Who will be grill blocking soon?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Sep 13, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    If you use HV much you will get some benefit starting below 80 degrees. Who did it last year?
    52,671
    well, it was 96 yesterday...
    JamesBurke likes this.
  3. markabele
    5,084
    1,782
    Nebraska
    Mid September. It's coming before long. It was in the 40's here last night.
    52,671
    i know, it changes fast, doesn't it? but i won't block until it stabilizes in the 40's or so. i'm too worried about overheating.
  5. markabele
    5,084
    1,782
    Nebraska
    Pretty hard to overheat it. You have to be doing pretty high speeds or lots of uphill. You have a way of monitoring it?
  6. bisco
    52,671
    no, and some have posted in the past that it overheats easily?
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Black Friday seems like a good time to do it around here....
    Ken Blake likes this.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    When daytime highs are only in the low 50's, then I see it as time to block. The benefit of heat-retention doesn't reveal itself until temps are below freezing anyway.
  9. Rvinyl
    Rvinyl New Member
    Hey guys,
    What is the purpose of blocking? I don't believe I have ever heard of it before.
  10. john1701a
    12,840
    5,312
    58
    You must be either really young or from the south. Here in Minnesota, it was common practice decades back. Every winter, you'd block to keep warm and make the engine run better.
    Nowadays with a Prius, you do it to make the engine shut off sooner and stay off longer. That reduces the MPG penalty associated with winter driving.
    Rvinyl likes this.
  11. Mendel Leisk
    42,165
    ^ Speeds up warm-up. Also, in winter "fully warmed" (say around 90C, 190F) is often never reached; grill blocking can help get you closer.
  12. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I blocked mine last Fall and didn't remove it. No Problems noticed.
  13. Mendel Leisk
    42,165
    Currawong likes this.
  14. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I left the top opening of the upper grille open for that reason.
  15. Rvinyl
    Rvinyl New Member
    Thanks for that!
  16. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    how about a procedure for this grill blocking for newbie such as me,,like how to do .parts needed etc
  17. Mendel Leisk
    42,165
    3/4" pipe insulation is commonly used. That the styrofoam split-tube for wrapping of (nom) 3/4" dia copper plumbing pipe. It has an outside diameter of around 1.5". It basically crimps on to the grill slats:
    Tubolit 1-1/2 in. IPS x 1/2 in. Polyethylene Semi-Split Pipe Insulation - 96 Lineal Feet/Carton-DGT11012S at The Home Depot
    Some cut into short sections, interrupt at each vertical bar. Personally I just run a single tube full width, and secure it at both ends with some velcro tape:
    Velcro® Plant Tie - Lee Valley Tools
  18. john1701a
    12,840
    5,312
    58
    1/2" is the other option available. With it, you squish the foam into each grille slot rather than use tape or string to hold it in place.
    markabele and Mendel Leisk like this.
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thanks John,
    Thats what I have done since 2005 have not lost a piece of foam yet, works great!
    and it's cheap!
  20. CharlesH
    2,798
    1,166
    Roseville, CA
    All the things I've missed by living in places where one goes somewhere else to experience snow and freezing weather, for recreation! :LOL: (Born and raised in Texas, then transplanted to California.)
