Why do I only get around 380 miles range for my Prius 2020 XLE AWD?
Discussion in 'Gen 4 Prius Technical Discussion' started by Tianen Chen, Mar 11, 2022.
  1. Tianen Chen
    Tianen Chen Junior Member
    43
    United States
    2020 Prius
    XLE AWD-e
    Sounds like you are driving at country-dirt road with a roof box on top.
    51,932
    i'm not aware of any testing that has shown slow acceleration to be less frugal than fast acceleration.
    there is an efficiency curve for an engine though, if you can find it.
    iirc, it was around 2,000 rpm on the gen2 engine, part of a pulse and glide study
  3. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    Thanks. I’ll check my alignment, too.
  4. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    It looks like my alignment is indeed off as suspected.
  5. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I believe that correcting rear alignment requires shims (It did in the Gen2 Prius). A good alignment shop should be able to fix your Prius.
    JeffD
    amos likes this.
  6. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    I got my alignment fixed for $157 from Rogers Toyota of Lewiston, ID.
  7. bisco
    51,932
    excellent. it will hopefully improve your mpg's
  8. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Tire tread life, too.
  9. Mendel Leisk
    41,452
    Wayne Gerdes (CleanMPG) was saying, when accelerating, sweet spot on the HSD is 1/2 to 3/4. At least on level roads; on hills you’ve got to go into the red power zone to keep the speedo moving up.
    jerrymildred and Tideland Prius like this.
  10. Billy56
    Billy56 Member
    73
    71
    Seattle, WA
    2020 Prius
    L Eco
    If you are only getting 47 MPG, you need some serious training on methods of hypermiling......if you really desire to improve. There are tons of tips and techniques here on Priuschat and also on cleanmpg. Your car is capable of about 80 mpg....
