Why in the Hell didnt Toyota put Air Vents in the Back ????????????
Discussion in 'Gen 3 Prius Main Forum' started by LARRYG36, Jul 6, 2013.
  1. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you don't have the climate vents set properly then it won't work. In my GenII the default when I turn the HVAC on is upper vents only. If I want upper and feet, I have to go to the climate screen and select it. The under seat vents won't blow anything if you don't have the feet option selected.
    We get hot here too, and no problems in the Prius. I find putting the AC on full and floor vent only with non-recirculating is best for cooling the whole car. The AC shoots to the back for people there and you get some as it cools down, but you also get some air flow that gets through the vents from the outside so you get a little breeze. Completely different strategy than if it is just 1 passenger.
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    There are two vents in the back. They are to the side of the spare tyre compartment and behind the 12 volt battery. The battery cooling fan depends on these to evacuate the hot air from the HV battery. They are in the same place as on most modern vehicles and vent under the rear bumper.
  3. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    FERI, what are you talking about ???? Whats that have to do with the AC vents???:confused:
    Tuesday when we take the kids into town (Vegas) for roller coaster riding , While my wife and i in front will be freezing our asses off and me with a scarf around my neck with the vents pointed to the rear at a slight angle up the the car in the power mode and still our daughter and her son and baby will be bitching/wining and fussing that they're too warm....Best way we've found to make everybody happy is , wife and i in the back, Daughter and grandson in front.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    just to make sure, you know there are flow controls in the vents themselves , right? shut them down some and more air will be diverted to the center vents. also make sure you are in recirc.
    if that fails, it is currently 53 and mostly cloudy here in anchorage.
    MPGnutcase likes this.
  5. Mendel Leisk
    41,459
    Do yourself a favour: read the responses.
    WE0H likes this.
  6. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    You have two rather large vents in the center of the dash. It's not rocket surgery to aim those vents to blow straight to the back seat, or maybe it is....
    It gets hot here in Mississippi, too, and the first thing I ask my friends is if they're getting enough air back there. Never had a complaint.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Thanks for this tip. I have just always pointed the front vents up and facing rear. The thought of changing the mode to the floor and using the rear vents has just never crossed my mind.
    I have not had this problem but once with my youngest son and his wife in the back. He is really hot-natured like his mom :)
  8. bisco
    51,939
    my 88 chrysler minivan had separate vents and controls in the back. darn kids wouldn't leave it alone.:cool:
    walter Lee and WE0H like this.
  9. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    grandchildren complaining here too about being hot
  10. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    My CMax has rear passenger vents with controls. They pass through the center arm rest tunnel which can also keep a drink chilled in it. Nice touch.
    PLSPUSH likes this.
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Or cool down your hot cup of coffee. :p
    WE0H likes this.
  12. fotomoto
    5,638
    3,813
    So. Texas
    LOL, no it's inside the compartment not the outside cupholders (where I keep my cup o' joe).
    But now that you mention it, I guess it would heat too if you select the vent option along with the usual floor routing for heat.
  13. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    .....................maybe if you close the front vents, more will be diverted to the rear
    Read more: http://priuschat.com/threads/why-in-the-hell-didnt-toyota-put-air-vents-in-the-back.128954/#ixzz2YPBEGRdB
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    Per: bisco's post.... maybe if you close the front vents, more will be diverted to the rear
    This will satisfy the front passengers and offer more cooling to the rear....
  14. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    If you are using the Eco driving mode it will derate the AC's performance, try using Normal driving mode which is the absence of any other mode.
    Posted from my iPhone via the Tapatalk app.
    WE0H likes this.
  15. Feri
    Feri Active Member
    761
    144
    Presumed you were talking about extraction vents which would enable front cold air to push to the back. if the warm air can't be pushed out of the vehicle you will get hot pockets of stale air.
    I've never had passengers complaining that they weren't cool enough, even on long hot trips to Sydney in 40+ degrees C.
  16. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    Well, I guess we live in the Twilight Zone and sense we're owned our 2011 for 15mins we dont know how to adjust AC vents ether.....:rolleyes: :confused: :rolleyes: But in 3 days after dropping the kids off at the airport it will all be a None Issue.:D
    walter Lee likes this.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thats OK Larry, we cant all be experts. ;)
    walter Lee, WE0H and dustoff003 like this.
  18. WE0H
    WE0H Senior Member
    3,247
    528
    Maybe someone could design a rear vent kit? We have tons of other aftermarket stuff available for the Prius :D
    Mike
    Mobile on my SGH-i717
    PLSPUSH likes this.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    the 'lowly' Civic LX for under $20k sticker gets rear seat heater (must be for A/C too) ducts and rearview camera.
    2013 Honda Civic Sedan - Specifications - Official Honda Website
    Rear-Seat Heater Ducts Standard Standard Standard
    but in new one, you'd need to XLE hybrid, most of those are near or well over $30k sticker.
  20. Flying White Dutchman
    4,376
    313
    sorry but this is really stupid
    you complain about the prius and compare it to a fusion ( is bigger and 1 class higher )
    i would say good luck with your fusion! lots of fun...
