Why does my current range with a fresh charge keep creeping up ?
Discussion in 'Prime Fuel Economy & EV Range' started by I'mJp, Feb 8, 2017.
  1. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Day one after charge - range = 25 miles
    A few days later 26.5
    then 27.5
    today 29
    But it's the same battery ?
    Whats up ?
    dalcon95 and priuscatprimeguy like this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Temperature will do that
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Lots of possible factors, such as:
    • Are (outdoor) temperatures moderating, requiring less power to go to the heat pump?
    • Are your driving habits becoming more conservative?
    • Has traffic gotten less congested, meaning less time stopped in traffic burning climate-control, to go the same distance
    Temperatures rising can have the effect of inflating the tires slightly (pressure goes up with temperature), which can improve mileage a bit.
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I put a small space heater in the cabin with a timer, that pre-heats. So car heating is turned off.
    Traffic has random variations, nothing too noticeable.
    Is it making a prediction based on my driving habits ?
    Yes, I've been experimenting with hyper milling, learning the new car.
    So my own antics is altering the predicated millage on the battery ?
    Krap, I hate when I do that. I guess I was hoping that the car was discovering it's own capacity.
    jp
  5. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    I started with 27 point something EV miles after first charge in late November, now up to 33.9 EV miles after charge.
    Indicating 93% EV usage on vehicle.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    Some batteries need a few charging cycles before they deliver their full capabilities. Just another possibility...
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Yes and yes.
  8. icespide
    icespide New Member
    San Jose
    I've experienced this as well. my first charge up estimated 24 miles of range while yesterday when I was fully charged it estimated 30
  9. bisco
    52,855
    if it didn't, it would be even more useless than it already is.
    vvillovv likes this.
  10. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    It means you were not satisfied with the initial number so you drove slowly and more carefully. Then the car noticed. It changes the number. In my case I disregard the number and drive whatever style I prefer. The number actually creeps up a bit, still.
  11. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    25 miles EV range is the default range when the car is new. When you start driving the car depending on how fast you go and for how long at that speed could be lower than Toyota's default EV range speed. Toyota probably learned their lesson when on the 2012-2015 PIP the EV range would creep downward.
  12. Mendel Leisk
    42,345
    Admit it: you're gloating, lol.
    Seriously, the main thing that's changing is the car's estimation of range, it's revising it's defaults to suit your driving style. Sounds like you're doing good things, though.
    priuscatprimeguy likes this.
  13. bwilson4web
    16,535
    The trick will be to measure the kWh put in the car after the estimated range settles. But this means my 'rule of thumb', 10 mi/hour, is likely to increase to 12 mi/hour. The reason this is important is the Plus trim does not appear to have a wireless link to monitor the SOC. So I use an iPhone timer to know when it is done.
  14. Ken77
    Ken77 Junior Member
    Wisconsin
    Could the improvement be due to the predictive stoping feature? I understand the navigation system accumulates a record of past stops and then the car can do a better job at regenerative breaking when you approach those stops each time after that. We'll be picking up our Prime this weekend and I'm interested in learning more on how that feature helps improve efficiency.
  15. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The only accurate way to check battery capacity is to meter the charge it can accept (hold) by an external meter. If you plan to do this, best accuracy will be achieved when measurements are taken from same starting SOC point and same temp.
