Why don't you like the large format screen in the Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by Turquo, Jul 7, 2020.
  1. Turquo
    Turquo Junior Member
    17
    2017 Prius v wagon
    Thanks everyone for some very interesting replies
    I'll let you know what I do. I'm looking at the Prime now - at first I just laughed it off with its 25 mile range, but then I realised how many journeys are actually under that, and there's always the gas engine once you get to 25 anyway. Plus the quick recharge
    Is this screen the same as the one in the Prius 4 Touring? They look similar
    mr88cet likes this.
  2. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Can a mirror my Android phone to that big touch screen?
  3. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    The 25 miles is a nominal estimate. My experience is that the number will be more like 21 miles in 20° F winter weather and more like 33 miles at 80° F in the summer.
    The heat pump is reasonably efficient but its use will somewhat reduce your electric driving range. It is less of a drain on the battery in summer when you're just trying to lower the cabin temperature 15° F from 90° F outside to a comfortable 75° F inside. It has to work a lot harder in winter when the desired temperature differential is much larger -- like maintaining a cabin temperature of 65° F when it's only 20° F outside. (Of course, if you do run the gasoline engine during winter driving, it provides plenty of heat even in the coldest weather.)
    And, yes, with a Level 2 EVSE (charger) drawing 15 amps at 240 volts, it takes just a little over two hours to fully recharge the traction battery. More likely, Mrs Bear or I make a five mile trip each way to our nearest Costco (ten miles total), plug the car in when we get home, and it's often close to fully re-charged before we've finished unloading everything and putting away the groceries.[/QUOTE]
    #43 Old Bear, Jul 10, 2020
    Tideland Prius likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    No. No mirroring for iPhone nor Android in pre2019 models. For the 2020 model Apple car play can be used but not Android Auto. I am not sure how Apple Car Play displays on the large screen. I don't have a large screen on my 2020 LE, and I don't have iPhone.
  5. Tideland Prius
    16,683
    CarPlay displays just on the top half of the screen.
    There’s a rumour that AndroidAuto might be coming for the 2021 model year
    Salamander_King likes this.
  6. Gokhan
    Gokhan Senior Member
    6,717
    2,672
    Paramount CA
    Unfortunately I think Toyota has confirmed that the Denso unit (11.6-inch unit) is not compatible with Android Auto. I read it somewhere recently.
    The 7.0-inch unit is made by Denso Ten (formerly Fujitsu Ten).
    I don't know why Denso and Denso Ten make audio units separately, even though the former is the parent company of the latter.
    #46 Gokhan, Jul 10, 2020
  7. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I confess I’m not familiar with the current Prius 4 Touring (although we also own the 2009 equivalent of that), but I do know that the big screen was introduced on the P.Prime originally. It may or may not have been incorporated into other, more-recent Toyotas.
    So, just to make sure there’s no confusion, you can re-charge in a little over 2 hours on 240V (AKA “level 2”)
    or around 5 hours on 120V. Whether that qualifies as “quick” depends upon the particular circumstances, not surprisingly.
    Yes, I at least am ~95% EV in town. In my particular case though, that’s partly because we invested in a Level-2 charger in the garage, and because we have chargers at my place of work (19 miles from home). Most Americans though live closer to work than I do.
    I believe the Prius Prime is intended to be one other thing more fundamentally than a plug-in hybrid: it’s above all else simply a super-efficient, easy-going, daily-driving, commuter car. So, even if you use the engine from time to time, it’s still, above all else, a really really efficient car!
    It’s worth mentioning that with a 25-mile battery, driving it as much as I do on electric, I charge-cycle it a lot. So, I accept that its battery is not likely to last as long as a pure-EV with a large, liquid-cooled battery.
  8. Salamander_King
    11,024
    8,980
    New England
    Can it mirror only in landscape orientation?
  9. Tideland Prius
    16,683
    Yes. The bottom half is either the climate menu or the Energy Monitor.
  10. Turquo
    17
    2017 Prius v wagon
    I did drive one yesterday and I have to say it's quite a nice vehicle. As for the screen, I forgot to check for glare, though I didn't notice any, so maybe not an issue for me. I did think it was a little blurry though, almost like when your monitor steps down a level to VGA. Oddly it seemed sharper when in Maps only mode
    Of course I'm now thinking of all the things I didn't or couldn't check: like I was never able to get it into EV mode and I looked at the HUD, ut didn't see anything (I'm assuming it works in the daytime) then when I got home I remembered the HUD switch down by the knee panel. Doh! I also forgot to look at where the charging port is
    Liek I said though, quite a nice vehicle
    Sarge and jerrymildred like this.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I only get it when the sun is low, behind me, and off to the right side coming in through the right rear door window.
    It is. From discussions here, it seems like it has good enough resolution but it's trying to up-convert lower resolution images. 4K TVs do that with HD content, but do a much better job of it.
    On the opposite side from the gas tank door.
    In my opinion, it's the best car I've ever had, but it does have some quirks that are probably extra irritating since they are such a contrast to the excellence in other areas.
    KCWhitney and Mendel Leisk like this.
  12. Mendel Leisk
    42,373
    Totally absurd, but I like to picture the car developing, firming up as it rolls along the assembly line, and near the end there's this guy, he says "Hey, where do you think you're going; you can't roll off the assembly line without quirks and irritants. Lessee...".
    jerrymildred likes this.
  13. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    They corrected that on the 2020 Prime.
    I love the bigger screen and have only had a couple restarts since buying last Fall. Other than a little glare it’s great.
    GSK likes this.
  14. Salamander_King
    11,024
    8,980
    New England
    What do you mean? AFAIK, no changes in 2020.
    schja01 likes this.
  15. Prim.e.xample
    164
    107
    Indiana
    2020 Prius Prime
    Sorry, I meant it had physical controls (not knobs).
  16. Salamander_King
    11,024
    8,980
    New England
    You mean touch screen controls? Yeah, it was that way from 2017 on. No change.
    I switched from 11.6" screen in my 2017 PRIME Premium to a smaller screen with physical knobs in 2020 PRIME LE exactly for that reason. In my climate, I need to wear very heavy work gloves during winter, being able to turn on and off heat and temp with gloved hand (sometimes mittens) is essential. I can't do that with touch screen switches.
    #56 Salamander_King, Jul 16, 2020
    Joe Cowie and jerrymildred like this.
  17. TonyaNorway
    TonyaNorway Junior Member
    Norway
    The big screen was one of the reasons I decided to order a Prime without actually seeing one first and I must say I was slightly disappointed when it came with a small screen.
    Large screens are not fitted to the Prime in Europe and the EnTune system is not available here either.
    But I did get the keyfob recoded at Toyota so I can trigger the AC/heating & can close the windows remotely.
    I was surprised that I couldn't control the cabin temp by voice command like I used to do with my previous Prius and the Infotainment software is s-l-o-w to load up the phone contacts and map data.
    The user manual clearly states that I can mirror my Samsung phone to the screen but that feature was never implemented o_O
    The only addition I installed was an Alexa Auto which makes everything so much easier . . . .
  18. correctclick
    correctclick Junior Member
    37
    VA
    2020 Prius Prime
  19. Mendel Leisk
    42,373
    Entertaining, right-on article. And congrats also, for dodging a potential exploding Jalopnik link. (y)
  20. Old Bear
    712
    1,050
    It always surprises me when I hear about the things some people find annoying. It seems to be quite idiosyncratic and varies widely from individual to individual.
    Most of the complaints written about by Jason Torchinsky in his Japlopnik review are quite personal, such as his dislike of the font used in the design of the speedometer display.
    The shifter design has been commented upon in PriusChat on many occasions. Personally, I don't find it a problem because one can easily see the large indicator shown in the display. And figuring out how to make the car go forward or to back-up does not seem particularly mentally challenging even if the markers on the shifter knob include arrows.
    Torchinsky's complaint about the number of small symbols used in the display has some merit -- especially when these symbols are not immediately intuitive. It does take some learning (as in RTFM). But it's like my great uncle who once commented on learning French: "I've been to France and there were small children speaking the language perfectly. How hard can it be?)
    Other things like the beeping in reverse, and when the lane-assist is active, are options which easily can be turned off. (And, contrary to Torchinsky's belief, the reverse beeping is not an exterior warning.)
    I take Torchinsky's column with good humor. It has inspired me to start compiling lists of other products with attributes I find annoying. I am going to start with our new Bosch dishwasher which has five primary cycle settings (Heavy, Auto, Normal, Speed60™, and Rinse), each with a choice of six variations (Extra Scrub, SpeedPerfect™, Half Load, Delicate, Sanitize, and AutoAir™) for a total of 30 possibilities.
    At least it doesn't beep in reverse.
    #60 Old Bear, Jul 18, 2020
