Why I hate dealerships
Discussion in 'Gen 3 Prius Main Forum' started by DTKim, Aug 22, 2020.
  1. DTKim
    DTKim Member
    52
    32
    Starting with a disclaimer that I don’t blame the previous owner at all. This is all on the mechanic at the dealership for work done just prior to my purchase. For reference: 2012 PiP w/ 61k miles.
    A couple days after purchasing the Prius, I noticed a little rattle in the front right. Sounded like a loose panel or something similar. Didn’t really drive it much because we had other cars we drove and I’ve been working from home. I left it alone as we were busy with... life.
    Fast forward a month or so and I was selling my Volt as the Prius PiP was a better option for us now that I wasn’t going into the office for free electricity and NJ electricity rates are high. Plus the family preferred the 3rd gen Prius we used to have so there goes the Volt. I go to PA to meet the buyer first in case they back out. I didn’t want to waste my wife’s time. Deal goes through and I call her to drive the hour to pick me up.
    When she arrives, we look through a local shop and she tells me about the rattle in the front right. I thought it was the light rattle from a few weeks prior. She says it’s loud. I dismiss it, but do test it in the parking lot before we go on our way home. WOW, it was loud. Sounded like a blown strut, but what confused me is that it didn’t handle like it had a blown strut. Now, I’m very familiar with how crappy the suspension is on 3rd gen Prius as we’ve had one before. Worse than the 2nd gen Touring Prius we had, which was just barely tolerable. Granted, the PiP, with the extra weight in back does handle slightly better than a regular 3rd gen, but I already ordered a rear sway bar as it did wonders for our prior 3rd gen. It’s on a two month backorder (so far), but that’s another story...
    Not being able to find anything loose in the parking lot, we drive home and I try to avoid every road imperfection I can on the right side. I do research on PC overnight and best I can find (if not a blown strut/strut mount) was brake pad clips... it wasn’t that light of a sound so I was resigned to the fact that I’ll need new struts. Bright side: opportunity to upgrade.
    Next morning, I jack it up and begin inspecting. I pull myself closer by grabbing at the brake caliper and it shifts on me... and the photos below is what I found...
    BOTH brake caliper sliding bolts were completely missing! Very fortunate that the caliper didn’t slide out and begin grinding on the wheel during that trip! I took a bolt from the left caliper (too easy to loosen), went on a replacement bolt hunt on my motorcycle, and ended up going to many stores with no luck in finding a M8x1.00x20mm flanged bolt. Only in a complete kit. Anyways, replaced the bolts and ensured both sides were tight.
    Now, why do I hate dealers? Let’s start with how they convinced the prior owner that he needed complete brake service, including a flush, with only 61k miles... Don’t know many people on here who burn through Prius brake pads in 61k miles, but yeah... he even had old paperwork from a prior dealer inspection within the last year and it clearly showed plenty of life (measured in mm/mm) and was even in their “green” portion of their printed form.
    Anyways, aside from them taking advantage of, what I believe to be, a decent family of hard earned money for work that clearly was not required, the dealer put them at risk by not properly torquing the bolts on.
    TL;DR: Dealer did unnecessary work, screwed up, endangered a family.
  2. orenji
    orenji Senior Member
    5,887
    3,488
    Damn that’s scary! Don’t ever go to the dealer unless I absolutely have to. Hybridpit in SoCal is the only place I trust.
    Burna J likes this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    That is criminal !
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    So why did you not go to the dealership that did the work on the car and let them know?
    The service manage gets information from the mechanic and tells the customer.
    Maybe the dealership didn't know about bad mechanic? If no one complains, how can they?
    Maybe they would have offered to repair it correctly, or offer the bolts for free.
    You can't blame ALL dealerships. Independent shops are no better. They just charge less.
    It is very easy to get sidetracked while working on a car and forget to tighten something.
    Should it happen, NO! But it does. No one if perfect.
    I've worked at 3 different dealerships, and 2 different independent shops. There were good and bad
    at each one.
    I worked at a firestone place and the service manager tried to sell a young couple new pads, rotors, calipers,
    and a brake flush on there one year old car! With less than 10,000 miles on it. The pads had more than
    half the live left. I was working on the car. I had to tell the customer they did NOT need any of that and
    not to come back to firestone again. I told the manager I was going to report him to the district manager,
    and to the BBB. Then I quit!
    I know not everyone can repair there cars themselves, but they can be informed!
    tvpierce likes this.
  5. bisco
    52,849
    wow, what a story! i was riveted right from the headline
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Recommending unneeded service: could be a bad dealer... or just a bad service writer. Was it really unneeded though? For perspective, my wife's 2013 wagon needed rear brake pads at 90K -- that's right *rear* pads, front were fine. Quite unusual for a hybrid with regenerative braking. Her previous 2008 was still on its original pads/shoes when it was totaled at 180K.
    You should definately contact the dealer to let them know -- nobody's perfect, but it should be a teachable moment for the tech. I'm not a professional tech, but I do all the work on mine and my family's vehicles (cars, trucks, motorcycles, boats, small engines, etc.) and consider myself a pretty competent wrench. But I have to confess, I missed torqueing those bolts once while servicing my wife's car. She had a slight clunk when braking. When I pulled the wheel, one bolt was gone, the other was finger-tight. :eek: :oops:
    I was rushed while doing that job and hadn't done a final check of all the fastners -- just a dumb mistake. Remember what I said earlier about a teachable moment? That was one for me. You can bet your life I haven't made that mistake since. Now even if I'm rushed -- in fact, particularly when I'm rushed -- I stop and take 30 seconds to count off the fasteners and put a wrench on each of them.
    Montgomery and ASRDogman like this.
  7. Zythryn
    Zythryn Senior Member
    6,412
    4,413
    I agree the dealer should be notified of the dangerous service you received.
    That said, there is a reason Dealerships have the reputation they have. Frankly, the high pressure and tag team sales tactics are the number one reason in my opinion.
    But service departments haven't helped.
    Up until a few years ago there was a national survey that asked people to rate the trustworthiness of various organizations.
    "Congress" was second from the bottom of the list.
    Auto Dealers were last.
    The owners and managers have to know there is a problem when you are rated less trustworthy than congress.
    ***edit***
    Found a more recent one:
    America's Most & Least Trusted Professions [Infographic]
    It appears Congress has managed to fall below Car Salespeople.
    Not sure if it was this one I was thinking of or another that rated dealerships as a whole or just car salespeople.
    Mendel Leisk and ASRDogman like this.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Agreed. There are many issues but the main one IMO is the talent pool of skilled workers is shrinking rapidly as every successive generation have been avoiding trade/skills careers in droves.
    I don't like the dealership model either but I certainly don't want to be in the position of having to rely on only one authorized manufacturer service center where I end up with zero leverage and zero options and they know it. Out of the frying pan and into the fire as it were.
    ASRDogman likes this.
  9. ChapmanF
    19,020
    Part of that might be the "if you become talented and skilled, who hires you?" question, if the guy in the corner office is saying "why do we hire these talented skilled workers when we could hire lower-wage instruction followers and just give them complete perfect foolproof instructions to follow? what could go wrong?"
    I admit this thread isn't much of an illustration, as "put the pins back in" ought to be a safe expectation of an instruction-follower. Not a lot of years of technical judgement required for that.
  10. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I am sadly reminded of this trend every time I need to read the service manuals in my newer cars. One of those manuals (German car) is actually even more extreme in that they seem to be trying to remove as many words as possible. Almost everything is pictures, probably assuming that is easier than publishing it in all the various languages European mechanics might need. No need to think, no need to read, just plug it in to the magic diagnosis machine and follow the pictures.
  11. ChapmanF
    19,020
    Especially ironic, given that the magic diagnosis machine only gives you evidence; it doesn't give you any diagnoses.
    There is still a large opening for brain work in getting from the evidence to what caused it.
    vvillovv likes this.
  12. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Great posts chap .... This thread is the main reason I logged in today after 6 months or so.
    As I'm now replacing the OEM tires at 35k and at the wear bars, I've noticed the dealer added clipon
    weights to the mags at the cars last service and they have already started to corrode the mags,
    I mentioned previously that the tires were finally rotated at around 30k (if I recall correct like).
    This is a little thing in the overall perspective of service, but at my first 5k service, the mechanic didn't
    replace one of the tpms sensor caps, much less rotate the tires. Again, not a big thing to me, but I think it illustrates
    the point the OP is making in this thread.
    I'd also like to comment about hybrid dealership service quality and offer my take on one reason it might be lacking.
    The dealership mechanics have to work on a wde range of vehicles every day. Hybrid / Electric service is distintly different
    than gasser service in many respects. ie oil change intervals, etc....
    Unfortunately, it seems we have to either get used to services provided or DIY/O (do it your/our-selves)
  13. vvillovv
    4,337
    1,519
    NY
    My bad for typing before knowing for sure. It looks like the clipon weights are factory. I guess it's a good thing that the OEM tires wear so quickly, but a few simple additives between the mags and the steel would definitely help reduce the corrosion between the two metals.
    A few thousand more miles and I'd probably have a really tough time separating the wheels from the hubs.
  14. DTKim
    DTKim Member
    52
    32
    Sorry for the delayed responses, hectic last few days.
    I was not the customer at the time. Previous owner had the work done prior to my purchase, but moved out of state. I've dealt with this dealership before, but only for parts as I DIY whatever I can.
    Reality is, dealerships are in it to make money. They don't pay the rent on selling the new car and rely heavily on $100-140/hr labor rates for mechanics they (typically) pay $15-30/hr, aside from the senior mechanics. I've been in many other dealership service departments (mostly for warranty/recall work) and listening the the conversations, especially with the female customers, it's part of the job description.
    There's no notes as to who the mechanic is/was, so I doubt anyone will scold the service advisor for upselling and doubtful they'll do the digging to figure out who did the actual work.
    The real issue is that there's a separation of duties so there's plausible deniability. The person up front blames the person in the back and you never get to speak to the person in the back so they say whatever they want about the condition of your vehicle, because you can't see for yourself, due to "insurance".
    Anyways, probably the bigger post contribution (since I'm preaching to the choir) is that if you hear a blown suspension like noise, but it doesn't feel like it's blown, check out all of the bolts in that general area. Hopefully this advise never has to be of benefit to anyone.
    Threej likes this.
  15. BZzap!
    1,607
    878
    It’s sorta like dealing with the government.
    vvillovv, bisco and ASRDogman like this.
