Why did my battery die?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Nov 12, 2016.
  1. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The second mode is "ign on" mode. Some test procedures need it. You can use the power windows in this mode as well. Kind of a "roll the windows up without the danger of the car moving" mode. ;)
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    This is the equivalent of an old key start on a conventional car when you turn it to the second position but don't crank the starter. The a/c fan will blow but it won't chill because the ICE isn't running and turning the a/c compressor. Back to hybrids, when it's in "ign on" and not in "ready" mode, the HV battery relays aren't connected so it can't power the electric a/c compressor nor drive. Same concept.
    52,814
    so, if it won't run a/c in acc or ig on, what happened to o/p's 12v battery, fan drew it down?
    52,814
    apparently not?
  5. fotomoto
    5,639
    3,815
    So. Texas
    Nothing. See post #4.
  6. bisco
    52,814
    got it, this thread has me confused.:)
  7. Mendel Leisk
    42,313
    The push button start system, how many pushes, with/without brake pedal, is a new level of confusion. Even the language describing it is confusing.
    Were there ever conventional-keyed Prius? Gen 1? Level 1 of Gen 2?
  8. bisco
    52,814
    gen1, but i still don't think you crank the engine with the key. and i think the low package c also.
    funny, i've never used acc or ig on, so it's all new to me after 12 years.(n)
  9. David Beale
    5,963
    1,990
    Edmonton Alberta
    I use "ign on" to roll up the windows when I forget to before shutting down. Can't use "EV" most of the time because we are in the "Great White North", where it's just too cold most of the time. Oh, and I'm too slow to hit the "EV" button and the engine starts anyway. ;)
  10. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    No warning
    Nexus 6 ?
  11. Taxi/Limo
    526
    107
    It seems overly confusing
    Nexus 6 ?
  12. CR94
    CR94 Senior Member
    2,824
    1,239
    Northwestern S.C.
    Even if the fan and other switchable gadgets are off, there's heavy drain on the 12V battery in the IG ON mode. That won't take long to kill the battery.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    This is the one and only feature about the Prius I don't like. I miss being able to chill in my car for awhile without draining the battery so easily.
    Is there a replacement battery that is a bit stronger in the off time?
  14. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Yellow top Optima is a deep discharge battery, but you are not going to run an AC compressor off that.
  15. fuzzy1
    10,693
    A 'bit' stronger isn't enough. For this issue, something in a substantially larger case is needed.
    #35 fuzzy1, Nov 18, 2016
  16. Mendel Leisk
    42,313
    I would just be resigned to different behaviour with the battery: never use it without the car in ready.
  17. Montgomery
    2,254
    2,242
    Orange County, CA
    Not too concerned about running the AC, just want to listen to the radio.
