Why do i have a spike in my engine temperature???
Discussion in 'Gen 2 Prius Technical Discussion' started by BillMelder, May 18, 2024.
  1. BillMelder
    BillMelder Junior Member
    24
    Tennessee
    Hi there!
    Let me first say that about 6 months ago i flushed my entire coolant system. Used OEM fluid and did it by the instructions in haynes manual.
    I own several gen 2s and im just now experimenting with Hybird Assistant App. Today i ran a report and i was shocked to see a spike in my engine temperature. Anyone know what may cause this?
    Ive attached all the screenshots from Hybird Assistant so you can give me some feedback. I know my hyburd battery is shot. Ill be buying a new battery next week. My main concern is the spike in temperature. You can see that in the attached screenshots.
    btw:
    2009 Toyota Prius
    189k
    Great running condition???
    I haven't had any issues but i want to address any problems before they become BIG problems!
    Thank you!
    Screenshot_2024-05-18-09-56-50-528.jpg Screenshot_2024-05-18-09-56-58-389.jpg Screenshot_2024-05-18-09-57-02-178.jpg Screenshot_2024-05-18-09-57-05-432.jpg Screenshot_2024-05-18-09-57-07-929.jpg Screenshot_2024-05-18-09-57-14-425.jpg Screenshot_2024-05-18-09-57-10-685.jpg Screenshot_2024-05-18-09-57-16-889.jpg Screenshot_2024-05-18-09-57-26-056.jpg Screenshot_2024-05-18-09-57-22-052.jpg Screenshot_2024-05-18-09-57-29-826.jpg Screenshot_2024-05-18-09-57-32-895.jpg Screenshot_2024-05-18-09-57-35-546.jpg Screenshot_2024-05-18-09-57-43-170.jpg Screenshot_2024-05-18-09-57-48-958.jpg Screenshot_2024-05-18-09-57-38-213.jpg Screenshot_2024-05-18-09-57-52-805.jpg Screenshot_2024-05-18-09-57-55-812.jpg Screenshot_2024-05-18-09-57-58-428.jpg Screenshot_2024-05-18-09-58-11-058.jpg Screenshot_2024-05-18-09-58-24-034.jpg Screenshot_2024-05-18-09-58-02-312.jpg Screenshot_2024-05-18-09-58-28-347.jpg Screenshot_2024-05-18-09-58-39-025.jpg Screenshot_2024-05-18-09-58-45-710.jpg Screenshot_2024-05-18-09-58-52-019.jpg
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    I didn't look at your report... But with high coolant temps the first step I'd reccomend is taking off your radiator cap when engine hasn't yet been started for the day and top it off. Do that a few days in a row it usually addresses these symptoms, unless you have a leak or a bad engine coolant pump.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    What you see in the report is some kind of glitch.
    At the exact time that the ECT temperature graph spikes up to 240°, the short and long term fuel trim numbers spike down to (-)90% ; that's not good data as those values are not valid.
    I'll assume it's a software (app) glitch.
    Also, actual ECT is not going to immediately jump by 60° for 10 seconds then drop. An intermittent electrical fault (short circuit) usually pegs the reading at 256°+ and sets a fault code.
    #3 mr_guy_mann, May 21, 2024
    memory and Brian1954 like this.
