Why Clock Lose 1m repeatedly?
Discussion in 'Gen 3 Prius Main Forum' started by PriusNeckBeard, Sep 14, 2017.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    My 2013 Prius' dashboard clock loses a minute every two months or so.
    do not know how often, really.
    It just keeps happening.
    I'm starting to keep a log.
    Normal or a sign of something more dire?
    I've never replaced the 12v battery.
    52,927
    Not sure what you mean by dire.
    Or normal, for that matter. Mine does too, I'm guessing cheap electronics.
    It has nothing to do with the 12v health.
    I set mine a minute ahead, so i don't have to reset as often.
    Starship16 likes this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    A Rolex Submariner upper and lower specs. are (-5 to+7) seconds per day. If the watch goes beyond these specs. it is suggested that it be serviced and regulated. If your Rolex averages a -3 second loss per day that equates to roughly a 3 minute loss in 2 months. With all that being (facetiously) said, I would say you Prius clock is pretty accurate. Tic on.
    FuelMiser likes this.
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    My clock gains 2 minutes in 4 months. Glad to see that someone else is having a weird clock issue. Toyota's way of chewing away are warrantee time?..................LoL
    Starship16, Raytheeagle and MPGesus like this.
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You got the OPs lost minutes. You should give them back.
    Starship16 and Raytheeagle like this.
  6. bisco
    52,927
    the digital clock in my kitchen stove and microwave are always spot on.
  7. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Mine gains time as well. I thought Toyota was trying to cure me of my habit of being late all of the time.
    Those are plugged into a home electrical system, not a supposedly 12 Volt but actually variable automobile one.
    Raytheeagle, Montgomery and bisco like this.
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Because your utility company regulates the line frequency coming into your house for that exact reason. It's not being driven by an oscillator or crystal.
    kc410 and bisco like this.
  9. PriusNeckBeard
    376
    211
    Cincinnati
    Man , you folks are gold. !!
  10. bisco
    52,927
    right back atcha!(y)
  11. Montgomery
    2,254
    2,244
    Orange County, CA
    Blame it on a bad flux capacitor
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The clock in my DeLorean not only freezes randomly for many minutes at a time making it count slow, it also just randomly increases the hour digit instead of the hour digit some times. So it might go:
    8:23
    8:24
    8:24
    8:24
    8:24
    9:24
    10:24
    10:25
    10:26
    etc, all within the span of 8 minutes. Nobody should complain about any electrical vehicle problems until they have experienced the awesomeness of something Lucas designed.
  13. BZzap!
    1,607
    878
    Maybe it'll snap out of it as soon as you get to 88MPH... if it'll go that fast!
    bisco and Montgomery like this.
  14. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Time is defined by the transition properties of a cesium atom. Since none of us have this instrument, all of our time prices will differ. It's beneficial for us that the digital clock in the Prius is slower as the adjustments to match are forward only. It's easy to add a minute than to add 23 hours and 59 minutes.
  15. Montgomery
    2,254
    2,244
    Orange County, CA
    Excuse me for a minute...............I'm at a Denny's eating breakfast and some wierd looking dude in a white Labcoat with wild hair and wild eyes is tapping me on my shoulder..................................
    Prodigyplace likes this.
  16. Mendel Leisk
    42,387
    For one heady moment I thought you'd sighted @Danny.
  17. bisco
    52,927
    that would explain everything.:cool:
    Prodigyplace and Mendel Leisk like this.
  18. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    My Prius has consistently gained time -- which is worse than losing time because the clock only adjusts forward. I'd say it is about a minute a month. Toyota actually sent me a new odometer/clock but it made no different. I have a Prius-driving friend who has the same problem. All I can say is what I keep on having to say: I've driven other cars and never have had this issue before.
  19. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    560
    Tucson, AZ
    2021 Prius
    For those with the NAV feature, too bad they couldn't have run a wire to the GPS clock for periodic updates. Oh, you can get to your GPS clock through the MFD battery voltage chicken dance. You all remember that one, right?
  20. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Be careful what you wish for. Some Nissan Leafs do this and there are 2 clocks in the car. The one on its MFD which is GPS controlled if you have navigation, and the other isn't. So while the GPS one is always correct, as the car loses or adds time like every car and as being discussed here, the two clocks become unsynchronized. Really really annoying to have 2 clocks in visual range that read differently... I'd rather they both be wrong by 2 minutes but show the same time.
