Why I Hate my Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Apr 29, 2017.
  1. Zythryn
    Zythryn Senior Member
    6,412
    4,414
    You should have just asked. Just about anyone could have told you that buying a Model S solely for saving money on gas doesn’t pan out.
    Of course, buying a Prime doesn’t either, you should have bought a used Geo Metro if gas money was your only priority.;)
    Ming C and Raytheeagle like this.
  2. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I bought my Prime Adv on November, 30th. I have about 1500 miles on it. I have never had more than 23-25 miles EV mode available after a charge. How are you getting substantially more than that?
  3. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I chose the Prime based on many factors upon which the Geo Metro does not appear to be as capable of meeting my expectations. Specifically safety and reliability.
    The bottom line is that no matter how hard I try, owning the Prime greatly impairs my ability to financially justify the purchase of a Model S which was difficult enough to justify before purchasing the Prime. Hence, in keeping with the theme of this thread, I mentioned that.
    Short of winning the lottery, which not playing makes a little less likely, I do not expect to find a Model S in my garage next to my Prime. There simply is not enough room.
    bwilson4web and fuzzy1 like this.
  4. DavidA
    2,349
    1,825
    Chicago western burbs
    It takes a dozen or more charges and good warm weather for the estimated miles to creep up in the 30's. Remember, that's only an estimate and won't necessarily mean you will get more than 25. Now that it is winter, the estimated and actual will probably go down until April.
  5. bwilson4web
    16,537
    Well you could have kept the Geo Metro and gotten a used Leaf. We call that a garbage plug-in hybrid.
  6. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    This isn't a "hate" rather seemingly an information center display design or layout oversight or quirk. Today I finally realized that the outside temperature is positioned over the battery, while the charge percentage is over the ECO car. Kept wondering why the charge was always 72 and the outside temperature kept dropping, then the light bulb lit and DUH, realized what was what! Seems percent should be over battery and temperature over car, or better yet, positioned near the clock.
    But I can get use to it the way it is.
    Second the LED that illuminate the floor could be brighter.
    bisco and bwilson4web like this.
  7. bisco
    52,862
    odd, since the pip temp is on the hvac screen, and the battery miles below the battery icon.
    hate to see engineering go backwards
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    The HSI shows EV driving information. Part of that info is either the remaining percentage in the battery or the remaining range estimate as chosen in settings. What you have set to show the battery, I have set to show the MPH or M/KWH depending on HV vs EV mode. The battery info is already plainly shown on the HSI, so having it in place of the mpg gauge doesn't make sense. I'd rather have both pieces of data than two of one and none of the other.
    On the models with the 11.6" display the inside setting and the outside temperature are both on display. Apparently not on the base trim with the smaller screen.
    Unfortunately, it seems that all trim levels consider the actual cabin temperature to be classified information.
