Why did they uglify the 2010 Prius?
Discussion in 'Gen 3 Prius Main Forum' started by priuscurius, Feb 21, 2009.
  1. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    Alam99, I sold my 2002 Prius after driving it for 2 years. I did this because of the slow acceleration, tire wear, and the "death shudder" problem. Looking back, I probably should have kept the car. Frankly, I liked the smaller size of the Gen I Prius and the small turning circle of the car was great.
    My preference for the 2010 MY Prius over the 2009 begins with efficiency improvements. First, the heat exchanger on the exhaust is a great way to get the engine warmed in cold weather as well as in short trip driving. It is a much better approach than a thermos bottle and it will improve mileage as well as creature comfort.
    Second, the electric water pump will allow temperature control of the engine even if it is not running. This should be a great way to minimize engine hot soak every time the engine stops rotating (longer engine life). You also get the added advantage of no drive belts and their inherent friction losses. Many of the revolutions made by an engine driven water pump are unnecessary. An electric pump (if properly designed) should last longer than a conventional water pump, although the coolant pump on the Prius 1.5L was about as simple and small has I have seen.
    Third, the A/C efficiency is said to be improved.
    Cooled EGR improves engine efficiency and lowers exhaust temperatures.
    It has been reported that the high voltage inverter now has a separate coolant system from the engine. The Gen I had a separate reservoir, radiator, and electric coolant pump. Was this not true of the Gen II Prius?
    The tires on the Gen III have finally grown up. Any car with this weight should have always had 195-65R15 or larger tires. A Corolla and Civic have them. My Scion xD has larger tires (195-60R16). Vehicle handling characteristics including the feel in the electric steering are said to be better.
    Adding telescoping steering and adjustable seat height was another "it's about time" feature. The dash layout without the dependence on an LCD display is an improvement.
    I suspect the transaxle change to a higher speed gear reduced MG2 was all about cost reduction. The smaller torque MG2 in the 2010 will undoubtedly be much cheaper to manufacture. If Toyota had kept the 1.5L engine, you would not need a 20% smaller transaxle.
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    This is one of the few features I still enjoy in the '02 over my '04, turning into just about any spot. This is one thing I'll be looking for in the 2010 to see if it is a compromise.
    The 2002 also has a more instant and linear accelerator pedal response. I'm hoping this has improved in the 2010, and that the ECO mode response more closely matches the Gen I. Gen I was much easier to "manage" electric mode or warp stealth by pedal modulation alone.
    Inverter has always had a separate cooling system from the engine. The two need to be managed at different operating temperatures. What's changed is direct cooling vs. heat-sink to water cooling of the components. This was displayed in one of the videos at PCD.
  3. kiwibruce
    kiwibruce Junior Member
    46
    Katikati, New Zealand
    I love my 2006, but that having been said, I would love to trade up to the 2010 one day. Both specs and shape appeal to me (41, married, 2 kids) so go figure!
  4. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    And this is why people should just ignore the trolls. Now the original trolls post gets deleted and we still have a quote of it with a reply that now really doesnt mean anything.
    Please people, just let the trolls say what they want. Replying makes no sense since they are idiots to begin with and just makes the clean up harder for the mods. If no one answers them, the mods could just delete their posts and the thread would continue like nothing happened.
    ok, rant off, sorry...
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    This might bring down the fun banter on this topic, but car looks are only somewhat important.
    Comfort has jumped very high on my list since test driving other small-midsize Japanese cars like Honda Civics and Mazda3 - 5's both of which accomodate tall drivers very well with generous legspace and telescoping steering wheel.
    I heard someone mention the 2010 driver's seat only slides back 1" further than the Gen2. Hope not.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It definitely does go back more, but how much I do not know. I know that compared to my 06' the 2010 had what seemed like a LOT more more though; My legs were almost straight to the gas pedal and not bent at the knee like they are now in the 06'.
    Also, I know they say there is more rear seat leg room. Oddly enough, with the drivers seat back all the way in the 2010 my knees were just about to hit the back of the seat. Whereas in my 06' my knees have a bit more room in the back. Now maybe the seat back itself was back a little more but I tried to set the drivers seat same as in my 06'. In the rear, headroom is improved quite a bit in the 2010. Moving the roofline back those 3.9" really helped headroom in the rear IMO.
  8. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I didn't measure (how would you do this anyway -- distance between the vertical line of the front of the seat back and the brake and accelerator pedals?), but I estimate that it slides 3" to 4" further back than the Gen2. In any event, I think it's got to be at least 2" further back.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    If there are obviously more attractive ways to get a 0.25CD then maybe you can name one other manufacturer who has used those obvious and more attractive ways to build a 4 door car with a CD of 0.25 or lower?
    Sorry, I can't think of any.
    By the way, I love the style for how it looks not the aero number.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Forty feet long and shaped like a cigar.
    Tom
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    But that's ok to me ... as driver, you can get the good legspace for 95% of the time. The other 5%, you collect $$ to move the seat forward. Win, win :cool:
    Boo & dox, thanks for the info... sounds promising.
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Hehe, yeah, win win. Since 99% of the time it's either my parents or my wife and son in the back, and they're shorter than me anyways, I can't wait to finally have more leg room for myself while driving...
    And like I mentioned, the only reason I may have thought the back was a tad closer 'knee-room-wise' was because I had the back of the seat reclined one click more than I am used to in my car now... Tried to keep it the same but ya' never know... Also, since the seat in the 2010 has vertical adjustments, that could have played into it as well...
    Just saw your reply earlier Tom and yeah, considering the amount of leg room gained while in the drivers seat I'd guess minimum 2" as well, maybe even more... It was quite noticable.
  13. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Are you implying that you're looking dated too, Pat!!
  14. ronhowell
    681
    32
    Cypress, CA.
    No different than here in the Los Angeles area. Who enters a freeway on-ramp at 0 mph and exits at 60 mph? As far as I am concerned, it is a meaningless statistic that far to few people have questioned the relevance of over the years. What matters more, especially in merging freeway traffic, is probably 25-55 mph times, together with a driver's timing ability, which only comes with practice. I find my Prius perfectly capable of merging with the flow of freeway traffic without problems.
    It is true that sometimes you have to have the confidence to intimidate idiots in SUVs (though not 18-wheelers!) speeding in the freeway slow lane, when they should be aware of possible entering on-ramp traffic. If they rear-end you, they are the one's responsible.
  15. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Whoops, did I come on too strong? I just don't think it's pretty or cool in that way. Seems a little funny to me to talk about it as if it were or was intended to be. I did try to acknowledge the design challenge. It is an incredible amount of interior space in such a small footprint. With that challenge, it was bound to be a bit bulbous. As far as naming aesthetic competitors, I'm not a gearhead, so I can't really help you. I'm not even sure a couple of points on the cd scale really make that much of a difference. Must be at least a couple of BMWs that come close though... or maybe that new Telsa sedan? In any case, I'll defer to your superior fashion sense..:D
  16. danl
    danl New Member
    231
    Boston, MA
    I'm in the same boat as the OP. I think the 2004 looks better than than 2010. I think it looks like what a knock off would look like, sorta like what kia or hyundai would come up with. Hopefully it looks better in person.
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I really think the 2010 Prius looks more functional than the Gen2.
    The extended peak of roofline, backwards ... clearly says this new Prius has more headroom in the backseats. Many small families with teens or soon to be teens, 'growing like a weed', will be glad to get a car with more rear headroom.
    The Gen2 car is certainly lacking in headroom for anyone near 6ft, I think.
    I also like the extension of plastic front fascia below the hood. This makes the metal hood less susceptible to rock chips. Not that plastic doesn't chip, but I seem to feel worse about getting rock chips in metal than in plastic.
    The Gen3 Prius will bring many into first time hybrid ownership, and I think it will be phenomenal success.
  18. hntr467
    hntr467 New Member
    22
    Rockford, IL
    I think the visual appeal of any car is subjective and unique to the individual. That's why there are some cars that I would never desire owning, driving, and in some cases even looking at with more than a glance. My personal opinion of the 2010 Prius is that it does look much better in person, especially some of the front end views.
    Like I said in a previous posting, the 2010 we are buying is for my wife. It'll be her car, and we hope to get one in May or June since our daughter will start driving my wife's current car. She's picking it out, but I have to say I like it too. If I were picking out the car, it would be the 2010 Camaro SS (keeping it under $40,000.00) we sat in at the Chicago Auto show. Now that will be a car you can race the SUVs with...lol.
    As far as I'm concerned too many people feel compelled to try to get ahead of another driver instead of simply merging in behind...especially when the other driver is speeding or driving aggressively. I've driven 2008s and 2009s, and both were quite capable of attaining highway speeds easily. No doubt the 2010 will do so too. But, if you really feel compelled to race SUVs and others, I'd suggest the 400 hp Camaro instead of a Prius. ;)
  19. Radon
    Radon New Member
    120
    Vancouver
    I think it also depends on whether you already own a pius or not. You get used to a shape and look for a car. I myself like the new Prius more than the old one it has more edges which break up the panels.
  20. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    This.
    When discussing logo's as plus or a minus in buying a vehicle is almost as bad as the 3 min wasted in responding to a molehill issue. 3 min of my life gone....dumb. :(
