Who's driven 4th gen in the snow?
Discussion in 'Gen 4 Prius Main Forum' started by first_superior_prius, Dec 7, 2016.
  1. Prodigyplace
    12,720
    11,852
    Central Virginia
    Here is another curiosity: My 2017 Trim Two does not have that button on the steering wheel, but the brochure insists I have traction control.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Traction control should stop one wheel slipping in slippery situations - I've never needed it in my PRIUS, but my previous car when on a grassy wet slope, you could feel the system locking one wheel so the other could get grip, but I had to drive very gently to allow movement. TRC helps with this. They've all got Traction Control that I understand, tied in with ABS Brakes and Stability Control computer.
    The Manual says:
    TRC (Traction Control) (called TRAC in USA Manual):
    Helps to maintain drive power and prevent the drive wheels from
    spinning when starting the vehicle or accelerating on slippery roads
    AND
    Tideland Prius likes this.
  3. madmax75
    madmax75 Junior Member
    north dakota
    Three Touring
    Heres my take on my gen 4's trac control. Is completely worthless with factory tires. Had to shut it off on flat ground on ice just to get it to move. And you cant spin the wheels fast enough with it off to get unstuck or plow through snow. My srt4 5spd with lsd is a million times better in winter driving. Heck any other car / truck ive owned is way better. If they are calling for stormy weather use a differnt vehicle if possible
    MrMischief likes this.
  4. Mendel Leisk
    42,387
    I've seen a video of a Prius, albeit 3rd gen, going slowly up an icy driveway. Traction control periodically activates, sort of "stuttering" the tire, and without a lot of drama the car does just fine, negotiates the slope to the top.
    Toyota's thrown a lot of research into this, and has refined it through three generations now. It's tempting, to assume extra controls are bad, and disabling them will improve things. Maybe when you're completely stuck, but in typical situations, I'd give it a chance.
    I've been looking for that video, so far without success. It was linked here on Priuschat at least once, IIRC.
    jerrymildred and RCO like this.
  5. madmax75
    north dakota
    Three Touring
    It might do better with winter tires. I was really surpised with the little ice on flat ground with no snow i had to disable the trac control. Think the biggest issue with mine is it activates almost immediately but that could be due to the low resistant tires. Maybe if i spring for winter wheels and tires next winter it will do better. But in bad weather and sitting so low either the durango with awd or my srt. Otherwise its done fine on winter roads as long as i take my time turning a corner as these tires want to slide. Has any one ran winter tires on gen 4
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    Is the button on the steering wheel or the dashboard? I definitely do not have it on the steering wheel, but I have TRAC.
  7. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    It's on the dashboard, on the left side, down low, near the buttons to adjust interior lighting.
    Prodigyplace likes this.
  8. Mendel Leisk
    42,387
    Looks to be on the dash, to the left of steering wheel, rightmost button in a row of three.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    Thanks. I'll need to check again.
    EDIT: The button is on the dash, somewhat hidden by the steering wheel. They should have used a different perspective in the manual to show that switch. It would be more obvious from the driver's door, for instance.
    #89 Prodigyplace, Mar 13, 2017
  10. Mendel Leisk
    42,387
    The Repair Manual is similar: picture locating engine coolant drain bolt ('round back of the engine block) is shown in a small picture viewing from the front. Treats it as transparent...
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I remember that one, but I can't find it either. I see lots of videos showing that it doesn't go at all in the snow and several showing it having no problems at all. I suspect that tires and driving technique are the difference. Here's one on ice with no problems.
  12. Mendel Leisk
    42,387
    On the "missing" video: sounds like wife filming the progress up the slope, and she laughs near the end?
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    I don't remember for sure, but it does go with the slight "See? I told you so," sort of atmosphere. Sure wish I could find it. It's a fairly long, steep, curving driveway.
    There's another account here, iirc, where a guy told about being parked on a grassy slope at some sporting event and it poured down rain. The pickup parked next to him threw mud all over in trying to back out onto the pavement but eventually made it. He figured he'd be in trouble, too, because his front tires were sunk in quite a bit but he just motored right out with no problems.
