Why Can't Other Plug-In Hybrids Copy Chevy Volt's All-Electric Running?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Mar 19, 2015.
  1. bisco
    51,895
    and get pips 50 mpg in hv mode.;)
  2. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    HV mode fuel efficiency is not very important if you don't use it very often.
    I'm more interested in fuel use over the year.
    In other words, if I use the HV mode 3% of the time, the HV efficiency is not very important.
    51,895
    i'm not interested in all electric running, but it's not a matter of personal preference.
  4. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  5. bisco
    51,895
    imo, he never quite seems to get it. props for trying i suppose.
  6. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    That 3% of trips probably is around 30% of miles, as these trips are mch longer than average. Still you are entirely correct.
    Let;s look at a 15,000 year and a 62% utilization rate (35 mile aer + 38 mile aer volt), 70% utilizzation likely for volt gen II, a 35mpg versus a 55mpg doesn't save that much gas
    utilization 0%, 62%,70%, 75%
    35 mpg - 428, 163, 129, 107
    41 mpg - 366, 139, 110, 91
    50 mpg - 300, 114, 90, 75
    55 mpg - 273, 104, 82, 68
    You can see if we get to a 70% with that new longer range even with a 35 mpg hybrid set up (worse than gen I volt) you burn only 47% of the gas of a hypothetical 55 mpg hybrid. Increasing efficiency from 41 mpg (rumored gen II volt) to 55 mpg (rumored gen IV prius) on a 70% utilization phev, only saves about 28 gallons a year.
    One day the lightbulb will go on
    #346 austingreen, Apr 3, 2015
    Jeff N likes this.
  7. Trollbait
    12,518
    My statement was based on month to month comparisons. Yes, it would take time for the i3 to roll out across the nation, but that appears to have taken 3 months. August 2014 to until now, its monthly sales have been near the same.
    The new Volt was unveiled the beginning of this year, and this year's monthly sales have been less than half what the Volt sold in the months of 2014.
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    My 2001 Prius is getting long in the tooth, but still running reliability. The only Volt I would look at is the next gen. The step from the 2001 to 2004 Prius was huge. Even if the next Volt is less dramatic, just the shift from using Premium to Regular is enough to make me wait. You point about the waiting certainly applies to me. In fact, I would think most prospective Volt buyers are well aware of the payoff of some waiting.
  9. El Dobro
    El Dobro A Member
    7,088
    3,270
    Do you think I'm upset about using premium? :p
    austingreen, Zythryn and Jeff N like this.
  10. bisco
    51,895
    yup.
    dbcassidy likes this.
  11. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Well, 3.9 gallons of being upset.
    (P.S. Most excellent way to convey a point.)
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    One of the members on the Volt Forums posted this. I doubt he worries about using premium. :D 11070941_1616948048535647_2838452944110104662_o.jpg
    austingreen likes this.
  13. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    That puts new meaning to the words "fossil fuel".
  14. walter Lee
    1,126
    376
    Maryland
    I agree - Much can change from now to when the 2nd gen Volt hits the show rooms.
    The next 10 years will be an interesting time for the car industry - I expect great things to happen.
    While the Prius isn't perfect - I am reasonable very happy with my 2010 Toyota Prius.
    I picked the Prius over the Insight because the Prius owner/driver community was bigger and more active than the Insight's.
    While all this new tech is great ... it can be somewhat overwhelming at times.
    Hence my focus switched from machines to people helped me adapt to all this new stuff.
    I've seen hi tech stuff come an go.
    Nobody stays on top of the hill forever
    What car will take the Prius' crown - will be interesting
  15. bwilson4web
    16,202
    Well this might be useful:
    Hypermiler repellant ... or attractant?
  16. bisco
    51,895
    it won't be the car with the above display.
  17. hill
    8,799
    There are carwings posts showing 18 miles/kWh. I'm thinking some folks know how to game the system. In fact numbers like that almost seem to defy the laws of physics. Perhaps GM has created A mileage calculating system more 'game proof' than carwings, and so the Volt numbers are in fact real.
  18. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    There's no magic here. This guy just drives in battery-only mode so the engine is mainly starting up for maintenance reasons.
    The more common mode ensures that the gas engine starts up and runs until it comes up to full operating temperature at least once every 6 weeks. This takes somewhere between 0.03 and maybe 0.10 gallons of gas depending on the ambient air temperature. This mode makes sure the engine is lubricated and any accumulated water is driven out of the engine.
    The less common mode is for fuel management. It ensures that the gas in the tank has an average age of less than 12 months. After the gas is judged to be a year old it forces the Volt to operate in hybrid mode until the old gas is used up and/or sufficient new gas is added to the tank to substantially reduce the average age. You can see in the photo that this driver keeps the gas tank nearly empty to reduce the amount of gas that needs to burned off during fuel maintenance mode.
    I personally have never seen either mode happen on my car because I'm using enough gas that the maintenance modes never need to run. Very few Volt drivers will ever see fuel maintenance mode.
  19. dipper
    dipper Senior Member
    1,242
    252
    He bought the wrong car. He should not be hauling an ICE if he did not want to use at all.
    usbseawolf2000 likes this.
  20. Trollbait
    12,518
    We don't know the year of the car. The picken's were slim early on.
