WHO TO BUY MODULES FROM?? I need 5???
Discussion in 'Gen 2 Prius Technical Discussion' started by Anthony Park, Mar 23, 2017.
  1. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Really ??
    I think he is much closer to the truth than YOU are.
    A battery cell that is worn out because the chemical processes are used up is NOT recoverable by any kind of "reconditioning".
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Have a look at this article and then decide if you haven't changed your mind.
    BU-807: How to Restore Nickel-based Batteries – Battery University
    That's where this little gadget helps alot.
    Prolong Battery Systems. Extending the life of your hybrid. – Hybrid Automotive
    Raytheeagle and bisco like this.
  3. Anthony Park
    Anthony Park Junior Member
    37
    Arizona
    Ok soooo I don't understand all the naysaying around here. I just replaced 7 modules actually, 6 of which came from a forumite TMR-JWAP out of a recently wrecked 2013.
    Now that the bad modules are out, lets be real for a moment. The last time I replaced two modules and drove almost 40000 miles in 8 months b4 one module died. I made no attempt to charge/discharge/rebalance myself. just drop in and drive.
    Of the 7 i replaced, 5 of those didnt have to be replaced but I wanted to be sure I didnt have to pull the pack apart again. remember I had bridged the positive terminals with a socket wrench between # 19 and 25. Number 3 was the rtod culprit.
    Without prolong i got 40k miles last time. with it i suspect ill get closer to 60k or so b4 i have another module failure. TMR-JWAP is on a very short list of people I will buy from.
    I currently have 223k miles on my prius. i suspect my driving shall be much less in the immediate future so that 60k miles is likely to last me a year or more.
    I have the pack removal/module replacement/pack install process down to about an hour and change. If prolong is mere preventative maintenance and gets me even an extra 10k miles...for 400 bux it was worth it.
    In the meantime i'll just keep buying modules and build another pack. At 35 bux a module thats only 980 a pack. Compared to the retail butt-bonking people get at the dealer i could buy 4 paks for that. FOUR!!!
    As an investment firm owner I understand that while money and time are fairly quantitative, perceptions of either range from pure quant to airy-fairy nonsensical unicorn fart huffing. And everywhere in between.
    But come on... this is so effing cheap I'll drive this car until 100 years old and i have 2 million miles on it. (hyperbole) but seriously, i can easily see this car getting 500k miles.
    This is the only car i know of where one can do a frame off resto mod with merely a metric socket set.
    And considering the gen 2 cars can take up to 2014 modules... sheesh. This car will die b4 then.
    strawbrad and bisco like this.
  4. Sam Spade
    2,036
    1,024
    2017 Prius c
    That is great......for YOU. Not everybody has your tolerance or love of "tinkering".
    As your own story shows, your first "repair" only lasted 8 months......and you don't KNOW how long the next iteration might be, if I follow the story correctly.
    Then there is that last statement which might be critically important.
    It would be a shame if the engine "blew up" right after you got that last module changed.
    One needs to be practical about the things that they undertake.
    And I think those who characterize others who try to put things in the proper perspective as "naysayers" or "haters" are not really doing the average Joe a favor........by in effect saying "How dare anybody disagree in the slightest little bit with my analysis of the situation."
    #24 Sam Spade, Apr 5, 2017
  5. Sam Spade
    2,036
    1,024
    2017 Prius c
    Nope. That changes NOTHING.
    That is talking ONLY about the "memory effect" of NiCad batteries.
    Other battery designs/chemistrys do NOT have that problem.
    That problem is widely known as is the "fix".......which produces varying results because you can't tell before hand if the loss of capacity is due to the memory effect OR if the cell is just worn out.
    I'm pretty sure that no hybrid vehicle ever ran with NiCad's. Certainly not any production model.
  6. Anthony Park
    37
    Arizona
    Sam...it was a repair, no need to add quotes for sarcasm. my 8 months is 40k miles. most people dont drive that in 2 years.
    it would be a shame indeed; but used gen 2 prius cost around 3-4k these days. chump change. and they usually have less than 150k miles. more like 60-90, especially here in az. lots of grandma-mobiles. I could pick one up and use my current as either a parts donor or just find an engine and swap or both.
    I would remind you that you are on a tinkerer's forum par excellence. Priuschat gen 2 TECHNICAL DISCUSSION.
    The funny thing is this: You have me all wrong. I hate this stuff. I'm a Scots-Korean-American academic who is culturally disinclined to say the least towards this sort of thing. we don't normally turn wrenches per se. It's just that with this car its so easy...its retarded to spend the money at a dealer. If I can spend an hour or two and save 4k...thats the Scots in me.. genetically parsimonious and proud... or sanctimonious and... well never mind.
    it is horribly unwise to disagree with me on anything I've opined about. you certainly have the right to be wrong about anything you wish, but calling your perspective "proper" is rubber horsepucky.
    #26 Anthony Park, Apr 5, 2017
  7. bisco
    52,862
    well done anthony!(y)
    Anthony Park likes this.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Allow me to butt-in here for a moment....
    First....To Anthony > I appreciate the good words thrown in my direction. I'd be happy to help anytime.
    Second.... I am a proponent of renewing a Gen 2 battery by performing a complete swap of all 28 modules using the modules from a wrecked/salvaged Gen 3. Forum member John C. now has one of these batteries in his car. It would be great to hear from him with regard to both short term and long term results. I'll contact him to see if he'd be willing to post about it now and then.
    Third... As many others have done, in earlier times, I also successfully repaired my 2005 battery (at 235k mile point) merely by swapping out the blatantly obvious bad module. Drove it for a year and put 30k+ miles on it, including many 600 mile trips from SC to Ohio (mountains of NC, VA, WV) and then decided to build another battery using (2) 2013 Prius C batteries to supply the needed modules. That was done merely because I planned to let my son use it for college and I wanted it to be as reliable as possible. That rebuilt 2005 sat on the shop floor for almost a year, when it was picked up and installed in another 2005 that I purchased that had a failed battery (260k miles). That car fired right up and ran like a champ for almost a year (15k+ miles) before another driver decided they liked my lane better and sent me off the road, totaling the car. So, can this be done and can it work? ABSOLUTELY. Will it work perfectly every time? ABSOLUTELY NOT. For the competent DIYers here.....have at it and have fun, just do your best to ID the culprit module(s), use common sense, take a hundred photos if you need to help with reassembly. Feel free to contact me if you need guidance. A little bit of planning and preparation can put you in the 'win' column on these battery pack rebuilds.
    Fourth....As I'm sure others have done also, I have been and continue to do, short term and long term testing of Gen 1, Gen 2 and Gen 3 modules. I went on a 12 hour round trip drive to acquire the HV battery from a very low mileage 2015 wreck in order to have a standard for comparison (actually 28 standards, right?) to use against "refurbished" modules. I've invested a bit more $$ into test equipment than the typical DIYer. I know for fact how an essentially 'new' module reacts and behaves under different testing methodologies. It's very easy to perform the same testing on a used module and compare the results. The difference between a "pos", "ok", "good" and "great" module is easy to recognize. It's not uncommon to fully test the 28 modules of a, let's say 2007, battery pack and have some that test great, some that test good, some ok and the rest be "pos". IMHO, anything other than great or the very high end of good falls under the category of "pos".
    Anthony and I had a couple discussions about his battery, the bad modules, the "shorting" event and the potential cell/module damage that may have resulted, along with discussions of the Prolong device. His concerns were totally justified. 6 modules shorted. ~45 volts with near zero resistance when a wrench welds itself to terminals is one heck of a current spike. IMHO, looking back on it, he made the right call by replacing them all. Many posters immediately jumped to the conclusion these modules were replaced because the entire battery pack was old and weak and he's going to chase his tail forever replacing one or two modules at a time. I personally do not feel that will be the case.
    As for the Prolong....Now that he has his battery in a reasonable working state, I see no downside to it. Will a prolong help a battery that has a failed cell/module. Not IMHO, and I don't care who says it will, because I feel it will not, and I'm a damn good electronics tech, electrician, multi-craft tech or anything else you want to call it. Will it help a battery that is already in good condition, by helping to keep it in good, balanced condition? Probably so, but the only way to know for sure is to do a real scientific test. Unless Prolong wants to install a thousand of them for free to compare to a thousand cars without it, we'll just never have true long term data to look at.
    And...if you take the time to read through this topic, you may notice there's more than one person who seems upset that everyone else isn't immediately falling in line behind their opinion. Just remember the world would be a mighty boring place if we were all the same.
    Anthony Park and bisco like this.
  9. Anthony Park
    37
    Arizona
    THIS! :)
  10. kkeane
    kkeane Junior Member
    72
    San Diego
    That's exactly my concern. My understanding is that it's neither contaminants nor chemicals being used up, but rather the electrolyte forming crystals. Keep in mind that I'm not a battery expert, so my description may be way off - it is supposed to be a smooth gel. Not unlike what happens with honey when you store it in the fridge. The crystals form as you discharge the batteries, and partially - but not fully - dissolve again as you discharge it.
    In new batteries, the crystals are small, but over time they build up. Usually, rechargable batteries can be recharged about 1000-3000 times before the buildup becomes excessive. I suspect that the same number is also true for Prius cells. After using NiCad batteries in laptops and other devices for decades, we have quite a bit of experience about how to prolong their lives.
    These crystals don't act as electrolyte the way the gel form does. Less electrolyte means less capacity.
    You can reduce the formation of these crystals by never fully discharging the battery - that's why the Prius will keep the battery within the 40% to 80% charge range. It's also why running out of gas damages the battery.
    Some of what this prolong system seems to do may help prolong the battery life of a new battery - the slow charging would prevent a deep discharge when the car is parked for a long time. But deliberately deep-discharging the batteries seems incredibly harmful to me on a new battery. In an old, dying, battery, it may help give it a little bit of a boost, but it doesn't last long. It may be enough to get you on the road again, but probably only enough to drive to the nearest dealer for a new battery...
  11. Anthony Park
    37
    Arizona
    Like I said earlier, once an older refurbed battery is up an running, it should act as something like preventative maintenance. Steve Keith seems to know lots about these batteries and he was the one who suggested I purchase Prolong.
    Perhaps Prolong will keep the crystals at bay longer. If i get another 10k, even one time, prior to having to rip the car apart again it's worth it.
    So i'll set the bar at 50k. If i make it to 50k, plus or minus 5k miles, i think we can all agree the extra 400 is worth it.
    It's really no different than an RC charger repackaged.
    bisco and MTL_hihy like this.
  12. MTL_hihy
    536
    261
    Maritimes, Canada
    Unfortunately not only was your first chemistry comment off the mark but your second comment shows how little you really do understand about battery technology or chemistry. I mean saying things like "chemicals get used up" in the battery module, seriously?! NiCD are totally different battery designs/chemistrys, really?!
    Nickel–metal hydride battery - Wikipedia (read the second sentence, also read "loss of capacity" section)
    Luckily most finding this thread later are usually smart enough to sort out those who feel the need to speak from those who are worth listening to but hey, what do we know, right.
    #32 MTL_hihy, Apr 11, 2017
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    Oh I see.
    Thank you Mr. Trump for showing me the truth.
    :ROFLMAO:
