Why can't I get 8.8kwh miles?
Discussion in 'Prime Main Forum (2017-2022)' started by SydneyNJ, May 30, 2019.
  1. SydneyNJ
    SydneyNJ Junior Member
    87
    24
    New Jersey
    2018 Prius Prime
    I have a 2018 Prime Advanced. The multi-display instrument panel (MIP) says "5.1miles/kwh".
    Somewhere in the manual, it says 8.8kwh battery capacity. When I full charge this
    traction battery via L2, I always see 35.1miles for using pure EV or 34.x with Fan/AC on
    my MIP.
    Why can't I get 44.88 miles per charge (5.1mi/kwh x 8.8kwh)?
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The portion of battery capacity for EV mode is closer to 6.1kwh. The rest is dedicated to HV mode use. The total is 8.8 Kwh.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    To prolong the battery life, the full capacity of the battery is not used. A typical full recharge from 0% indicated is 6.6 KWh.
  4. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    So when I charge, am I just charging ~6.1 - 6.8kwh of electric power or the full 8.8?
  5. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The battery will never be empty. At most, about 72% is added back each recharge.
    #5 john1701a, May 30, 2019
  6. Trollbait
    12,831
    With no EV range left, a charge is only adding @6kWh.
  7. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    So if I want to know how much ($$) I am paying per charge (roughly), is the math:
    72% of 8.8kwh x $0.11 ?
    11 cents per kwh is my electric rate.
  8. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    or is the math:
    (1kwh/5.1mi) x ( 35.1mi) x ($0.11/kwh) ??
    35.1 is what i see on my MIP and the other numbers are just specs/facts.
  9. bisco
    52,863
    the cost is 11 cents times 6 = 66 cents per charge, roughly, depending on how low your battery is when charging
    the number of miles per kwh has nothing to do with your cost per charge.
    that would be useful for cost per mile if you're interested
    however, to be sure your kWh charge is correct, include all costs on your bill related to anything over the minimum monthly charge, if there is one.
    #9 bisco, May 30, 2019
    Arctic_White likes this.
  10. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    5.1 miles/KWh is quite good, BTW. I’ve been seeing — long-term, including bouts with high and low temps — 4.6 miles/KWh.
    A Tesla Model 3, which is considerably pretty efficient EV gets only around 3.8ish miles/KWh, and the Jaguar iPace, widely acknowledged as dreadfully inefficient, gets something like 2.5 IIRC.
    Anyway, I haven’t read the rest of the replies, but short summary, they reserve a 10-15% “top margin” to reduce the overcharging that can kill battery life, plus around 1KWh at the bottom is reserved for HV operation (and margin).
    #10 mr88cet, May 30, 2019
  11. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Is this what you've been noticing on your electric bill? :)
    Well, I guess knowing exactly how much you pay on the bill is nearly impossible unless you have a dedicated circuit.
  12. bisco
    52,863
    not exactly
  13. bisco
    52,863
    the bill only shows total kwh used by the whole house. individual circuits aren't tracked.
    you would need a kill a watt meter plugged into your outlet, then plug your evse into that. it would tell you what you are using, minus losses from the panel to the outlet.
  14. fuzzy1
    10,713
    You can put a kWh meter on you charger and get a real number.
  15. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    I'll take the guesstimate of $0.11kwh x 6.x kwh :)
    benagi and bisco like this.
  16. bisco
    52,863
    that's what i do
    benagi likes this.
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    If you want to track how much electricity you're actually buying for the car, there are plug-in meters like the Kill-A-Watt that will track it.
    As others have said, Toyota won't let the car completely fill or drain the battery. That would kill your traction battery in short order. If you're getting 35 miles/charge, you're way ahead of the EPA estimates (25 miles) and doing average to a little above average for most Prime owners. Before the Florida heat set in, I was getting 5.5-5.8 m/kWh. Now that the air conditioner is working overtime, it's just above or below 5.0. Not quite getting 30 miles/charge anymore that it's unbearable outside. It was at least 35 miles.
  18. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    hhmmmm... do you have a picture of this thing?
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    There are charging inefficiencies from both the cable (EVSE), the charger itself inside the car and the battery. There's also the BMS (battery management systems) and the TMS (thermal management system) that regulate both the charge rate and the temperature of the pack which also requires some electricity so......
    as previously stated, you need some sort of measuring device (killawatt typically recommended) to see exactly how much energy is require to "fill the tank". High tech EVSE's will report the full charge amount via an app.
  20. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    benagi likes this.
