Why does my battery only charge to 46% in ready mode?
Discussion in 'Gen 2 Prius Main Forum' started by ghostwheel, Jun 15, 2021.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    Why would the car use (waste) fuel to charge up the HV battery any more than minimally needed if you aren't driving any where?
    Everything is designed for mpg- if the car don't go nowhere then you have 0 mpg.
  2. ghostwheel
    ghostwheel Junior Member
    30
    Santa Fe, NM
    Yes, you are right. A part of any energy put into the battery is wasted. I just wish there was a way to adjust that. It would come in handy in other situations - like when I know I'm approaching a mountain and would like a full battery at the bottom. I guess in terms of MPG it probably would still be a waste.
    #22 ghostwheel, Jun 15, 2021
  3. ghostwheel
    30
    Santa Fe, NM
    OK, I ran a Dr Prius test (before doing anything to the battery. I might need for colder weather for doing anything)
    It says 60%, fair condition. Not too bad (well, at least not poor - 40-50%, and not needs replacement soon <40%). I wonder what it'll look like after deep cycling.
    I'd like to understand two things. Maybe one thing. Others have reported slower cycles than what I saw with A/C on. Is it really the battery? And second, it seems the cycling depends on the draw, with the non-intuitive result that smaller draw causes less charging, so less capacity available, and possibly faster ICE cycle. How can I achieve the slowest cycles possible? I'll try to play with it some more.
    #23 ghostwheel, Jun 15, 2021
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    First, "Battery University" is not a real University.......but most of the information there is really good.
    Second, that article is about Nickel Cadmium cells. Which Prius uses that kind of battery ?
    Hint: None.
    Care to try again ??
  5. drone13
    drone13 Active Member
    140
    115
    SoCal
    It would have been great if Toyota engineers had programmed in a camping mode where if the car was stationary and the camping mode button was pushed it would start charging at the normal low level of around 2 bars and continue to continue to charge until a 60 or 70% charge at a low rpm on the ICE. It wouldn't matter if your HV pack was new or getting tired, it would provide a much longer no charge period than the logic used now. Of course the ICE would run longer too, but at low RPMs that wouldn't bother me much. I would love a feature like this for when I have to pull over and work with a client for 45 minutes on my cell phone with the A/C blasting.
  6. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    They've done it. There's a "Room Mode" on some of their newest hybrids. I'm not aware of any plan to retrofit the feature into older ones.
