Why can't I get 8.8kwh miles?
Discussion in 'Prime Main Forum (2017-2022)' started by SydneyNJ, May 30, 2019.
  1. SydneyNJ
    SydneyNJ Junior Member
    87
    24
    New Jersey
    2018 Prius Prime
    Thanks so much. I'm going to check this out.
  2. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    I have noted in my other thread that when I use L1, I only got 25.x miles per charge. I just had a 240V outlet installed couple of weeks ago and notice the difference right away after my first charge using L2. I now always see 35.1 miles on my MIP. This is consistent from charge to charge. It takes ~1hr 50mins from empty to full. Don't understand this ...
  3. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    These are for 120v. I will try to find one that works on a 240 circuit as well as giving me the 240v plug configuration for my
    charger.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Yap, that's a good estimate if you always charge from EV range 0mile to full.
    I was going to tell you that Kill-a-watt meter only works with L1 120v EVSE, but you seems to figured out that. There are more expensive and robust kW meter that can handle 240V, but it will cost more. Doesn't your L2 have an option of monitoring kWh used for each charge session? Many does.
    The difference in EV range is just a coincidence. Probably it was much colder when you were using L1 and now with L2 you are using in much warmer days. I was getting less than 25 mils of EV on GOM until end of April, but now I get 33 miles, all with L1 EVSE use.
    jerrymildred likes this.
  5. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    No, I don't have that. Maybe if I had stepped up to a L2 charging cable for $400, that might have it. Is it worth that?
  6. Salamander_King
    11,024
    8,980
    New England
    Yeah, many of more expensive ones like this one ChargePoint Home EV Charger have various features like phone app to monitor and remote control the charging session. If you got just a simple cord, then you will have to install kWh meter DIY.
  7. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    $400 is a lot just to see how much charging your car costs.
    benagi, jerrymildred and bisco like this.
  8. bisco
    52,895
    just get the kill a watt. when you find out how many kwh you use at 120v, 240v will be very close.
    fuzzy1 and jerrymildred like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    SK is right. Just coincidence. Probable cause is either temperature or driving habits/conditions. The battery doesn't care if it's charged at L1 or L2. At least no one else's battery cares, so your's is not likely to be different.
    Arctic_White and Salamander_King like this.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I find that if I coil the charge cable just so, the alignment of the lunarfaciant marsal vanes with the coptic reluctors produces a recipient trophoidal wave that puts ever so slightly more charge in at 240V. ;)
    drash, benagi, Trollbait and 3 others like this.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I'd like to try that. Do you have a picture or diagram? :LOL:
  12. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Guess i could do that. Not exact but not a bad idea either.
    17 bucks at Home Depot. Why not?
    I'll get one this weekend and try to post a picture here. :)
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    That would be the minor benefit of going with a high-tech level II EVSE.
    The main reasons folks go 240v is A) much quicker charging (more important on smaller packs if one needs extra charges to make it through a day on pure EV) and B) being able to pre-condition (heat or cool) the car before getting in WITHOUT draining the pack; level 1 can't keep up and will draw on the pack reducing range.
  14. jerrymildred
    11,517
    14,171
    Tampa, FL
    True that it's not exact. But better than nothing. Also, the ones what remember readings after a power outage cost a little more. Mine was a cheap model, so I recorded the kWh after every charge.
    If you go with L2 on a 240 circuit, they make some inexpensive meters. Mine was $19 iirc.
  15. jerrymildred
    11,517
    14,171
    Tampa, FL
    You can get those basic L2 features for a lot less than $400, though. Mine was $189. It's just like L1 but more than twice as fast. Just no extra bells & whistles.
  16. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You can do all that for less than $50 with an adapter cable for the existing charge cable to run the existing one off 240VAC.
  17. fotomoto
    5,639
    3,815
    So. Texas
    Exactly. That's why I separated the sentences to hopefully separate the ideas (guess I didn't).
    Some Clarity owners discovered the OEM 120v charger is actually the same one shipped to other areas of the world as a 240v; just different plugs so all one needs is a cheap ($13) plug adapter for USA owners to turn it into a level II. I haven't tried it since I already have a level II but others report satisfactory results.
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This usually does it. Quick math shows that the coil diameter should be no more than the theta angle of the unilateral phase detractors, and no less than the squared sine of the interelectrode diffusion integrator flux angle.
    benagi likes this.
  19. jerrymildred
    11,517
    14,171
    Tampa, FL
    I've noticed that, too. I won't deny that it's working, but I don't quite trust it yet. Besides, I like leaving my L2 connected at home and having the OEM one for work and other places in the car all the time.
    That's cool. Would it work the same in the southern hemisphere or does the Coriolis effect make it reverse?
    #39 jerrymildred, May 30, 2019
    Arctic_White and drash like this.
  20. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    That's a good question. Being stuck in the northern hemisphere, we'll have to rely on one of our southern hemisphere members to confirm.
