Why does the 12v drain so easily?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Heather Lombardi, Feb 26, 2018.
  1. Heather Lombardi
    Heather Lombardi New Member
    New York
    2014 Prius c
    I have a 2014 Prius C. We live in Upstate NY and from the first winter onward, if the car sat for about a week I couldn't start the car. Now, the battery drains if it sits for more than 1 day; so I know it is probably time to replace it. But why does it drain so easily?
    And if the 12v doesn't start the car, why won't the car start if the 12v is drained? Once the car is started, the hybrid battery often shows fully charged.
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    The 12v.battery is about the same as a motorcycle battery so it doesn't have much capacity. It's use during start up is to just power up the computers so it doesn't need much juice. If it goes dead in a week it's probably shot, just replace it.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Not sure about all Prii, but Gen2 has a relatively slow 12v charge rate when the car is running, so you really need a good hour or more to really bring it up if it got too low.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    (1) Use a battery-maintainer when the car is parked for a long time without running.
    and/or
    (2) invest in a jump-starter pack
    There are lots of threads on PriusChat about (1) and (2) - search can be very useful! (I'll leave that as a good exercise for you, since I already know how to use search!) ;)
    BTW Welcome to PriusChat!
    j12piprius likes this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Cold is an enemy to all batteries, not so much because the battery is weaker, but because everything is harder. Oil is thicker, Transmission fluid is thicker, etc. The fans are all running, often the wipers are too.
    The 12 volt battery does not turn the engine, but it powers the computers. The computers decide if they will allow the use of the HV Battery, which starts the engine. You really want all the tests to come back perfect before you allow high voltage out of that battery.
    #5 JimboPalmer, Feb 26, 2018
    WilDavis likes this.
  6. bisco
    52,793
    the battery was likely defective when you purchased the car. many dealers let them go dead on the lot, which severely damages them.
    my 3 prius have been left up to 7 weeks in the winter with no starting issues when we got home from vacation.
    Prodigyplace likes this.
  7. Pamela Yates
    Pamela Yates New Member
    Gresham, OR
    2014 Prius c
    I am having similar problems but I live in Oregon where it's typically very mild. I use my Prius C for errands, like grocery store, etc. It's a 2014 with low mileage and ran fine until just before Christmas 2017. I had it jumped then and it ran until February 8. I had it jumped again and took it to the dealership. The first guy I encountered in service just said I don't drive it enough. That's ridiculous. Even if I don't drive it for a few days, I go out and run the engine. I'm painfully careful not to leave anything on at all. The battery indicator shows it's topped off.
    So last Friday, March 2, it didn't start. again. I have noticed that when the car doesn't start, the events are as follows: I push down on the brake as far as it goes, but it doesn't go to the floor. Then I push start and the heads up display flashes, the brake depresses to the floor, then everything dies. The car just whines for awhile after that, even when I turn it off again. Now it's completely inert in the garage.
    The service guy didn't even offer to check the battery, probably because it's awkwardly located under the back seat which I didn't realize until then (since the jump point is under the hood). However, when I bought the car brand new, it had to be jumped in the showroom. My husband asked if it was going to be a problem for it to sit awhile between trips since he knew I'd probably only drive it once or twice a week around my area. They said there would be no problem with that, it was just low from being looked at without the engine turned on. If I had known about the battery issues, I would have bought a Corolla. I've complained to Toyota USA but they've just passed me to the dealership who has yet to show any interest. Now since the battery has been jumped at least 3 times that I know of, it's probably shot. Oh, and the heads up display never gives any hints that the battery is low or otherwise problematic. We have a 2011 Prius that never has any problems (and others before that). It seems it's the Prius C that doesn't work right. :-(
  8. bisco
    52,793
    welcome!
    the battery indicator is for the hybrid battery, not the 12v. get a new battery, and you'll be fine.
    scona likes this.
  9. Pamela Yates
    Gresham, OR
    2014 Prius c
    Yes, that's what I originally thought but could never find anything specific about the indicator. There certainly doesn't seem to be any warning or idiot light for the 12 V. I took the car in to replace the battery last Wednesday and it's still there. Why? Because there's a battery shortage and they have to wait for the factory to build new ones! Unbelievable. I can only surmise that these batteries need replacing a lot. Now I wonder if I should trade it while it has low miles.
  10. bisco
    52,793
    trading it might be a good idea. in the meantime, you can get a battery online, or from a local auto part store.
    the o/m has a section on the battery icon, but you are correct, there is no warning for a bad 12v.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    This is a Catch-22, if there was such an indicator, it would be powered by the same 12 bolt battery it is designed to test.
    Toyota Prius Battery Sealed AGM - (2010-2015)
    TOYOTA Prius V Battery. S46b24r. Prius, efi, dohc - 2880021171 | Village Toyota Parts, Homosassa FL
    https://www.ruralking.com/51jis-auto-agm-battery.html?gclid=Cj0KCQjw7Z3VBRC-ARIsAEQifZRQn-7foEKMJRHVkToIYopr05BRFAyC6odTdjzYWHMVyj1EVb4zC1UaAnfhEALw_wcB
    amazon.com/ACDelco-ACDB24R-Advantage-Automotive-Battery/dp/B010GKJ8F6
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 to 2015 , Prius V & Plug-in Prius with Instructions
    There are other batteries. Locally a NAPA or OReilly's auto parts store may have them
    https://www.napaonline.com/en/p/NBP9851P?searchCategory=11.1&searchIndex=App
    https://www.oreillyauto.com/detail/super-start-platinum-5003/battery-accessories-16452/battery---automotive-16864/battery-12836/battery/prius/4742707
  12. Pamela Yates
    Gresham, OR
    2014 Prius c
    As I suspected, there are lots of options. I suspect they are holding my car hostage in hopes I will trade it in. I left a stern message with the service manager and next time I will replace the battery myself. I will get a tickle charger too. Thanks so much for your help.
    Raytheeagle likes this.
  13. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    My 12v is going almost 5 years now, with the past 3 years spent in Wisconsin cold winters. Hopefully it'll go for another year or so.
