Why does the car smell bad when it rains?
Discussion in 'Newbie Forum' started by Richard77, Sep 24, 2022.
  1. Richard77
    Richard77 New Member
    Santa Clara
    This problem has been happening for a while. After every rain, if the car smells bad after the sun is shining, it is useless to turn on the air conditioner. After a few weeks, the odor will disappear. I don't know if it's a problem with the floor mats or the air conditioner filter.
    2017 Toyota Prius Prime
    52,855
    i would pull everything up in the hatch and check for leaks
  3. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Is this a relative new problem or one that has plagued you since new? Does it affect a specific area or does it seem to be concentrated in one area? Before pulling up everything in a specific area and checking for leaks there, this information will help us to give more helpful information.
  4. Mendel Leisk
    42,345
    Do you use the AC a lot? Relentless use can lead to mildew.
  5. shmu
    shmu Junior Member
    cincinnati
    I had a similar problem and fixed it by running ac(to wrung out humidity) and keeping fan mode in non-recirculate(to stop humidity buildup).
    Humidity causes mold. And removing humidity dries off the mold.
  6. Debo160
    Debo160 Junior Member
    MORTH CAROLINA
    Im not sure how this model is but I know the get 2 used to have a issue sometimes where the water would get below the battery area because of a very small crack in the roof and hatch area. I normally clean the hatch and get some flex seal. And spray iron the passenger side of the hatch, all the way up to the small crack area on the roof.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    979
    Monument, Colorado USA
    Is it a mildew smell? Water left on the A/C coils can mildew which can stink. If you don't have a carbon-activated cabin air filter, get the FD157 (Fun Driving) filters on Amazon. ($15 for two) I replace ours yearly and haven't gotten any bad smells.
    Another tip that helps with the smell is to run your fan on HIGH but with the A/C turned off for about 5 minutes whenever you are done driving the car for the day. This helps dry out the water that's on the coils and vents to prevent mold and mildew.
  8. Peter Fanelli
    Peter Fanelli Junior Member
    36
    Smyrna, Tennessee
    Have you tried replacing the cabin air filter?
  9. frankhawkins786
    frankhawkins786 New Member
    US
    2012 Prius+ MPV
    Four Touring
