Why does non-synthetic oil still exist?
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Nov 13, 2025.
Tags:
  1. Prodigyplace
    12,720
    11,852
    Central Virginia
    i use it in my tractor that has an engine designed in the 1940's. Yes, fuel is gravity fed and it uses a generator to charge the battery. Plugs, points. coil & distributor too.
  2. PriusCamper
    PriusCamper Senior Member
    13,479
    5,446
    Pacific Northwest, USA
    To your point, the real problem starts with William Patterson who created debt-based government financing when he created the Bank Of England in 1694:
  3. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    That's why I buy it.
    May I subscribe to your newsletter?
  4. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Fewer oil changes is not a hardship.
  5. PriusCamper
    13,479
    5,446
    I guess that means I'll have to start a newsletter? What would you like the newsletter to be about?
  6. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I guess you didn't know your chain was being jerked a little.
  7. PriusCamper
    13,479
    5,446
    I guess you didn't know I jerking their chain back little? :)
  8. fuzzy1
    10,724
    Likewise.
    At least in the U.S., that is no reason to ban any ordinary consumer product. Tons of much worse products stay on the market.
    Prodigyplace likes this.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Nice try.
  10. Mendel Leisk
    42,386
    Seriously? That's fairly myopic.
    Regarding automotive fluids that should be outlawed, I'd nominate stop-leak products for engine coolant.
  11. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It could be argued that non-synthetics cause premature engine wear.
    PriusCamper likes this.
  12. hill
    9,047
    Similarly it could be argued that NOT changing your oil often enough, causes premature engine wear - regardless whether it's synthetic or conventional. Heck for that matter, people that are picky must REALLY have fits if they discover reclaimed (re-refined) motor oil is still in use. When we were kids, poor side of town, that's all many folks could afford for an oil change. Modernly, crude costs versus the labor necessary to clean old oil (add additives) is such that the reclaimed market goes to other sources rather than the automotive crankcase.
    #32 hill, Nov 14, 2025
  13. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I have stretched oil changes to as much as twice a year using synthetics, with no ill effects that I could see. I haven't had an engine wear out in over 30 years, and some of them have gone over 300k.
  14. Mendel Leisk
    42,386
  15. bisco
    52,927
    LOL, can we go back to arguing what constitutes a hybrid? :cool:
    hill and Prodigyplace like this.
  16. Gokhan
    Gokhan Senior Member
    6,722
    2,672
    Paramount CA
    Moreover, 0W-16 and 0W-8, which are what Gen 5 specifies, only exist as a full synthetic anyway. That is because the more volatile conventional base oils cannot meet the 15% maximum for Noack volatility in API/ILSAC when they are that thin.
    #36 Gokhan, Nov 14, 2025
    Blackat likes this.
  17. Gokhan
    6,722
    2,672
    Paramount CA
    Regarding synthetic vs. conventional, you first need to understand what it means. It is too long to discuss here. But rest assured that today’s conventional base oils are of very high quality. They are Group II as opposed to Group III, and they are only marginally worse in oxidation resistance, which is made up to a large extent by the antioxidants in the additive package anyway.
    You will not get less wear with a synthetic oil, period, which is determined by the oil viscosity and additive package. Synthetic base oils in fact sometimes result in somewhat higher wear than conventional base oils. The main advantage of synthetic oils is that they might allow longer oil-change intervals due to higher oxidation resistance of the base oil, but this is probably only the case if they also come with a high antioxidant content, such as in “extended performance” oils.
    Last but not least, all 0W-16 and 0W-8 oils as well as virtually all 0W-20 oils are synthetic (Group III or higher) anyway; so, this is a moot issue. Even thicker grades these days are usually at least semisynthetic due to ever stringent requirements on Noack volatility. Truly conventional oils, which have a Group I base oil, no longer exist in North America, but you might find them in Mexico.
  18. Tideland Prius
    16,684
    Thread clean up
  19. bisco
    52,927
    were you able to get the vomit stains out of the rug? :cool:
  20. hill
    9,047
    Gasoline is an enemy of oil. It's like a solvent. That blow by is just waiting to help it break down. In a converted Econoline van set up to run strictly on propane? That oil stayed clean for unbelievably long times. That was in the early '70s, when conventional oil 38 was pretty much the main stay of most autos. That sucker ran for well into the six digits on the odometer
    #40 hill, Nov 15, 2025
