Why Don't I Get The EPA Mileage?
Discussion in 'Knowledge Base Articles Discussion' started by Tideland Prius, Sep 5, 2007.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  2. brarian
    brarian New Member
    St Joseph, MO
    Re: Why Don't I Get The EPA Mileage?
    I bought a used 2007 Prius in September and got between 48 and 51mpg for the first 6 weeks. Then it dropped to in the area of 42-44mpg. Now i am in the area of 32-33mpg. Took it to the dealer and was told that this was normal for winter driving - cold (20ish) here but no snow. What say you?
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Fill out the gas milage questionaire. 40's are normal in the cold. 30's are normal with agressive driving and/or short trips and/or extreme climate control use.
  4. brarian
    brarian New Member
    St Joseph, MO
    Where do I find the fuel mileage questionnaire? I am definitely not an aggressive driver - the granddaughter will testify to that :).
    Being new today I confess I am having some trouble navagating this site .
  5. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    If you look in the fuel economy section of the GenII discussion area (Gen II Prius Fuel Economy - PriusChat Forums) you will see a couple of "stickies" at the top of the list. These always remain there while the rest of the non-stickies are sorted chronologically by their last post.
    One sticky is: Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
    Make a new thread and follow those guidelines. Feel free to PM me once you get it up.
  6. brarian
    brarian New Member
    St Joseph, MO
    This is my first Toyota and hybrid and it has made me feel like a real idiot. My dad was a GM design engineer and I have dropped a transmission, done a valve job etc - so I am not totally a babe in the woods with cars
  7. tf4624
    tf4624 Active Member
    527
    51
    LOl why is this thread so long..the answer sweet and simple
    EPA-Liers/Controlled testing
    vs real world driving and there are to many factors..
    thats why LOL
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    That has nothing to do with it. Most people beat the EPA mileage because their short test includes the warmpup cycle.
  9. scottyfon
    scottyfon New Member
    White Haven PA
    My 2004 prius gets 40-44 mpg most of the time, with lots of long distance commutes. The ABS system never worked, and three different dealers seem to just reset the dash lights without fixing anything, so "repairs" last only a mile or so, if they were repaired at all. ABS has caused front wheels to drag mercilessly, lowering mpg to 24 mpg, several times when the fragile sensor wires just inside the front tires get broken. I resolder them now, no more replacing them. The right front corner of my car dips hard every time I brake, always did. Worthless lack of traction on wet or snowy roads... all due to bad ABS. Am considering going to Harrys U-Pull It junkyard to get a bunch of control modules for in the fusebox to try swapping them out. And still under warranty! Anybody getting really bad mileage, like suddenly 24, needs to jack the car up and see if wheels are dragging. If so loosen the brake fluid bleeders and retighten them to release pressure on the dragging brake, and turn the car back on and apply the brakes once. If any wheel drags again it's probably those flimsy sensor wires having been broken by ice and snow. Take the wheel off, find and repair the broken wire yourself. The dealers are clueless or they play dumb... I do not know which. They usually try to sell me a new traction battery when an ABS sensor wire is broken. (My traction battery is fine at almost 100,000 miles.) By the way, they are all Americans... it isn't the car, it's the dealerships that I fault for it, and the American rip-off ethic. You get the same with Ford or Chevy dealerships...
  10. Tideland Prius
    16,683
    ABS or braking system? There's a difference. I'm guessing it's the braking system that you have an issue, given the post you wrote up there (plus, why are you posting in multiple places?)
  11. lonninsj
    lonninsj New Member
    It’s a brand new Prius V. According to my trip computer, I’m averaging 25 MPG. I was expecting better than this, but not 40 to 44 MPG because we’re new to the car and just learning how to drive it. We’ve been driving it for short trips of 5 to 10 miles combined city and highway running the heater in severe cold Minnesota winter temperatures: 0 to 10 degrees F. Our average speed is approx. 40 MPH. There is a fair amount of stop and go on flat to gentle terrain. Interestingly, this mileage the same as what I’m currently getting in my 2005 Corolla, and I normally get around 33 MPG in that car. I’m in ‘normal’ mode trying to avoid the ‘power’ zone as much as I can. I’m in ‘D’ not ‘B’
  12. fuzzy1
    10,722
    Please go back to your original post, click on 'Prius v Fuel Economy' (a Forum), click on 'Post New Thread', then start answering the questionnaire that I pointed to.
    The short trips combined with severe cold will slash MPG, especially if you use a lot of cabin heat. But there are other factors that can contribute, and things you can do to help.
    Did the Corolla's 33 mpg also occur on these same short trips and same severe cold? If that was a summer or year-round measure that included longer highway runs, it is not at all comparable.
  13. Zin
    Zin New Member
    Arizona
    image.jpg image.jpg I'm of course new to this as I've recently purchased a 2011 Prius and the 1st thing I've done was reset the trip in order to see how good my MPG was. Well I'm down to half a tank and have traveled 130miles.. (Average of 21.6mpg)What am I doing wrong? Ac is on auto with recirculating vent to hybrid batteries.
    Car info:
    2011 Prius fully loaded (if that means anything? With jbl nav and solar roof.. The works)
    31k miles.
    My worries/story. During the purchase the finance manager knew the lady that traded this car in and let me know that it had sat for 2-3 years because her husband got sick. In this time he had a tragedy and car NEVER got used until one day she said "it was time to let go of sentimental car" so she traded this in. I got "told" that I have to let the battery charge up with time it'll get better from the dealer because I noticed the hybrid batteries get drained out within 20miles of 3/4 charge. As I look more into this I've found that you should NEVER deplete your hybrid system right? What I'm getting at is... Now I'm NOT feeling comfortable knowing that happened and looking to push for a new hybrid batteries with the dealer cause of it, Any help/recommendations would be great!!
    Ps. I have a feeling because the car was in such great shape they felt nothing would be wrong with the hybrid system and never bothered to check.
  14. bisco
    52,891
    what you're doing wrong: panicking. fill the tank to first click, drive until 2 pips left on the gas gauge, refill to first click and repeat a few times. calculate you average mpg over the total miles driven and report back here.
    you can't 'deplete the hybrid system', the car takes care of itself. the only thing you might want to do is check the 12 volt battery health. all the best!(y)
  15. fuzzy1
    10,722
    Please fill out this questionnaire and post as many answers as practical. That will give us many more clues to help guide feedback:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    Is that what the dashboard display says? Or did you calculate that by assuming 'half a tank' means 6 gallons burned? If the later, that is incorrect because it the gauge is not even close to 'ideal'.
    AC on Auto, with temperature LO, can consumer significant fuel in hot conditions. If you can stay reasonably comfortable with the fan turned down a ways, and the set temperature boosted to something in the 76 - 80 range, it will burn less fuel. You may want to redirect some of the vent air directly towards you.
    Not an issue. In city traffic, it may deplete relatively quickly, just a few miles, if the traffic conditions have you using mostly electric mode. But the computers won't let it drop below 2 bars, instead firing up the gas engine to recharge.
    Don't intentionally try to use electric mode until you know the car better. Many neophytes overdo it and hurt overall MPG. The car is already quite smart about when to use electric of gas, and it takes some practice in order to do better. Remember, this is not an electric car. Drive 'normally' for a tank or two to get a baseline, before trying to outsmart the computer.
  16. Tideland Prius
    16,683
    I think Zin's issue is that the Prius sat for 2-3 years without being driven. The NiMH will be drained in that time. Zin's just worried about a potential battery replacement down the road because of this incident that may or may not have shorten the HV battery's life.
    It is warranted for 8 years/100,000 miles from the original in-service date. so he only has half of the warranty left (~4 years)
  17. bisco
    52,891
    if that's the case, how does he find out? would shortened life affect current mpg's? no lites or codes.
    i wonder how the lady got it started and to the dealer?
  18. Tideland Prius
    16,683
    Not sure how he can check cause a system check will just check the current state of the battery. You'll probably notice a drop in mpg as the battery starts to fail or prematurely age. (Just like our Gen 2's battery drains faster now than when it was new so you will use more fuel)
    Probably a tow to the dealer.
  19. bisco
    52,891
    so, do you think his 21.6 mpg qualifies?
  20. Tideland Prius
    16,683
    Yup. We're at 39mpg on the Gen 2 but it's short trips in hilly terrain. I'm getting 47mpg in a similar commute on the Gen 3. It can still get 45mpg on more mileage-friendly routes (i.e. flat or rolling terrain) compared to 55mpg+ on the Gen 3.
