Why does my trip and mpg keep resetting?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Aug 8, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    Ok so this is the 2nd time this has happened
    This week I got my car tinted.
    When I picked it up both my trip, avg mpg and miles next to the avg have been reset
    I literally just went into a store and came out and my avg mpg and trio had been reset
    I hit nothing to make this happened and just turned the car on...
    Why is this happening?
    #1 Banksy, Aug 8, 2020
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Could be that you have a loose connection somewhere.....maybe at the battery.
    SFO likes this.
  3. Banksy
    415
    133
    Well since I picked it up and this happened the car has ran over 150 miles.
    I just checked the connection on the battery. Negative called was loose tightened that and positive cable
    Voltage looks fine on the 12V too
    52,787
    when they tint your windows, they usually leave the car on and run down the 12v. then they jump it, recharge it and give it back to you
    Banksy likes this.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes, and.......
    Loose electrical connections are often intermittent.
    Banksy likes this.
