolong does a good job of explaining the rest. The idea is that once a quarter or so you charge, discharge, charge and rebalance your pack.. doesnt have to be in one sitting either. They do a great job of helping people avoid the rc charger messy nightmare. This seems infinitely easier and less hassle.
    is it worth 400.00? maybe not, especially if you like having tools for a multitude of things. but this seems as hassle free as it gets.
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Anthony. That's a trick that I've seen several ebay sellers use when they have zero stock on an item. Instead of removing their listing they prefer to just put a ridiculous price on it instead. So in this case I would read that $999.99 as code for "none currently available" from that guy.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    Even if "for good" means something short of forever.......
    It is HIGHLY unlikely that all of your time and investment will really change anything long term.
    It just postpones the inevitable. NO battery lasts forever, no matter what you do to it.
  14. bisco
    52,831
    what the point?(n)
  15. bisco
    52,831
    where did you wind up getting modules?
  16. kkeane
    kkeane Junior Member
    72
    San Diego
    You can buy complete reconditioned batteries for around $1400 or so with 3 years of warranty. Spending $400, plus buying probably as many as 28 battery modules in the foreseeable future, plus putting in all the work, plus ending up with a battery with very unbalanced modules, doesn't seem to be a great deal.
    I also suspect that if the Prolong system works at all, it would only extend the life of a *new* battery pack. Once a battery cell or module is work out, it is pretty much dead for good. The actual failure is, as far as I understand it, a one-way chemical reaction that cannot be reversed electrically.
    If that wasn't the case, this prolong system would be very popular with laptop owners.
  17. kkeane
    72
    San Diego
    I think you may have a fundamental problem; the supply of these modules is likely to dry up. In the past, these modules came from wrecked fairly new cars. But today, even the youngest Gen 2 Prius are eight years old. Those on the road are either already on their second battery (often with refurbished cells), or the battery pack is about to die.
    I vaguely recall reading that so far, only Toyota/Panasonic are permitted to make these modules, but that may be due to some patent protection that is about to expire. If that is true, we may soon see third-party companies making compatible *new* battery modules. But please don't consider this as fact - it's a mix of rumor and speculation.
  18. dolj
    dolj Senior Member
    8,640
    4,391
    Your theory just shows you don't have a very good grasp of the reconditioning process. If you had to replace more than 3-4 modules, it is likely you would need to look at a replacement battery of some sort, whether that was a salvaged (better option) one or a reconditioned (worse option) one.
    It is certainly better to start the earlier than later, but you can get good results, without having to even open up the battery (one of the attractions of this option), as long as your HV battery is not "on death's door".
    Laptop batteries are typically Li-Ion, a totally different beast.
    #18 dolj, Apr 5, 2017
  19. MTL_hihy
    536
    261
    Maritimes, Canada
    I find that if you ever need to buy a salvage battery you are best off getting a low mileage one from a rural very cold climate (AK,ID,MI,MN,MT, etc) and have it shipped to where you are (esp if you live in hotter states). Heat kills these batteries as does city driving (confirmed through testing) so the chances of getting another one going south (even if they are lower mileage) is far greater at southern salvage yards. The one I got for my Highlander was from an 06 (mine is an 09) with only 40k miles on it when wrecked and the battery is literally functioning like new after just grid charging with the Prolong setup.
  20. Sam Spade
    2,036
    1,024
    2017 Prius c
    Was that directed at my post ??
    My point IS.....that batteries operate on a chemical reaction cycle.
    Mainly because the reacting materials are not absolutely pure, some contamination works it's way in over time and the relative concentration of the reacting chemicals goes down........or the chemicals are "used up" when undesirable compounds are formed.
    Thus, there really isn't anything you can do to "rejuvenate" a battery cell without taking it apart and replacing the reacting chemicals with fresh stuff.
    Manipulating the charging and discharging by applying various external voltages to the weakening cells might APPEAR to bring them back to life, that is mostly an illusion and is at best short lived.
    Thus, when enough cells start to fail so that it is obviously AGE and not just manufacturing flaws, replacing them a few at a time is just wasted time and effort and money in the long run.
