Who's driven 4th gen in the snow?
Discussion in 'Gen 4 Prius Main Forum' started by first_superior_prius, Dec 7, 2016.
  1. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    Actually this advice was for winter driving specifically. But I read it back to "manual-time", way before any E-traction/stability controls and any legislation.
    My understanding of this advice is that deceleration control is more important then accelaration,
    IMO and YMMV :)
    #21 alexgrigori, Dec 9, 2016
  2. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    These OEM tires on my Gen 4 are absolutely worthless in the snow here in the mountains. Try going up a 20% grade with these, and you'll be walking very soon. So what's the best snow tire for the Gen 4 Prius guys???
    Absolu22 likes this.
  3. Mendel Leisk
    42,347
    Best can vary. I'm likeing our X-Ice because they're well mannered on bare pavement as well, but maybe they're not the deep snow traction leader. They're decent though.
    Absolu22, RCO and alexgrigori like this.
  4. alexgrigori
    163
    109
    Technology
    IMO for 20% grade and non-4WD car the best snow tire would chained tires or at least studded tires.
    RCO likes this.
  5. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
  6. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    I use Bridgestone Blizzak ws70s on mine; others have suggested Michelin X-Ice. I suspect both will be a significant improvement over OEM tires. I have a set of radial chains, but have never had to use them.
    Rangerdavid and RCO like this.
  7. Heikki Finland
    Finland
    Excel
    Seaulater, jdenenberg and RCO like this.
  8. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    For those of you that are deep in northern climes, of course get 4 good snow tires (the hakkapeliittas above are very good, the Finns know snow) and a set of rims. For those of us in climes with periodic snow I suggest that replacing their OE tires with a set of Nokian WRg3 tires is a good compromise. They are all-weather tires that are LRR, work as well as most snow tires in snow/ice and can be used year around for their 50k+ miles service life. I have been happy with the performance of their earlier WR and 2 sets of their WRg2 tires on my 2004 Prius and as stated earlier due to a Toyo tire failure, now have a pair of WRg3s on my 2016 Prius.
    I know that experts say to never use snow tires on the front with normal ones on the rear. I believe that rear toyos with 3400 miles will have sufficient side to side traction to maintain stability, but as an engineer, I will test that assumption when there is a snow cover here in CT.
    JeffD
    #28 jdenenberg, Dec 10, 2016
    Seaulater and RCO like this.
  9. Tideland Prius
    16,680
    "best" depends on what your criteria is but here are some highly rated ones:
    Nokian Hakkapeliita 8
    Nokian R2
    Michelin X-Ice series (currently at Xi3)
    Bridgestone Blizzaks WS series (currently at WS-80)
    Yokohama Ice Guard iG52c
    My personal experience has been with the Nokian Hakkapeliita WR, WRG2, WRG3 as well as their Hakkapelitta R winter tire. The "R" is the best performer since it's a dedicated winter tire vs the WR series which are all weather tires.
    The WR has improved with each series but I found the WRG2 and WRG3 noisier in the dry than the WR. (I suppose the trade off for better snow traction). I found the WRG3 a bit more susceptible to wheel spin on wet roads (rain, above freezing) than the older siblings. I'm somewhere between 6 and 7/32nds of tread left on the WRG3 after 37,000km. (The Nokians have a tire wear indicator built into the tread)
    Rangerdavid and Mendel Leisk like this.
  10. Mendel Leisk
    42,347
    Maybe you're between 6 and 7 mm? Or you measured independently with a tread depth gauge? I think the Nokia tread indicators in mm, anyway.
  11. jettlash1000
    jettlash1000 Junior Member
    51
    Here's my two cents:
  12. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Nokia hapa8 with studs, frozen dirt and snow roads, and some 6" plus snow, lower than the gen3 by .9" but still a beasty, good traction, excellent stability control--it just stops, very pleased, studs are for stopping.
  13. Tideland Prius
    16,680
    Crap. It will also help if I knew what units those numbers were in. Thanks for that!
    I used the tread indicators.
    Mendel Leisk and RCO like this.
  14. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    The traction control is really loud. It kind of clunks and grinds. Little jarring but not the end of the world.
    And yes I've youtubed it and mine isn't damaged.
  15. Mendel Leisk
    42,347
    Which means it's more tread depth than you expected, that's good.
    Tideland Prius, RCO and Prodigyplace like this.
  16. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    My Gen 2 was horrible. Once the tires started spinning it would remove power to the wheels. That and the low ground clearance would keep my Gen 2 grounded on any snow days greater than a few inches. That said, in the NYC area I drive in most roads get plowed well enough for the prius. I hope my gen4 is better. I think we can turn off the traction control. It will be interesting to see if I can move in snow with that off.
    RCO likes this.
  17. Mendel Leisk
    42,347
    Gen 3 improved traction control. With 4th gen yes believe you can turn it off, but I wouldn't assume it would be better, turned off. Maybe only when you're royally stuck?
    RCO likes this.
  18. Prodigyplace
    12,713
    11,848
    Central Virginia
    From the 2016 manual:
    Of course, people here already read that.
  19. Lucifer
    1,014
    486
    Nh
    My gen 2 was the same, until I put snow tires with studs on, then it was a winter beast. Same with the gen 3 +4, the interface between the car and the planet is your problem, not the car.
    RCO likes this.
  20. Mendel Leisk
    42,347
    Seems like sage advice, still I'd hazard no one's ever done that.
    They also mention using wheel chocks (for the wheel diagonally across from the flat) when jacking up a corner due to a flat (assuming you have a spare). I purchased a light-weight pair expressly for emergencies, stow in the car. Have had occasion to use them for that purpose.
