Why in the Hell didnt Toyota put Air Vents in the Back ????????????
Discussion in 'Gen 3 Prius Main Forum' started by LARRYG36, Jul 6, 2013.
  1. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I'm surprised (or maybe I'm not) at how everyone is just trying to dismiss and ridicule the OP's perfectly legitimate issue.
    Whether "you" think it's a problem, or whether "you" can manage just fine by some manner of front vent re-pointing, is completely inconsequential to the OP's issue. They've had their car for years in a hot climate and have been unable to find any combination of modes/vents to adequately cool the backseat as much as THEY would like.
    So offer up suggestions, but you don't have to be rude and dismissive about it, it brings the entire community down. Amiright?
    We have the same problem, though to lesser degrees as our son is generally ok in warmer weather. In the few times I've sat back there in the hot weather I've found the ventilation severely limited and wound up having to put the window down.
    Our last vehicle had big, rear HVAC vents in the back of the center console and you could direct plenty of hot or cool air right where you wanted and needed it.
    It's not a deal-breaker for us, but I wish our Prius had a similar setup, and I feel your pain OP.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    2013 Civic LX can easily be had for $18,000 + TTL with rear seat ducts, rearview camera, USB, handsfree bluetooth.
    .... and its driver's seating is above reproach.
  3. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    well said
    Sporin likes this.
  4. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    Thanks SPORIN.
    Sporin likes this.
  5. Jzerocsk
    Jzerocsk Member
    108
    31
    I think that's the same thing the Prius have - a rear duct that blows when the "feet" setting is enabled on the CCU (which is generally when you're using the heater).
  6. Tideland Prius
    16,559
    Some of you are confusing the "rear seat heater ducts" (that's the one on the floor under the front seats) with the "rear A/C vents" which are typically mounted higher (either on the rear of the centre console or on the B-pillars). Most, if not all, new cars will have a rear seat heater duct (though some recent cars like the '03-'07 Corolla can be ordered without it).
    The A/C vents that the OP is talking about works when the climate control is on "FACE" (or at least the most effective. RRxing's photo attachment shows that air still blows out the top vents). This helps direct cold air to the rear rather than having to pass through half the cabin and warm up by the time it reaches the rear seating area.
    It's useful on vehicles with bigger cabins (like the Camry).
    To the OP, I'm guessing Toyota either thought the cabin is small enough that it didn't warrant it, they thought the targeted market wouldn't want to pay for it, or it saves cost on manufacturing. The issue is that the Prius' cabin is a hatchback and it has that large rear window that doesn't help with cooling the interior (unless it's tinted).
    PLSPUSH likes this.
  7. willrob
    willrob Junior Member
    33
    Madison, Wisconsin
    Keeping the rear hatch cover (tonneau) closed (ie - covering the rear compartment) will both reflect the sun's heat coming through the hatch window, and make less space for the air to have to cool down.
  8. Hoosier1
    Hoosier1 Member
    87
    33
    Southwest Indiana
    Remember the days when most cars and houses didn't have air conditioning? The back seat ride in our family car was really hot in the middle of the summer. In ten years, it will be interesting to hear the new expectations of automobiles if most of us are not on scooters or bicycles due to high fuel costs and bankruptcy of our cities, states and country.
  9. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Would window tint solve this?
    SCH-I535 ? 2
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Apparently not as the OP has dark tint judging from his avatar.
  11. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Many PC members here insist the Prius Hatchback is a Mid-size car like the Camry.
    You are the first one differs.
  12. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    Skipping ahead of reading everything, but you do have the system in closed mode? You should not be adding 110 deg air into the car and only just recirculate the interior air, that will cool it down. Also jumping in and out of the car every 30 minutes doesnt help either.
  13. Tideland Prius
    16,559
    The Prius is a midsize based on EPA volume. The Camry is on the larger side of midsize. (There's no doubt that the Camry is significantly wider for more elbow and hip room than the Prius)
  14. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    Great ideas on how to cool the interior of a Prius. My wife and I both wear contacts so it is difficult to aim the default front vents so that neither of us get air in the eyes. Next time I think I'll try defroster/floor to see if that solves the problem. When we have the grandkids in the back, we have usually taken them someplace and worn them out so they're sound asleep anyway!
  15. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I've tried defroster/floor but the deroster air heats up too much travelling over the windscreen glass in really hot weather. Deflecting the centre vents up is best> Cold air sinks.
    Prius_Cub likes this.
  16. Cthehentz
    Cthehentz New Member
    Las vegas
    A good thick sunshade along with tinted windows help but the only way to cool the car down is start driving with the windows down to blow the heat out and share the vents with the back seat.
  17. situationalawareness
    83
    43
    San Tan Valley, AZ
    There's been a lot of posts here, but I just wanted to add that while living in Phoenix, AZ & Las Vegas, NV my entire Prius was cooled by my AC nicely. I point my vents up since hot air rises, and usually close the side vents since it's simply peripheral. Did the job nicely, for 74 degree temps inside.
    Jeffrey Jessup and jgilliam1955 like this.
  18. knite75
    knite75 Junior Member
    46
    Has anyone figured out why the engineers neglected to put any vent in the rear?
    Took a road trip to Vegas from Los Angeles over the weekend. The passengers in the back complaining of heat while the the front passenger had to put on a sweater to keep warm.
    Wth Toyota?!
  19. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    Primary reason is that the Prius is first and foremost an economy car. By the way, wouldn't having rear passengers increase the weight of the car and decrease MPGs? Then, you've defeated the purpose of driving a Prius :D
    Nexus 7 ? 4
  20. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Were you sitting in the back seat?
