Why can't I post?
Discussion in 'Newbie Forum' started by TheNomadicAspie, Nov 12, 2021.
  1. TheNomadicAspie
    TheNomadicAspie New Member
    Las Vegas
    I'm trying to post a question in the gen 2 maintenance section, but it says I need 4 posts to talk on that forum. But the same requirement seems to exist for all of the forums?
    DunRingill likes this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes. Except THIS one.
    AND I believe you can "reply" to existing threads in other forums too in order to meet the requirement.
    If you reply to this post, then you will only have 2 more to go.
    vvillovv, DunRingill and Mendel Leisk like this.
  3. TheNomadicAspie
    Las Vegas
    Good to know, thank you so much.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Due to getting absolutely swamped by bot posts a while back, the forum now requires that the first few posts from a new member be moderated to prevent that. We only have one moderator and he actually does have a life, so sometimes it can take a little while. Since he's the only one, I'm always amazed at how prompt he usually is.
    Tideland Prius likes this.
  5. bisco
    52,773
    just keep posting here, until the pain goes away
    80sguy and vvillovv like this.
  6. JamoRem
    JamoRem New Member
    Los Angeles, CA, USA
    That explains a lot. I'm new too. Thanks for the info, and thank you Moderator for the great work you do keeping this forum safe!
  7. SuzyGS
    SuzyGS Member
    138
    66
    Hampton Cove AL
    This is hard to figure out. I have posted over 100 comments starting 4 years ago but there's no "post new thread" anywhere. Really needed some help tonight.:(
    #7 SuzyGS, Dec 6, 2021
  8. Tideland Prius
    16,668
    :cautious:
    bisco and vvillovv like this.
  9. bisco
    52,773
    now that you've mentioned it, can we get back the info bubble when you hover over a title? :p
    jerrymildred likes this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    It is also hard to figure out why folks are posting in reply to your problem WITHOUT giving a clue as to what the answer is.
    IF.....you click on the name of a sub-forum, the "post new thread" button should be near the upper right corner in a prominent large box.
    As for the other changes that were made recently, that is just more of Danny's screwing around.
    In this case, I suspect it is an attempt to generate more read "clicks" to inflate the amount of traffic that he reports to his ad "partners" and get more revenue.
    I'm about ready to leave.
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    I miss that thing!!
  12. Eric Z.
    Eric Z. New Member
    Milwaukee, WI
    2014 Prius v wagon
    I am in the same situation. I was hoping to post a question about uneven tire deflation in cold weather.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    ANd now you have 3 posts.
    Only one more to go.
    It is not unusual for the pressure drop to be somewhat uneven when cold weather sets in.
    They might not have been exactly equal to start with.
    Or one side might be sitting in the sun.
  14. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    @Tideland Prius can you confirm what is quoted below?
    I've seen a few similar forum formats changing over the last year or two and it looks to me like a ton of javascript updates are to blame for the things most users are complaining about, and has little to do with the forum administrators, as far as I can tell.
  15. Deidre Hammond
    Deidre Hammond New Member
    Vadnais Heights, MN
    I need to post a help question about my 2011 Prius and I am unable to start a post anywhere.
  16. bisco
    52,773
  17. Enriquez1023
    Enriquez1023 New Member
    Anaheim
    I guess we need to make about 4-5 posts or responses until our main post about our question will be public for everyone
    Why do they make such rules need help and mechanic will only **** us over
    #17 Enriquez1023, Dec 10, 2021
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    I feel sorry for folks who are so jaded and cynical. I hope you get over that soon.
    The rules are necessary because the world is loaded with BAD people who take pleasure in tearing down anything that they can.
    The good people have to suffer a bit because of that.
  19. Tyler Sheaffer
    Tyler Sheaffer New Member
    Ah, now I understand. Thanks to the moderator for dealing with all the robots!
    Deidre Hammond likes this.
  20. Steel Rat
    Steel Rat New Member
    Oak Harbor, WA
    Posting a comment to get to my 4.:cool:
    hill likes this.
