Why are Prius V tires so expensive?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by neuf150, Jul 12, 2016.
Tags:
  1. neuf150
    neuf150 Junior Member
    Had a nail in a tire and needed a new tire. $249 from the dealer. Service said I needed to match current tires or it would lower mpg and ride poorly. Seems like a high price. Called 4 tire companies that said Prius tires run from $85-$125. Went with the service recommendations but still feel like I was hosed.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    You can check price on TireRack.com and add about $30 for install ( and you have shipping too).
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Since you do not list a location, it is hard to know how 'taken' you were US dollars, Canadian Dollars, Australian Dollars, etc.
    4 Michelin Energy Saver A/S would be $644 at a 'nearby' Sams Club in MS. ($161 each 2 hour drive)
    But only $548 at a Costco in TN ($137 each, 2.5 hour drive)
    So shopping certainly does help
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,982
    Texas Hill Country
    At least you were probably cooled off by the hosing.
    Raytheeagle and bisco like this.
  5. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    Sorry you were hosed
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    You sure you even needed a new tire?
    Nail Punctures can often be repaired.
  7. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    Any OEM replacement tire purchased at a dealership will be on the order of twice retail.
  8. rjparker
    11,133
    6,982
    Texas Hill Country
    I replaced by factory tires at 105k with Michelins from Costco. Probably $150 each installed out the door with nitrogen and lifetime rotations. No impact on mpg.
  9. bisco
    52,889
    that's just standard dealership practice. if you want to keep more change in your pocket, you have to shop around.you only need the dealership for warranty, and very specific hybrid service/maintenance items, usually not in the first 100,000 miles.
    RoadNoise likes this.
  10. iibw
    iibw Junior Member
    Pittsburg CA
    2013 Prius+ MPV
    The original factory tire is a Toyo Proxes A20, which sells for $241.52 at tirerack so that seems like the right price for an OEM replacement. It's made in Japan. However, as a previous poster said, a nail shouldn't warrant a tire change, unless the tire got shredded?
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You claim to have a Prius v V, if you meant Prius v Five, you have the rarer 17 inch tires. That may increase the price as well
  12. bisco
    52,889
    apparently, the o/p had a moment, and got it off his chest.
