Why do I plug in?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Kyle4858, Sep 14, 2013.
  1. Kyle4858
    Kyle4858 Junior Member
    NY
    2013 Prius Plug-in
    I've had my PIP for about 6 months and have started to notice the following. When I charge up (costing $$$) I get about 16 miles of nice flat suburban driving. I started to notice and pay attention to my trips. If I have expended all my EV range and drive around about 25-30mph city driving I'm still driving around in electric. I realize my ICE comes on for a short time during the warm up, but I'm still cruising around for 5 to 10 miles on electric or however long my short trips are when I run errands and if I'm careful and keep the bar below the 50% mark on the display I still average 200 or sometimes 300mpg every trip even with the ICE turning on after the first 5 seconds or so.
    I know gas is more expensive than electricity, but it seems to me to be cheaper to run the ICE for a minute then cruise around on electric at about 25mph in ECO mode with an EV range of zero that to plug in at my house for 2 1/2 hours.
    Does it make economic sense to plug in for short 5 to 10 mile trips if I'm going to keep it around 25 mph and run on electric in ECO mode? Thank you for any input.
    52,536
    you're way, way, way off. if you don't plug in, no way you're gonna get 2-300 mpg. try it and get back to us. unless you're paying more than .30 a kwh or so, you're better off plugging in.
    lensovet likes this.
  3. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I think you are assuming that in HV mode, if you stay in the ECO zone, you're on all electric. You aren't, the engine is just very quiet in that zone. You are probably getting 50-70 mpg in that mode. Great mileage, but still nowhere as efficient as plugging in.
  4. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    If you are always driving short, 20-30mph trips you should get a NEV not a PiP.
  5. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    After the EV battery depletes and it switches to HV, the Battery still has some energy. The ICE, after warmup, will stay off if you keep it to the left of the HV Bar until the Battery hit the bottom. Then the ICE starts to add enough energy to the battery to get it off the bottom.
  6. lensovet
    2,615
    496
    Burlington, NJ
    If you putz around as gently in EV mode as you do in HV mode to keep the car in EV (less than 50% of the bar), you'll get way more than 16 miles. Retired499 got something like 30 miles once.
    Sorry but physics is physics.
  7. markabele
    5,084
    1,782
    Nebraska
    21.x I believe. Most of us think it is theoretically possible to hit 24 or 25 with all conditions being perfect.
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    There should be a "training wheels" mode in the PiP. For the first 2000 miles it only operates in HV with the usual computer selected EV/non-EV below 42 mph. That way you will learn how to effectively drive the PiP without charging, 45 mpg "just driving" or 50+ mpg with a little educated effort. After the 2000 miles, when you do plug-in you will truly appreciate the PiP. If you are a previous Prius owner or plead with the dealer the training wheels mode can be turned off (like the reverse beeps).
    I owned a standard Prius for 5000 miles before purchasing the PiP. While that was the expensive way to get there it helped me understand the value of the PiP. And the experience helps me get good mileage on long trips.
    SAronian, BCP and lensovet like this.
  9. markabele
    5,084
    1,782
    Nebraska
    haha, good idea! I definitely agree that owning a regular Prius first helps you with some of the more advanced hypermiling techniques that you can't do with any other car, including a regular Prius.
  10. rsb97080
    rsb97080 New Member
    28
    Fortunately for me, electricity is still inexpensive in this region of the country. I can get to work without using any gasoline at all, so it almost cut my fuel cost in half.
  11. bisco
    52,536
    but why plug in when you can get to work on ev without the ice coming on?
  12. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I have.
    Tested it on a one mile flat loop around school grounds @ 17-18mph - 26 miles max with full charge.
  13. markabele
    5,084
    1,782
    Nebraska
    That's awesome. That would have taken you well over an hour.
  14. rsb97080
    rsb97080 New Member
    28
    I can't - one way to work is 14.3 miles.
  15. markabele
    5,084
    1,782
    Nebraska
    Unless they are really fast roads then you should be able to get all the way there in warmer months.
  16. rsb97080
    rsb97080 New Member
    28
    I must have misunderstood what bisco was asking. I can and do make it to work completely on a charge. Plus I haven't noticed a spike in my electric bill since buying the thing in May.
  17. markabele
    5,084
    1,782
    Nebraska
    I agree....I only use 10-15 bucks worth of electricity for the thing every month.
  18. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    If you are happy doing this then continue and save your electric bill. with your range and speed plugging in for more range makes no sense, you do not need more range. I assume from time to time, your driving differs from your usual schedule and then it is worthwhile to plug in / in your case which cost more, Electricity or Gasoline. If electricity is cheaper then plugging in is alway cheaper and better. If the whole charge is not used today, it can be saved for tomorrow. the PIP is essentialy a Hybrid so propulsion is shared constantly with either the EV charge or the remaining basic charge that Gen 1,2 and 3 all have. And both EV sources are continually charging, not counting high speed or big hills. Its like a Bank account, if you dont accept this free deposit that your Bank gives you, then your balance will go down. Not plugging in on a regular basis depletes your overall potential causing the ICE to get busy. ( Two viewpoints in one Para. )
  19. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    It was summer. I coach 10mos a year and the other 2 months I'm bored...
    Had a big iced coffee along, only problem was needing to pee partway through
    markabele likes this.
  20. Andyprius1
    2,327
    859
    Cool CA
    Thats exactly the problem! Bisco. Once I get to work, I dont have enough Ev to get back home.........so....I have to sleep at work........for 4 more days, until it is economically possible to splurge and use the ICE. You ever try sleeping in a solid waste plant?
    BCP, rsb97080, bisco and 2 others like this.
