Who will be grill blocking soon?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Sep 13, 2013.
  1. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Tape is holding up well after two weeks during warmer, cooler and wet weather. Very pleased with the tape versus the foam insulation method. If taping the grill is good enough for NASCAR, it's good enough for my car.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Tape should work fine as a quick, simple, nice-looking, long-lasting alternative. But what about the residue it will likely leave behind?
  3. markabele
    5,084
    1,782
    Nebraska
    I suppose tape and foam would be ideal (if you could find tape that wouldn't leave any residue).
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:Very possible, but I'll address that issue in the spring. Still worth the effort.
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I use clear packing tape to hold the foam in place, but it's hardly invisible.
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Goo-Gone will remove it and fairly cheaply too.
  7. bisco
    52,847
    blocked mine saturday, 16 degrees.:eek:
  8. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I blocked mine 2 weeks ago, with pipe insulation, first time I blocked radiator in about 45 years!
  9. bisco
    52,847
    i used to put cardboard over my mgb radiator, but that was because i couldn't afford a new thermostat.:unsure:
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yeah! Thats when we had to change them twice a year! Ahhhhhhhhhh! Memorys!;)
  11. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    The Prius in Japan supposedly has automatic louvers that close when it's cold out, and open again when it warms up. I'm not sure if this includes the PHEV.
